CSF Rsync not working with csf enabled
Discussion in 'Other Centmin Mod Installed software' started by pamamolf, Jun 5, 2016.
    4,101
    428
    9:27 PM
    Nginx-1.26.x
    Hi
    I have a server 2 that has a simple rsync script that sync a folder from server 1 to a folder from server 2.....
    But when i enable csf firewall on server 2 then is not working :(
    When i disable it all are working fine ....
    Any ideas?
    55,189
    12,251
    4:27 AM
    if you changed sshd ports on either source or destination, then the ports need to be whitelisted on both servers' firewalls
  3. SeaTea
    SeaTea Member
    49
    13
    the Netherlands
    8:27 PM
    Nginx:1.11
    MariaDB-10
    Just add the ip-adress of the other server in 'csf.allow' if you don't want to open ports for everyone.
    If you don't want all ports open for another hosts, just open one port.
    tcp|in|d=12345|s=52.1.2.3
    In this example you only open port 12345 for source-ip 52.1.2.3
    I am using csf together with lfd (which watches files and suspicious log activity). I control both via webmin which has a good web-interface for it. This is sometimes handy if I do not have a ssh client available.
    55,189
    12,251
    4:27 AM
    very nice tip regarding csf firewall @SeaTea (y)
  5. pamamolf
    4,101
    428
    9:27 PM
    Nginx-1.26.x
    Thanks @SeaTea :)
    Yes i use custom ports :)
    Let's say main server 1 port 1000 for ssh and ip 123.456.789.000 and server 2 the one that i run the script and connects to main server ssh port 1111 and ip 111.222.333.444 then should i use :
    server 1 edit csf.allow:
    tcp|in|d=1111|s=111.222.333.444
    and
    server 2 edit csf.allow:
    tcp|in|d=1000|s=123.456.789.000
    Correct ?
    55,189
    12,251
    4:27 AM
  7. pamamolf
    4,101
    428
    9:27 PM
    Nginx-1.26.x
    Confused :(
    So do i need to enable on each server two rules each?
    One for incoming and one for outgoing ?
    like:
    tcp|out|d=1111|s=111.222.333.444
    and
    tcp|out|d=1000|s=123.456.789.000
  8. pamamolf
    4,101
    428
    9:27 PM
    Nginx-1.26.x
    Actually these settings if they allow only the specified ip to connect to the ssh port then is not what i want :(
    I just need both servers to use existing ssh ports and let anyone to use the ports as it is now ......
    Also it should work as i have on csf config file in TCP_IN and TCP_OUT the port open but it doesn't work :(
    I also add the ip of server 1 to server 2 allow file of csf to avoid any ip blocks and the opposite...
    55,189
    12,251
    4:27 AM
    then my original suggestion stands open TCP_IN/OUT for the ports rsync connects to
    pay attention to examples and s= vs d= for source and destination
    check /var/log/messages for diagnostics info etc for what is being blocked etc
  10. pamamolf
    4,101
    428
    9:27 PM
    Nginx-1.26.x
    Ok i found that rsync port is 873 using:
    grep rsync /etc/services
    So if i enable this port for tcp/udp in/out on the firewall it may work ?
    Don't see the reason to open an extra port....
    I prefer to use default ssh ports and not 873 :(
    So is this ok?
    tcp|in|d=1000|s=111.222.333.444
    and
    tcp|in|d=1111|s=123.456.789.000
    55,189
    12,251
    4:27 AM
    i've never had to open port 873 for rsync to work once i setup csf whitelisted ports
  12. pamamolf
    4,101
    428
    9:27 PM
    Nginx-1.26.x
    Yes but the new ssh port is already changed using Centminmod menu and it auto add the new port on the csf config file...
    But this is not enough for rsync to work :(
    It's server has it's own new ssh port open on the csf config file.
    Or do you mean to add also the server 2 ssh port on the server 1 csf config file and the opposite?
    55,189
    12,251
    4:27 AM
    centmin.sh menu option to change sshd port only adds new ports whitelisting for TCP_IN (inbound) only, it does not added white listing for port on TCP_OUT (outbound) on same server and does not setup on destination server's csf firewall for TCP_IN (inbound)
    both source and destination servers need their respective CSF firewall's port whitelisting for their respective directions of rsync communication's destination and source ports
    server1 (sshd port XX)
    server2 (sshd port YY)
    server1 TCP_OUT (port YY) ==> server2 TCP_IN (port YY)
    server2 TCP_OUT (port XX) ==> server1 TCP_IN (port XX)
  14. pamamolf
    4,101
    428
    9:27 PM
    Nginx-1.26.x
    Server1 then:
    TCP_IN 1000
    TCP_OUT 1111
    and
    server2 :
    TCP_IN 1111
    TCP_OUT 1000
    Don't say that i didn't got it now :)
  15. pamamolf
    4,101
    428
    9:27 PM
    Nginx-1.26.x
    Didn't see your edit with the sample when i post it :)
    I think that my example above will work :)
  16. YuchiRO
    YuchiRO Member
    100
    6
    1:27 AM
    5.5.4
    I made same config as eva2000 sugguest:
    sv1 - ssh 1111 ip 1.1.1.1
    sv2 - ssh 2222 ip 2.2.2.2
    CSFallow sv1
    tcp|in|d=1111|s=2.2.2.2
    tcp|out|d=2222|s=2.2.2.2
    CSFallow sv2
    tcp|in|d=2222|s=1.1.1.1
    tcp|out|d=1111|s=1.1.1.1
    and csf -r both server but i cant rsync. So, what's i missing ?
    55,189
    12,251
    4:27 AM
    check for clues in /var/log/lfd.log and /var/log/messages for your servers ips related entries
    what rsync command and errors ?
  18. YuchiRO
    YuchiRO Member
    100
    6
    1:27 AM
    5.5.4
    rsync -avz --progress -e "ssh -p 1111" root@1.1.1.1:/home/nginx/domains/domain.com/public/* .
    ssh: connect to host 1.1.1.1 port 1111: Connection timed out
    rsync: connection unexpectedly closed (0 bytes received so far) [Receiver]
    rsync error: unexplained error (code 255) at io.c(605) [Receiver=3.0.9]
    55,189
    12,251
    4:27 AM
    1. check for clues in /var/log/lfd.log and /var/log/messages for your servers ips related entries
    2. check if either server ips are blocked in respective csf firewall via grep command
    csf -g ipaddress
    3. can you ssh into other server and vice versa via ssh from one server to another ?
    55,189
    12,251
    4:27 AM
    were these added to /etc/csf/csf.allow ?
