Pure-FTP issue
Discussion in 'Other Centmin Mod Installed software' started by Matt Williams, Dec 3, 2015.
  1. Matt Williams
    537
    104
    Virginia, USA
    10:35 PM
    latest
    Added a new user for FTP and went to restart and this is what I get:
    [root@ngx ~]# service pure-ftpd start
    Redirecting to /bin/systemctl start  pure-ftpd.service
    Job for pure-ftpd.service failed. See 'systemctl status pure-ftpd.service' and 'journalctl -xn' for details.
    [root@ngx ~]# journalctl -xn
    -- Logs begin at Thu 2015-12-03 00:57:42 UTC, end at Thu 2015-12-03 04:25:58 UTC. --
    Dec 03 04:25:16 ngx.xxx.com kernel: Firewall: *TCP_IN Blocked* IN=eth0 OUT= MAC=56:00:00:18:44:bc:fe:00:00:18:44:bc:08:00 SRC=80.82.78.166 DST
    Dec 03 04:25:22 ngx.xxx.com kernel: Firewall: *TCP_IN Blocked* IN=eth0 OUT= MAC=56:00:00:18:44:bc:fe:00:00:18:44:bc:08:00 SRC=80.82.78.166 DST
    Dec 03 04:25:32 ngx.xxx.com kernel: Firewall: *TCP_IN Blocked* IN=eth0 OUT= MAC=56:00:00:18:44:bc:fe:00:00:18:44:bc:08:00 SRC=80.82.78.166 DST
    Dec 03 04:25:38 ngx.xxx.com kernel: Firewall: *TCP_IN Blocked* IN=eth0 OUT= MAC=56:00:00:18:44:bc:fe:00:00:18:44:bc:08:00 SRC=80.82.78.166 DST
    Dec 03 04:25:52 ngx.xxx.com kernel: Firewall: *TCP_IN Blocked* IN=eth0 OUT= MAC=56:00:00:18:44:bc:fe:00:00:18:44:bc:08:00 SRC=80.82.78.166 DST
    Dec 03 04:25:54 ngx.xxx.com systemd[1]: pure-ftpd.service operation timed out. Terminating.
    Dec 03 04:25:54 ngx.xxx.com systemd[1]: Failed to start Pure-FTPd FTP server.
    -- Subject: Unit pure-ftpd.service has failed
    -- Defined-By: systemd
    -- Unit pure-ftpd.service has failed.
    -- The result is failed.
    Dec 03 04:25:54 ngx.xxx.com systemd[1]: Unit pure-ftpd.service entered failed state.
    Dec 03 04:25:58 ngx.xxx.com kernel: Firewall: *TCP_IN Blocked* IN=eth0 OUT= MAC=56:00:00:18:44:bc:fe:00:00:18:44:bc:08:00 SRC=80.82.78.166 DST
    lines 1-18/18 (END)
    Dec 03 04:25:16 ngx.xxx.com kernel: Firewall: *TCP_IN Blocked* IN=eth0 OUT= MAC=56:00:00:18:44:bc:fe:00:00:18:44:bc:08:00 SRC=80.82.78.166 DST=104.238.182.86 LEN=40 T
    Dec 03 04:25:22 ngx.xxx.com kernel: Firewall: *TCP_IN Blocked* IN=eth0 OUT= MAC=56:00:00:18:44:bc:fe:00:00:18:44:bc:08:00 SRC=80.82.78.166 DST=104.238.182.86 LEN=40 T
    Dec 03 04:25:32 ngx.xxx.com kernel: Firewall: *TCP_IN Blocked* IN=eth0 OUT= MAC=56:00:00:18:44:bc:fe:00:00:18:44:bc:08:00 SRC=80.82.78.166 DST=104.238.182.86 LEN=40 T
    Dec 03 04:25:38 ngx.xxx.com kernel: Firewall: *TCP_IN Blocked* IN=eth0 OUT= MAC=56:00:00:18:44:bc:fe:00:00:18:44:bc:08:00 SRC=80.82.78.166 DST=104.238.182.86 LEN=40 T
    Dec 03 04:25:52 ngx.xxx.com kernel: Firewall: *TCP_IN Blocked* IN=eth0 OUT= MAC=56:00:00:18:44:bc:fe:00:00:18:44:bc:08:00 SRC=80.82.78.166 DST=104.238.182.86 LEN=40 T
    Dec 03 04:25:58 ngx.xxx.com kernel: Firewall: *TCP_IN Blocked* IN=eth0 OUT= MAC=56:00:00:18:44:bc:fe:00:00:18:44:bc:08:00 SRC=80.82.78.166 DST=104.238.182.86 LEN=40 T
    Tried restarting the firewall and also tried to re-install FTP and had no luck. Any advice?
