Xenforo Rewrite Help
Discussion in 'Forum software usage' started by BamaStangGuy, Oct 31, 2014.
  1. BamaStangGuy
    BamaStangGuy Active Member
    668
    192
    3:16 PM
    55,797
    12,271
    6:16 AM
  3. BamaStangGuy
    668
    192
    3:16 PM
    Right that is what we are trying to do. html is removed from staticfiles.conf and still doesn't work.
  4. BamaStangGuy
    668
    192
    3:16 PM
    I see what you were saying. It was a 1 to 1 import. All ids are the same so we can skip the redirect to showthread.php
    55,797
    12,271
    6:16 AM
    you probably picked up on Jake's slight syntax or format boo boo with a newline before the rewrite, but if you didn't
    location ~* ^/forum/[^/]+/[0-9]+-[^\.]+\.html$ {
                    rewrite [^/]+/([0-9]+)-[^\.]+\.html$ /threads/$1/ last;
