Upgrade Problems when I upgraded from 123.09beta01 to 131.00stable
Discussion in 'Install & Upgrades or Pre-Install Questions' started by jellday, Oct 17, 2024.
  1. jellday
    jellday Member
    73
    10:51 PM
    1.4.6
    5.5
    • CentOS Version:
      CentOS release 6.10 (Final)
    • Centmin Mod Version Installed:
      131.00stable
    • Nginx Version Installed:
    • PHP Version Installed:
      PHP 5.6.40 (cli) (built: Jul 23 2019 05:41:09)
      Zend Engine v2.6.0, Copyright (c) 1998-2016 Zend Technologies
          with Zend OPcache v7.0.6-dev, Copyright (c) 1999-2016, by Zend Technologies
    • MariaDB MySQL Version Installed:
      5.5.64-MariaDB
    • When was last time updated Centmin Mod code base ? : Oct 16th,2024
    • Persistent Config: no
      MARCH_TARGETNATIVE='n'
    The problem is when I run centmin.sh, I got several errors:
    awk: cmd. line:1: fatal: cannot open file `/etc/os-release' for reading (No such file or directory)
    cat: /etc/os-release: No such file or directory
    /usr/local/src/centminmod/inc/datamanager.inc: line 5: jq: command not found
    /usr/local/src/centminmod/inc/cpcheck.inc: line 1361: jq: command not found
    /usr/local/src/centminmod/inc/cpcheck.inc: line 1362: jq: command not found
    I checked and there is no "os-release" file but only "centos-release" file. And what is "jq" file, where can I find it?
    Anyway, the problem is not big, but I still need help. Many thanks.
    The following is the process when I upgraded from 123.09beta01 to 131.00stable.
    # ./centmin.sh
    pure-ftpd: create 2048bit /etc/pki/pure-ftpd/pure-ftpd.pem file for
    pure-ftpd: /etc/pki/pure-ftpd/pure-ftpd.pem created
    /etc/init.d /usr/local/src/centminmod
    1).  Centmin Install
    2).  Add Nginx vhost domain
    5).  PHP Upgrade / Downgrade
    6).  XCache Re-install
    7).  APC Cache Re-install
    8).  XCache Install
    9).  APC Cache Install
    14). SELinux disable
    16). Change SSHD Port Number
    17). Multi-thread compression: zstd,pigz,pbzip2,lbzip2
    20). NSD Install/Re-Install
    21). Data Transfer (TBA)
    24). Exit
    Enter option [ 1 - 24 ] 23
            Centmin Mod Updater Sub-Menu
    1). Setup Centmin Mod Github Environment
    2). Update Centmin Mod Current Branch
    3). Update Centmin Mod Newer Branch
    4). Exit
    Enter option [ 1 - 4 ] 3
    fetching latest branch list...
    Update Centmin Mod to newer branch via git
    You need to input the name of the branch
    List of current remote branches by descending date order
    /centminmod/centminmod/branches
    /centminmod/centminmod/branches/active
    /centminmod/centminmod/branches/stale
    /centminmod/centminmod/branches/all
    140.00beta01
    /centminmod
    131.00stable
    /centminmod
    Enter the branch name you want to switch to i.e. 123.09beta01 : 131.00stable
    download github.com centmin mod 131.00stable branch repo
    time git clone -b 131.00stable --depth=1 https://github.com/centminmod/centminmod.git centminmod
    Initialized empty Git repository in /usr/local/src/centminmod/.git/
    real    0m11.412s
    user    0m7.967s
    sys    0m1.679s
    list all available local branches
     git branch -a
    * 131.00stable
      remotes/origin/123.06stable
      remotes/origin/123.07stable
      remotes/origin/123.08stable
      remotes/origin/123.09beta01
      remotes/origin/123.09beta01-cf-http3
      remotes/origin/123.09beta01-el8
      remotes/origin/123.09beta01-el8.3
      remotes/origin/123.09beta01-el8.5
      remotes/origin/123.09beta01-mariadb105
      remotes/origin/123.09beta01-nginx-http3-preview1
      remotes/origin/123.09beta01-wpsendmail
      remotes/origin/124.00stable
      remotes/origin/130.00beta01
      remotes/origin/130.00beta01-appstream-mariadb
      remotes/origin/130.00beta01-mariadb10.11
      remotes/origin/131.00stable
      remotes/origin/140.00beta01
      remotes/origin/HEAD -> origin/master
      remotes/origin/master
    list git log last commit
     git log -a
    commit efd5840f2761fdb09744c0926ce7ba83c7f2d4a4
    Author: George Liu (eva2000) <eva2000@centminmod.com>
    Date:   Fri Oct 4 10:59:52 2024 +1000
        update nginx 1.27.2 in 131.00stable
        - update nginx 1.27.2 default https://community.centminmod.com/threads/nginx-announce-nginx-1-27-2.26489/
    to update centmin mod 131.00stable branch repo via git
     cd /usr/local/src/centminmod
     git stash
     git pull
     chmod +x centmin.sh
    ####################### IMPORTANT #######################
     To complete update
     run:
     before invoking centmin.sh again
    [02:34][root@vultr.guest centminmod]# cd /usr/local/src/centminmod
    [02:35][root@vultr.guest centminmod]#  git stash
    No local changes to save
    [02:35][root@vultr.guest centminmod]#  git pull
    Already up-to-date.
    [02:35][root@vultr.guest centminmod]#  chmod +x centmin.sh
    [02:35][root@vultr.guest centminmod]# ./centmin.sh
    Creating backup...
    `/etc/csf/csf.conf' -> `/var/lib/csf/backup/1729132537_before_cc_src_2_switch'
    Creating backup...
    `/etc/csf/csf.conf' -> `/var/lib/csf/backup/1729132538_after_cc_src_2_switch'
         Centmin Mod Menu 131.00stable centminmod.com
    1).  Centmin Install
    6).  MySQL User Database Management
    7).  Option Being Revised (TBA)
    8).  Option Being Revised (TBA)
    9).  Option Being Revised (TBA)
    21). Data Transfer
    24). Exit
    54,389
    12,198
    12:51 AM
    CentOS 6.x has long been end of life and not longer supports by CentOS so Centmin Mod wouldn't really support new installs - though existing installs may work somewhat.
    That I came across for my test CentOS 6.x systems I still have. For that you need to switch to Centmin Mod 140.00beta01 https://community.centminmod.com/th...ase-with-almalinux-rocky-linux-support.25572/ which is only branch with that specific fix
    So on existing server run cmupdate command below to switch to 140.00beta01
    cmupdate update-beta
    But I highly suggest you move to a new server with AlmaLinux 8 or 9 instead of remaining on CentOS 6.x as it's end of life.
  3. jellday
    jellday Member
    73
    10:51 PM
    1.4.6
    5.5
    Many thanks for your help.
    Switching OS is time-consuming and lots of work, and I am not sure if current web-apps' compatible with AlmaLinux, which can be tricky.