    55,983
    12:35 PM
    never seen that before
    source and destination IP addresses familiar to you ?
  3. Matt Williams
    537
    104
    Virginia, USA
    10:35 PM
    latest
    DST=104.238.182.86 is the VPS IP - the other is a location in the Netherlands which isn't me. See: IP Address: 80.82.78.166
    55,983
    12:35 PM
  5. Matt Williams
    537
    104
    Virginia, USA
    10:35 PM
    latest
    [root@ngx ~]# service pure-ftpd restart; journalctl -xn
    Redirecting to /bin/systemctl restart  pure-ftpd.service
    -- Logs begin at Thu 2015-12-03 00:57:42 UTC, end at Thu 2015-12-03 04:46:51 UTC. --
    Dec 03 04:46:23 ngx.xxxx.com kernel: Firewall: *TCP_IN Blocked* IN=eth0 OUT= MAC=56:00:00:18:44:bc:fe:00:00:18:44:bc:08:00 SRC=80.82.78.166 DST=104.238.182.86 LEN=40 TOS=0x08 PREC=0x20 TTL=247 ID=460
    Dec 03 04:46:32 ngx.xxxx.com kernel: Firewall: *TCP_IN Blocked* IN=eth0 OUT= MAC=56:00:00:18:44:bc:fe:00:00:18:44:bc:08:00 SRC=58.218.205.73 DST=104.238.182.86 LEN=40 TOS=0x00 PREC=0x00 TTL=114 ID=25
    Dec 03 04:46:33 ngx.xxxx.com kernel: Firewall: *TCP_IN Blocked* IN=eth0 OUT= MAC=56:00:00:18:44:bc:fe:00:00:18:44:bc:08:00 SRC=80.82.78.166 DST=104.238.182.86 LEN=40 TOS=0x08 PREC=0x20 TTL=247 ID=165
    Dec 03 04:46:37 ngx.xxxx.com dhclient[683]: DHCPREQUEST on eth0 to 169.254.169.254 port 67 (xid=0x289c89d0)
    Dec 03 04:46:45 ngx.xxxx.com kernel: Firewall: *TCP_IN Blocked* IN=eth0 OUT= MAC=56:00:00:18:44:bc:fe:00:00:18:44:bc:08:00 SRC=80.82.78.166 DST=104.238.182.86 LEN=40 TOS=0x08 PREC=0x20 TTL=247 ID=635
    Dec 03 04:46:48 ngx.xxxx.com kernel: Firewall: *TCP_IN Blocked* IN=eth0 OUT= MAC=56:00:00:18:44:bc:fe:00:00:18:44:bc:08:00 SRC=112.95.0.175 DST=104.238.182.86 LEN=60 TOS=0x00 PREC=0x00 TTL=53 ID=5378
    Dec 03 04:46:50 ngx.xxxx.com dhclient[683]: DHCPREQUEST on eth0 to 169.254.169.254 port 67 (xid=0x289c89d0)
    Dec 03 04:46:51 ngx.xxxx.com systemd[1]: pure-ftpd.service operation timed out. Terminating.
