rsync "Connection timed out" problem
Discussion in 'Centmin Mod Insights' started by rdan, Jun 1, 2014.
    1:46 AM
    are you using centmin menu option 16 to change SSHD port ? or doing it manually ?
    16). Change SSHD Port Number
    using menu option 16 will first ask for your default SSHD port to be entered (22) then the port number of your new SSHD port you want to use.
  2. karistuck
    karistuck Member
    대한민국
    12:46 AM
    1.5.8
    I was changed sshd port number with 16 menu option long time ago.
    I can't connect ssh again still now.
    I was contact to my vps provider that wait for them reply.
    Thank you
    1:46 AM
    weird let us know what your web host finds out
  4. karistuck
    karistuck Member
    대한민국
    12:46 AM
    1.5.8
    My host is wable.com.
    Im wait from them because wable not support web console.
    Thank you so much @eva2000
    1:46 AM
    I've had IPTables/CSF issues before on wable.com but their tech support fixed it. Only using wable.com for testing Centmin Mod - not stable enough due to such issues for live production use. Prefer RamNode if you need OpenVZ VPS or KVM VPS that maybe cheaper than DigitalOcean and Linode.
  6. elargento
    elargento Member
    353
    12:46 PM
    I've disabled CSF from both centminmod servers and I'm still having this issue. Any suggestions?
    CSF has been disabled because I'm dealing with a support company and they ask me every day to whitelist a new IP and I'm tired of that
    1:46 AM
    If you disable CSF Firewall, then there are virtually no iptables rules setup for either of those servers so everything would be blocked. You'd need to setup iptables rules for SSHD port, HTTP/HTTPS port etc. CSF Firewall usually does that by default when it's running.
    What usage/app requires whitelisting new IPs everyday ?
