PHP 8.4 compile problem
Discussion in 'Install & Upgrades or Pre-Install Questions' started by duderuud, Dec 14, 2024.
  1. duderuud
    duderuud Active Member
    328
    98
    The Netherlands
    10:42 AM
    1.29 x
    11.4
    • CentOS Version: AlmaLinux 9.5
    • Centmin Mod Version Installed: 131.00stable
    • Nginx Version Installed: 1.27.3
    • PHP Version Installed: 8.4.1
    • MariaDB MySQL Version Installed: 10.6.20
    • When was last time updated Centmin Mod code base ? : just now
    • Persistent Config:
    Tried to install PHP 8.4.1.
    When trying to (re)start php, I ghet the following error:
    PHP Warning:  PHP Startup: Unable to load dynamic library 'imagick.so' (tried: /usr/local/lib/php/extensions/no-debug-non-zts-20240924/imagick.so (/usr/local/lib/php/extensions/no-debug-non-zts-20240924/imagick.so: undefined symbol: php_strtolower), /usr/local/lib/php/extensions/no-debug-non-zts-20240924/imagick.so.so (/usr/local/lib/php/extensions/no-debug-non-zts-20240924/imagick.so.so: cannot open shared object file: No such file or directory)) in Unknown on line 0
    PHP Warning:  PHP Startup: Unable to load dynamic library 'mailparse.so' (tried: /usr/local/lib/php/extensions/no-debug-non-zts-20240924/mailparse.so (/usr/local/lib/php/extensions/no-debug-non-zts-20240924/mailparse.so: undefined symbol: php_strtolower), /usr/local/lib/php/extensions/no-debug-non-zts-20240924/mailparse.so.so (/usr/local/lib/php/extensions/no-debug-non-zts-20240924/mailparse.so.so: cannot open shared object file: No such file or directory)) in Unknown on line 0
    PHP Warning:  PHP Startup: Unable to load dynamic library 'redis.so' (tried: /usr/local/lib/php/extensions/no-debug-non-zts-20240924/redis.so (/usr/local/lib/php/extensions/no-debug-non-zts-20240924/redis.so: undefined symbol: php_rand), /usr/local/lib/php/extensions/no-debug-non-zts-20240924/redis.so.so (/usr/local/lib/php/extensions/no-debug-non-zts-20240924/redis.so.so: cannot open shared object file: No such file or directory)) in Unknown on line 0
    12,576
    6:42 PM
