Sysadmin Raid10 using centminmod
Discussion in 'System Administration' started by Venucci, Jul 29, 2020.
  1. Venucci
    Venucci Member
    75
    7:00 PM
    currentyl
    Hi ! Are there any limitations or things that must be beared in mind if i wish to use RAID10 (4vps or dedis) with centminmod?
    50,891
    11,791
    4:00 AM
    Well technically VPS would use whatever disk storage your VPS host node uses and you wouldn't have control over configuring raid 10 for most VPS servers. So raid 10 decision is usually something for dedicated servers. Only decision for Centmin Mod or any LEMP stack with regards to raid 10 would be your disk partition configuration you decide. Centmin Mod won't care if you use raid or not, just what disk partitions/disk free sizes for partitions are. Easiest of course is just have one single /boot and / partition for the rest.