    Dec 03 04:46:51 ngx.xxxx.com systemd[1]: Failed to start Pure-FTPd FTP server.
    Dec 03 04:46:51 ngx.xxxx.com systemd[1]: Unit pure-ftpd.service entered failed state.
    55,983
    12:35 PM
    what does output of give ?
    service pure-ftpd status
  7. Matt Williams
    537
    104
    Virginia, USA
    10:35 PM
    latest
    55,983
    12:35 PM
  9. Matt Williams
    537
    104
    Virginia, USA
    10:35 PM
    latest
    55,983
    12:35 PM
  11. Matt Williams
    537
    104
    Virginia, USA
    10:35 PM
    latest
    55,983
    12:35 PM
    looks like setup-callupload.sh script didn't launch the manual command that needs to run in background
    you can manually run the command
    pure-uploadscript -B -r /etc/pure-ftpd/clamscan.sh
    then restart restarting pure-ftpd service
  13. Matt Williams
    537
    104
    Virginia, USA
    10:35 PM
    latest
    Now it's working
  14. Matt Williams
    537
    104
    Virginia, USA
    10:35 PM
    latest
    55,983
    12:35 PM
    You're welcome :)
  16. Matt Williams
    537
    104
    Virginia, USA
    10:35 PM
    latest
    Where are the usernames/passwords for FTP stored at? Is there an easy way to delete existing FTP accounts?
    55,983
    12:35 PM
    see 1st post at Beta Branch - Centmin Mod .08 beta + pure-ftpd virtual FTP user support | Centmin Mod Community for pure-pw command to delete pure-ftpd virtual ftpd users
    pure-pw commands
    pure-pw command useradd was to add a virtual user. However, there's more commands to delete a user or change passwords etc.
    pure-pw manual is here and http://download.pureftpd.org/pub/pure-ftpd/doc/README.Virtual-Users
    pure-pw userdel login [-f passwd_file] [-F puredb_file] [-m]
    pure-pw passwd login [-f passwd_file] [-F puredb_file] [-m]
    pure-pw show login [-f passwd_file] [-m]
    pure-pw mkdb [<puredb_database_file> [-f passwd_file]] [-F puredb_file]
    pure-pw list [-f passwd_file]
    list all pure-ftpd created virtual FTP users
    pure-pw list
    pure-pw list
    ftpuser             /usr/local/nginx/html/./
    ftpuser2            /usr/local/nginx/html/./
    ftpuser3            /usr/local/nginx/html/./
    ftpuser4            /home/nginx/domains/domain1.com/./
    ftpuser6            /home/nginx/domains/sub.domain1.com/./
    ftpuser5            /home/nginx/domains/domain2.com/./
    to delete virtual FTP user
    pure-pw userdel FTPUSERNAME
    pure-pw mkdb
    change virtual FTP user's password
    pure-pw passwd FTPUSERNAME
    pure-pw mkdb
    show full details for an specific pure-ftpd virtual FTP user
    pure-pw show FTPUSERNAME
    password is encrypted
    pure-pw show ftpuser5
    Login              : ftpuser5
    Password           : $1$msgfvdN0$51dhLdPGiCQpQEwtZ30kF1
    UID                : 500 (nginx)
    GID                : 500 (nginx)
    Directory          : /home/nginx/domains/domain2.com/./
    Full name          :
    Download bandwidth : 0 Kb (unlimited)
    Upload   bandwidth : 0 Kb (unlimited)
    Max files          : 0 (unlimited)
    Max size           : 0 Mb (unlimited)
    Ratio              : 0:0 (unlimited:unlimited)
    Allowed local  IPs :
    Denied  local  IPs :
    Allowed client IPs :
    Denied  client IPs :
    Time restrictions  : 0000-0000 (unlimited)
    Max sim sessions   : 0 (unlimited)
