Nginx (RESOLVED)Problem with lua
Discussion in 'Bug Reports' started by EckyBrazzz, Oct 17, 2019.
    190
    4:36 AM
    Acutely, I showed it the first time in post #3
    60,408
    12,614
    5:36 PM
    well another way to resolve this is to properly set lua_package_path when lua nginx module enabled openresty/lua-nginx-module
    in /usr/local/nginx/conf/nginx.conf in http{} context after variables for variables_hash_max_size
    http {
     map_hash_bucket_size 128;
     map_hash_max_size 4096;
     server_names_hash_bucket_size 128;
     server_names_hash_max_size 2048;
     variables_hash_max_size 2048;
    lua_package_path '/usr/local/lib/lua/?.lua;/usr/local/lib/lua/5.1/?.lua;/usr/local/lib/lua/ngx/?.lua;/usr/local/lib/lua/resty/?.lua;;';
    usually you just set the lua_package_path to whatever lua scripts you specifically want to load/use rather than all of them.
