CSF Rsync not working with csf enabled
Discussion in 'Other Centmin Mod Installed software' started by pamamolf, Jun 5, 2016.
  1. YuchiRO
    YuchiRO Member
    100
    6
    7:31 PM
    5.5.4
    1. check for clues in /var/log/lfd.log and /var/log/messages for your servers ips related entries
    ldf dont show any ip relate both server
    message show blocked ip but it's yesterday, today i try rsync comand again and dont see any blocked as yesterday.
    2. check if either server ips are blocked in respective csf firewall via grep command
    Server 2
    csf -g 1.1.1.1
    Chain            num   pkts bytes target     prot opt in     out     source               destination
    ALLOWIN          1        0     0 ACCEPT     tcp  --  !lo    *       1.1.1.1       0.0.0.0/0            tcp dpt:2222
    ALLOWOUT         1        0     0 ACCEPT     tcp  --  *      !lo     1.1.1.1       0.0.0.0/0            tcp dpt:1111
    IPSET: No matches found for 1.1.1.1
    ip6tables:
    No matches found for 1.1.1.1 in ip6tables
    Server 1
     csf -g 2.2.2.2
    ALLOWIN          1        0     0 ACCEPT     tcp  --  !lo    *       2.2.2.2       0.0.0.0/0            tcp dpt:1111
    ALLOWOUT         1        0     0 ACCEPT     tcp  --  *      !lo     2.2.2.2       0.0.0.0/0            tcp dpt:2222
    IPSET: No matches found for 2.2.2.2
    ip6tables:
    No matches found for 2.2.2.2 in ip6tables
    Yes, i added to both server.
    12,579
    10:31 PM
    if they were added properly the server ips will show up in csf -g ipaddr output
    looks like they'd not
    12,579
    10:31 PM
    what if you just whitelist ip ?
    csf -a ipaddr
  4. YuchiRO
    YuchiRO Member
    100
    6
    7:31 PM
    5.5.4
    when i add ip with this command
    Adding 1.1.1.1 to csf.allow and iptables ACCEPT...
    csf: IPSET adding [1.1.1.1] to set [chain_ALLOW]
    12,579
    10:31 PM
    yes that means properly whitelisted ip
    then try rsync
    ensure custom sshd port is in /etc/csf/csf.conf TCP_IN/TCP_OUT and TCP6_IN/TCP6_OUT comma separated list of whitelisted ports on both servers
  6. YuchiRO
    YuchiRO Member
    100
    6
    7:31 PM
    5.5.4
    Thanks, work like charm.
    12,579
    10:31 PM
    guess the other method has issues which is strange, worked for me
  8. Meirami
    Meirami Active Member
    154
    3:31 PM
    This is really old thread, but still usefull. I'd like to share my way to do this.
    I rsynced between 2 dedicated ipv4s, so I think it's ok to open all ports.
    Server1 cfs -ta server2IP 'time in seconds'
    Server2 csf -ta server1IP 'time in seconds'
    *Time is how long rule is active
    After this, I scratched my head for a while.
    No connection.
    Until I remembered. I didn't use correct port.
    So, on server1 rsync 'server2 sshport' and rsync is connected.
