reboot trouble
Discussion in 'Blogs & CMS usage' started by emre22, Dec 21, 2016.
  1. emre22
    emre22 Member
    44
    5
    8:06 AM
    nginx-1.10.1
    MariaDB 10
    so, how to do it on beta, I will test it first.. just hit the command:
    ./csfcf.sh nginx
    and it will do it automatically?
    60,161
    12,594
    5:06 PM
    add the include file outlined into your vhost above root directive first and then to test manually run
    /usr/local/src/centminmod/tools/csfcf.sh auto
    as per Beta Branch - csfcf.sh - automate Cloudflare Nginx & CSF Firewall setups | Centmin Mod Community
    that adds cloudflare ips to your csf firewall whitelist so they don't get blocked by csf + updates the include file you added with latest cloudflare ips
    example manual auto run output
     Add Cloudflare IP list to CSF
      Add to /etc/csf/csf.allow
    Adding 103.21.244.0/22 to csf.allow and iptables ACCEPT...
    csf: IPSET adding [103.21.244.0/22] to set [chain_ALLOW]
    Adding 103.22.200.0/22 to csf.allow and iptables ACCEPT...
    csf: IPSET adding [103.22.200.0/22] to set [chain_ALLOW]
    Adding 103.31.4.0/22 to csf.allow and iptables ACCEPT...
    csf: IPSET adding [103.31.4.0/22] to set [chain_ALLOW]
    Adding 104.16.0.0/12 to csf.allow and iptables ACCEPT...
    csf: IPSET adding [104.16.0.0/12] to set [chain_ALLOW]
    Adding 108.162.192.0/18 to csf.allow and iptables ACCEPT...
    csf: IPSET adding [108.162.192.0/18] to set [chain_ALLOW]
    Adding 131.0.72.0/22 to csf.allow and iptables ACCEPT...
    csf: IPSET adding [131.0.72.0/22] to set [chain_ALLOW]
    Adding 141.101.64.0/18 to csf.allow and iptables ACCEPT...
    csf: IPSET adding [141.101.64.0/18] to set [chain_ALLOW]
    Adding 162.158.0.0/15 to csf.allow and iptables ACCEPT...
    csf: IPSET adding [162.158.0.0/15] to set [chain_ALLOW]
    Adding 172.64.0.0/13 to csf.allow and iptables ACCEPT...
    csf: IPSET adding [172.64.0.0/13] to set [chain_ALLOW]
    Adding 173.245.48.0/20 to csf.allow and iptables ACCEPT...
    csf: IPSET adding [173.245.48.0/20] to set [chain_ALLOW]
    Adding 188.114.96.0/20 to csf.allow and iptables ACCEPT...
    csf: IPSET adding [188.114.96.0/20] to set [chain_ALLOW]
    Adding 190.93.240.0/20 to csf.allow and iptables ACCEPT...
    csf: IPSET adding [190.93.240.0/20] to set [chain_ALLOW]
    Adding 197.234.240.0/22 to csf.allow and iptables ACCEPT...
    csf: IPSET adding [197.234.240.0/22] to set [chain_ALLOW]
    Adding 198.41.128.0/17 to csf.allow and iptables ACCEPT...
    csf: IPSET adding [198.41.128.0/17] to set [chain_ALLOW]
    Adding 199.27.128.0/21 to csf.allow and iptables ACCEPT...
    csf: IPSET adding [199.27.128.0/21] to set [chain_ALLOW]
    Adding 2400:cb00::/32 to csf.allow and iptables ACCEPT...
    csf: IPSET adding [2400:cb00::/32] to set [chain_6_ALLOW]
    Adding 2405:8100::/32 to csf.allow and iptables ACCEPT...
    csf: IPSET adding [2405:8100::/32] to set [chain_6_ALLOW]
    Adding 2405:b500::/32 to csf.allow and iptables ACCEPT...
    csf: IPSET adding [2405:b500::/32] to set [chain_6_ALLOW]
    Adding 2606:4700::/32 to csf.allow and iptables ACCEPT...
    csf: IPSET adding [2606:4700::/32] to set [chain_6_ALLOW]
    Adding 2803:f800::/32 to csf.allow and iptables ACCEPT...
    csf: IPSET adding [2803:f800::/32] to set [chain_6_ALLOW]
    Adding 2c0f:f248::/32 to csf.allow and iptables ACCEPT...
    csf: IPSET adding [2c0f:f248::/32] to set [chain_6_ALLOW]
    Adding 2a06:98c0::/29 to csf.allow and iptables ACCEPT...
    csf: IPSET adding [2a06:98c0::/29] to set [chain_6_ALLOW]
    created /usr/local/nginx/conf/cloudflare.conf include file
  3. emre22
    emre22 Member
    44
    5
    8:06 AM
    nginx-1.10.1
    MariaDB 10
    allright I uncommented
    from my vhost configs.
    and hit that command
    all sites are still running on beta box :)
    60,161
    12,594
    5:06 PM
    you can confirm if it's working by checking visitor ips logged in your site's access_log at
    /home/nginx/domains/domain.com/log/access.log
    note as centmin mod nginx users a buffer cache ~256k in size for 60 seconds for writes to access_log for performance, log entries are not realtime unless you do an nginx restart which flushes writes from buffer cache to
    list last 10 lines of /home/nginx/domains/domain.com/log/access.log
    tail -10 /home/nginx/domains/domain.com/log/access.log
    you can browser your site first and look for log entry for your ISP ip
    if you are still getting redirected to main hostname, then it won't show up in /home/nginx/domains/domain.com/log/access.log
    have you also tried clearing browser cache, reboot your local pc before seeing if a redirect is cached in your browser ?
