Nginx Rewrite Help
Discussion in 'Nginx, PHP-FPM & MariaDB MySQL' started by BamaStangGuy, May 14, 2015.
  1. BamaStangGuy
    BamaStangGuy Active Member
    668
    192
    5:55 AM
    Thanks to Slavik, we are on XenForo now with http://www.christianforums.com
    However, I can't get the url redirects to work for Nginx.
    Here is what I have:
    rewrite ^/t([\d]+)-([\d]+)/$ /showthread.php?t=$1&page=$2 permanent;
    rewrite ^/t([\d]+)/$ /showthread.php?t=$1 permanent;
    rewrite ^/t([\d]+)-([\d]+)/$ /forumdisplay.php?f=$1&page=$2 last;
    rewrite ^/t([\d]+)/$ /forumdisplay.php?f=$1 last;
    for the urls:
    Christian Forums
    http://www.christianforums.com/f445/
    They just redirect to the homepage.
    I have checked 301config.php and xf_import_log is defined correctly as well as the file path to xenforo install.
    What am I missing here?
    55,906
    12,281
    8:55 PM
    maybe the full Nginx vhost might help
  3. BamaStangGuy
    668
    192
    5:55 AM
    55,906
    12,281
    8:55 PM
    You can see even accessing http://www.christianforums.com/showthread.php without any vlaues redirects to index which AFAIK shouldn't do that
    Curious as you have done other vB to XF migrations on Nginx, did these same rewrites in same vhost syntax work before ? Or is it first time you tried this set of rewrites in Centmin Mod Nginx/ regular Nginx ?
    Try moving the 4 rewrites out of location root / context so they're not wrapped in any location context. i.e. above location / context
  5. rdan
    1,412
    6:55 PM
    For VBSEO preset 01, this one works for me.
  6. rdan
    1,412
    6:55 PM
    And I hard coded every forum node urls.
  7. prometheus
    prometheus Member
    39
    Greece
    1:55 PM
    1.9.9
    10.1
