rsync "Connection timed out" problem
Discussion in 'Centmin Mod Insights' started by rdan, Jun 1, 2014.
    1,412
    1:14 AM
    # rsync -avzhe 'ssh -p 1234' root@192.1.2.3:/home/nginx/domains/ /home/nginx/domains/
    ssh: connect to host 192.1.2.3 port 1234: Connection timed out
    rsync: connection unexpectedly closed (0 bytes received so far) [receiver]
    rsync error: unexplained error (code 255) at io.c(600) [receiver=3.0.6]
    What could be the problem?
    Is it csf blocking this?
    55,400
    12,255
    3:14 AM
    192.1.2.3 a remote server or the server with Centmin Mod installed ?
    For security reasons, yes by default [HASHTAG]#CSF[/HASHTAG] firewall will block connections to root ssh unless the remote server is whitelisted as per CSF info at http://centminmod.com/csf_firewall.html
    If both remote and source servers are Centmin Mod based, then both instances of CSF need whitelisting as well.
  3. rdan
    1,412
    1:14 AM
    The remote server.
    55,400
    12,255
    3:14 AM
    in that case in /etc/csf/csf.conf need to add to TCP_OUT comma separated list of ports port 1234 to allow it outbound connections
    then restart CSF firewall
    csf -r
    moving this thread to Centmin Mod Insights forum so folks can understand this too
  5. rdan
    1,412
    1:14 AM
    I white list both IP on both end, and it works now :)
    55,400
    12,255
    3:14 AM
    Why I love CSF Firewall when properly configured for added security :)
  7. rdan
    1,412
    1:14 AM
    I also Love rsync because I can transfer my forum very quick thru different servers :)
    Even though I got 5GB+ Forum files only.
  8. rdan
    1,412
    1:14 AM
    sent 4.53M bytes  received 4.48G bytes  10.56M bytes/sec
    total size is 5.42G  speedup is 1.21
    55,400
    12,255
    3:14 AM
    Yeah i use rsync through http://www.rsnapshot.org to automate backup pulls from a Backupsy KVM VPS server with 500GB storage space for US$7/month and they had a promo for 100% free credit for every dollar you deposited. So got US$125 free credit on top of my US$125 deposited = US$250 to use. Going to spin up more Backupsy KVM VPS servers in different locations eventually :D
  10. Matt
    Matt Well-Known Member
    932
    415
    Rotherham, UK
    6:14 PM
    1.5.15
    MariaDB 10.2
    I also fully automate my backups using rsnapshot. Great programme. I don't use backupsy any more, as I'm putting my backups on the Kimsufi server.
    55,400
    12,255
    3:14 AM
    Yeah I'm using Backupsy to take advantage of their raid redundant storage as once you factor that into a dedicated server, the costs are much higher. But I guess with your Kimsufi server you could afford to setup more than one heh.
  12. Matt
    932
    415
    Rotherham, UK
    6:14 PM
    1.5.15
    MariaDB 10.2
    I don't even bother with that, I just rsync the most recent daily.0 backup to my NAS at home each night.
    55,400
    12,255
    3:14 AM
    I would love to do that too just restore speed for my ISP upload speed is too slow at ~150KB/s. 400GB of data would take ages to restore from my local pc :LOL:
  14. rdan
    1,412
    1:14 AM
    Same here :)
    I think Philippines Has the Most Expensive and Slowest Internet in the world (n)
    55,400
    12,255
    3:14 AM
    Well I have the weirdest ISP Telstra Australia effective is ~112Mbps down and ~2.5Mbps up within Australia and outside i.e. USA around 2-8Mbps down and up half that speed.
    Ah should start an http://speedtest.net thread in off topic forums :D
  16. karistuck
    karistuck Member
    대한민국
    2:14 AM
    1.5.8
    When I was type 'csf -r' on vps.
    Appear some error message.
    I want rsync for move data. But I couldn't it
    55,400
    12,255
    3:14 AM
  18. karistuck
    karistuck Member
    대한민국
    2:14 AM
    1.5.8
    No, never edit.
    And My iptables rule
    /etc/csf/csf.deny file
    55,400
    12,255
    3:14 AM
    try update and restart
    csf -u
    csf -r
    or disable FASTSTART in /etc/csf/csf.conf
    FASTSTART = "0"
  20. karistuck
    karistuck Member
    대한민국
    2:14 AM
    1.5.8
    I have some happen. When I typ csf -r than close connection to ssh
    Than I can't connecto ssh with custom port number.
    lol
    Im look for clear this issue
