Beta Branch add _dmotd_push_status validator and migrate 10 push sites in 140.00b…
Discussion in 'Centmin Mod Github Commits' started by eva2000, May 20, 2026.
    60,143
    12,590
    2:49 AM
    add _dmotd_push_status validator and migrate 10 push sites in 140.00beta01
    Introduces a tag-validating helper that wraps every append to the
    _dmotd_status_lines accumulator. Three behavioral upgrades:
    1. Tag enum validation at push time. The tag must be one of
    ok|warn|crit; anything else is replaced with 'crit' and a stderr
    warning is emitted. crit is chosen over warn so a future security
    warning that silently loses its tag cannot downgrade to [OK].
    2. Embedded newline scrubbing. The footer renderer iterates one entry
    per array element; a multiline payload (e.g. captured needs-restart
    output) would otherwise only get a badge on its first line.
    3. Removes the render-side defensive fallback at the (previously)
    _tag == _text check. Push-time validation makes the render-time
    forgiveness path unreachable.
    All 10 existing push sites (check_git_major_branch, ngxver_checker,
    phpver_checker, gitenv_askupdate up-to-date / out-of-date branches,
    needrestart_check, csf_version_checker 4 branches) migrated to
    _dmotd_push_status calls.
    140.00beta01 branch
