projecthoneypot.org installation with Xenforo and centmin mod
Discussion in 'System Administration' started by MaximilianKohler, Jul 4, 2023.
  1. MaximilianKohler
    MaximilianKohler Member
    203
    9
    8:49 PM
    In Xenforo's admin panel, spam page, there's an option to set up your forum with various anti-spam providers, including projecthoneypot.org.
    I registered my forum.website.com domain on projecthoneypot for the key. At the end of the process I realized the php script/page will only load on the alternative main.website.com that we're supposed to protect.
    Have you enabled honeypot on your forum(s)? Which domain/subdomain did you enter on the honeypot site? I don't know if it would be secure to register it on main.website.com?
    FYI, it took me some time to find the install location:
    It's at
    EDIT:
    I moved the file to
    and it loaded and worked at http://forum.website.com/honeypot.php
    55,801
    12,271
    1:49 PM
    You don't need to setup the actual Honeypot for Xenforo only using the API key should be enough
