Wordpress Problems with login page
Discussion in 'Blogs & CMS usage' started by MrKoro, Jan 28, 2018.
  1. MrKoro
    MrKoro New Member
    7
    11:41 AM
    1.13.8
    Hello!
    I am wondering if anyone on here could help me with a problem I have with a freshly installed Wordpress.
    When I try to login to my admin Dashboard for the first time the page just refreshes. Without displaying any error/success message.
    I tried to search around for a fix but none of them worked (clear cookies, add two lines of code to wp-config.php, Edit databases, replacing wp-admin & wp-includes, disable plugins by renaming the plugin folder etc.)
    I am now stuck with no solution in view. So I will be very grateful if anyone here could help me out!
    I am running 123.09beta01 on CentOS 7 64bit.
    Any settings haven't been changed. What this means is that I run centmin.sh option 22 right away after Centmin Mod is installed. And I have also rebooted my server.
    My VPS ($5) is hosted by Linode.
    If needed, I can record my screen for you guys to understand the problem better.
    Thank you so much!
    54,920
    12,240
    8:41 PM
    Do you have any front end reverse proxies like cloudflare or sucuri cloudproxy in use ?
    Are you use HTTPS SSL based wordpress or non-HTTPS wordpress ?
    curl -I https://domain.com
    curl -I http://domain.com
    curl -I http://www.domain.com
    wrap output in CODE tags
  3. MrKoro
    MrKoro New Member
    7
    11:41 AM
    1.13.8
    Thank you for the fast reply!
    I do use Cloudflare and their HTTPS SSL service.
    Here are the outputs you requested:
    /usr/local/nginx/conf/conf.d/mydomain.com.conf
    #server {
    #            listen   80;
    #            server_name mydomain.com;
    #            return 301 $scheme://www.mydomain.com$request_uri;
      server_name mydomain.com www.mydomain.com;
      # ssi  on;
      access_log /home/nginx/domains/mydomain.com/log/access.log combined buffer=256k flush=5m;
    error_log /home/nginx/domains/mydomain.com/log/error.log;
      include /usr/local/nginx/conf/autoprotect/mydomain.com/autoprotect-mydomain.com.conf;
      root /home/nginx/domains/mydomain.com/public;
      # server and/or vhost site
      include /usr/local/nginx/conf/wpincludes/mydomain.com/wpcacheenabler_mydomain.com.conf;
      #include /usr/local/nginx/conf/wpincludes/mydomain.com/wpsupercache_mydomain.com.conf;
      #include /usr/local/nginx/conf/wpincludes/mydomain.com/rediscache_mydomain.com.conf;
      #autoindex  on;
      #try_files /wp-content/cache/supercache/$http_host/$cache_uri/index.html $uri $uri/ /index.php?q=$
      # for wp cache enabler plugin
      try_files $cache_enabler_uri $uri $uri/ $custom_subdir/index.php?$args;
      # Wordpress Permalinks
     # Nginx level redis Wordpress
        #limit_conn xwpconlimit 30;
        auth_basic "Private";
        auth_basic_user_file /home/nginx/domains/mydomain.com/htpasswd_wplogin;
    location ~* /(xmlrpc\.php) {
      include /usr/local/nginx/conf/wpincludes/mydomain.com/wpsecure_mydomain.com.conf;
    HTTP/1.1 200 OK
    Date: Sun, 28 Jan 2018 14:15:27 GMT
    Connection: keep-alive
    Set-Cookie: __cfduid=dc0093afa642cafdd0d52d9905d5e6f7c1517148927; expires=Mon, 28-Jan-19 14:15:27 GMT; path=/; domain=.mydomain.com; HttpOnly; Secure
    Last-Modified: Sun, 28 Jan 2018 12:09:37 GMT
    Vary: Accept-Encoding
    X-Powered-By: centminmod
    Server: cloudflare
    CF-RAY: 3e44905ea97634ac-LHR
    curl -I https://www.mydomain.com:
    Date: Sun, 28 Jan 2018 14:23:57 GMT
    Set-Cookie: __cfduid=d1942dc7859192e6dfd9b7c4ac9267d321517149437; expires=Mon, 28-Jan-19 14:23:57 GMT; path=/; domain=.mydomain.com; HttpOnly; Secure
    Server: cloudflare
    CF-RAY: 3e449cd0f81a357e-LHR
    curl -I http://mydomain.com:
    Date: Sun, 28 Jan 2018 14:25:48 GMT
    Cache-Control: max-age=3600
    Expires: Sun, 28 Jan 2018 15:25:48 GMT
    Server: cloudflare
    CF-RAY: 3e449f84361034b8-LHR
    curl -I http://www.mydomain.com:
    Date: Sun, 28 Jan 2018 14:27:24 GMT
    Expires: Sun, 28 Jan 2018 15:27:24 GMT
    Server: cloudflare
    CF-RAY: 3e44a1dcd77535a8-LHR
    I edited out my domain name for privacy reasons and replaced it with mydomain.com
    Again, thank you very much! :)
    54,920
    12,240
    8:41 PM
    which is your main domain redirect for as this one is forcing a redirect loop from HTTPS www to non-www non-HTTPS
    Server: cloudflare
    If you have Centmin Mod Nginx with letsencrypt HTTPS vhost setup, then switch from cloudflare flexible ssl to full ssl and remove Cloudflare wordpress plugin and remove nginx vhost level redirect 301/302 redirects for http to https. If you do not have letsencrypt HTTPS on Centmin Mod Nginx vhost, then set cloudflare to flexible ssl and install cloudflare wordpress plugin and remove nginx vhost level redirect 301/302 redirects for http to https.
