Routing outgoing emails with Centmin and Sendgrid
Discussion in 'Install & Upgrades or Pre-Install Questions' started by Nelson, Dec 14, 2014.
  1. Nelson
    Nelson New Member
    9
    5:57 PM
    Hi there, my provider does not allow me to use port 25 for SMTP.
    The solution is to use services such as:
    • Mailgun
    • Mailchimp
    • Sendgrid
    In my other server I use cpanel with SendGrid, see this guide:
    Exim - SendGrid Documentation | SendGrid
    Cpanel setup is easy, but how you could use centmin mod With SendGrid, anyone of you had a similar problem?
    Thanks.
    55,380
    12,255
    8:57 AM
  3. Nelson
    Nelson New Member
    9
    5:57 PM
    Thanks for you reply.
  4. Razib Hasan
    Razib Hasan Member
    37
    15
    Dhaka, Bangladesh
    4:57 AM
    1.7.6
    5.10
    The configuration below works fine for me with Mandrill;
    # Cyrus SASL for System Administrators
    yum install cyrus-sasl-plain -y
    # create a file
    touch /etc/postfix/sasl_passwd
    # edit sasl_passwd file
    nano /etc/postfix/sasl_passwd
    #Occupy sasl_passwd file with mandrill's SMTP address and port along with your mandrill username & SMTP password
    [smtp.mandrillapp.com]:587 yourmandrilUsername@something.com:password
    # File permission for sasl_passwd file
    chmod 600 /etc/postfix/sasl_passwd
    postmap /etc/postfix/sasl_passwd
    #edit postfix configuration
    nano /etc/postfix/main.cf
    # === paste the following lines at the very last of main.cf file ===
    # enable SASL authentication
    smtp_sasl_auth_enable = yes
    # tell Postfix where the credentials are stored
    smtp_sasl_password_maps = hash:/etc/postfix/sasl_passwd
    smtp_sasl_security_options = noanonymous
    # use STARTTLS for encryption
    smtp_use_tls = yes
    relayhost = [smtp.mandrillapp.com]:587
    #restart postfix
    service postfix restart
    ### Note: Make sure you have port 587 open in CSF configuration.