    Unrelated to your issue is if you use a reverse proxy like Cloudflare, Sucuri, or Incapsula in front of Centmin Mod Nginx, you need to setup nginx realip to be passed onto Nginx.
    See Getting Started Guide step 5 and setting correct real ip via nginx module config at http://centminmod.com/nginx_configure_cloudflare.html.
    If using Centmin Mod 123.09beta01 and newer, there's an added tools/csfcf.sh script to aid in this. Details at:
    You just need to setup a cronjob to run
    /usr/local/src/centminmod/tools/csfcf.sh auto
    and ensure your nginx.conf http{} context has the include file /usr/local/nginx/conf/cloudflare.conf and/or your individual nginx vhost's server contexts has the same include file
    http {
    map_hash_bucket_size 128;
    map_hash_max_size 2048;
    server_names_hash_bucket_size 128;
    server_names_hash_max_size 2048;
    limit_req_zone $binary_remote_addr zone=xwplogin:16m rate=40r/m;
    #limit_conn_zone $binary_remote_addr zone=xwpconlimit:16m;
    more_set_headers "Server: nginx centminmod";
    more_set_headers "X-Powered-By: centminmod";
    include /usr/local/nginx/conf/maintenance.conf;
    include /usr/local/nginx/conf/vts_http.conf;
    include /usr/local/nginx/conf/fastcgi_param_https_map.conf;
    Then restart nginx server via command shortcut
    ngxrestart
    or
    service nginx restart
    54,920
    12,240
    8:41 PM
    /usr/local/nginx/conf/conf.d/mydomain.com.conf file is missing alot of output actually
    cat /usr/local/nginx/conf/conf.d/mydomain.com.conf
    will show it all
  6. MrKoro
    MrKoro New Member
    7
    11:41 AM
    1.13.8
    Yep, I noticed that. Just edited my 2nd post.
    54,920
    12,240
    8:41 PM
    so you only have non-https nginx vhost so highlighted quoted part applies
  8. MrKoro
    MrKoro New Member
    7
    11:41 AM
    1.13.8
    Can you please tell me how to do this?
    54,920
    12,240
    8:41 PM
    no need your mydomain.com.conf vhost already has them commented out
    #server {
    #            listen   80;
    it's usually a step users manually do as per centminmod.com/nginx_domain_dns_setup.html#httpsredirect
  10. MrKoro
    MrKoro New Member
    7
    11:41 AM
    1.13.8
    Hello again.
    I am still having the same problem after I followed your instructions. Do you have any more idea how this problem can be solved?
    Here is how it looks like (.gif) :
    54,920
    12,240
    8:41 PM
    did you install and configure wordpress cloudflare plugin previously Using Cloudflare with WordPress ?
    try disabling cloudflare orange cloud on your wordpress domain temporarily and see if it works
  12. MrKoro
    MrKoro New Member
    7
    11:41 AM
    1.13.8
    I did manually install the plugin via FTP but couldn't configure it. (No access to the dashboard. But now I will try.) And I could login after I disabled Cloudflare orange cloud. How do I move forward after this to fix the underlying problem?
    Thank you for all the help! Phenomenal support :)
  13. jeparamedia
    jeparamedia Member
    32
    5:41 PM
    1.15.12
    MariaDB 10.3.15
    Hey Mrkoro, same problem with me... same problem in 3 days in row... and still trying to make it work :D
    thanks to @MrKoro and @eva2000
    54,920
    12,240
    8:41 PM
  15. jeparamedia
    jeparamedia Member
    32
    5:41 PM
    1.15.12
    MariaDB 10.3.15
    54,920
    12,240
    8:41 PM
    self signed ssl certificates not trusted by web browsers so visitors won't be able to use your site by default. Centmin Mod Nginx's letsencrypt ssl certificate process in 123.09beta01 and newer is more robust and renewals usually happen without issue. So quick install/creation of Nginx HTTP/2 HTTPS vhost site with letsencrypt ssl certificate at https://community.centminmod.com/th...-nginx-vhost-site-mysql-database-setup.13602/ is a good start as all letsencrypt ssl issued certificates get auto renewal fine.
  17. jeparamedia
    jeparamedia Member
    32
    5:41 PM
    1.15.12
    MariaDB 10.3.15
    aaah.. now i know what to do :)
    million thanks brother @eva2000 ..
    I feel i have a good support without a paying single of buck :D
    ;)(y)
