Amazon AWS Problems restoring from image in AWS
Discussion in 'Virtual Private Server (VPS) hosting' started by fly, Aug 14, 2020.
  1. Dryline
    Dryline New Member
    7
    Colorado
    7:32 AM
    1.15.9
    It’s a CentOS based EC2 image running Centminmod versus Windows.
  2. fly
    fly Member
    109
    16
    9:32 AM
    Sorry to bump an old thread, but I'm wondering if its related...
    I just did a yum update on my server and got the following error:
    Error: Package: python-requests-2.6.0-10.el7.noarch (base)
               Requires: python-urllib3 >= 1.10.2-1
     You could try using --skip-broken to work around the problem
    ** Found 1 pre-existing rpmdb problem(s), 'yum check' output follows:
    python-requests-2.6.0-9.el7_8.noarch has missing requires of python-urllib3 >= ('0', '1.10.2', '1')
    The issue in this thread was related to python-urllib3, so I was wondering what the correct course of action here should be.
  3. fly
    fly Member
    109
    16
    9:32 AM
    Just following back up on this. Any ideas?
    11:32 PM
    can you post the full command output for the yum update wrapped in CODE or CODEB tags - How to use forum BBCODE code tags
  5. fly
    fly Member
    109
    16
    9:32 AM
    Sure
    [12:46][root@ip centos]# yum update
     * base: d36uatko69830t.cloudfront.net
     * centos-sclo-rh: d36uatko69830t.cloudfront.net
     * centos-sclo-sclo: d36uatko69830t.cloudfront.net
     * epel: mirror.steadfastnet.com
     * extras: d36uatko69830t.cloudfront.net
     * rpmforge: mirror.teklinks.com
     * updates: d36uatko69830t.cloudfront.net
    328 packages excluded due to repository priority protections
    Excluding 12 updates due to versionlock (use "yum versionlock status" to show them)
    Resolving Dependencies
    --> Running transaction check
    ---> Package MariaDB-client.x86_64 0:10.1.46-1.el7.centos will be updated
    ---> Package MariaDB-client.x86_64 0:10.1.48-1.el7.centos will be an update
    ---> Package MariaDB-common.x86_64 0:10.1.46-1.el7.centos will be updated
    ---> Package MariaDB-common.x86_64 0:10.1.48-1.el7.centos will be an update
    ---> Package MariaDB-compat.x86_64 0:10.1.46-1.el7.centos will be updated
    ---> Package MariaDB-compat.x86_64 0:10.1.48-1.el7.centos will be an update
    ---> Package MariaDB-devel.x86_64 0:10.1.46-1.el7.centos will be updated
    ---> Package MariaDB-devel.x86_64 0:10.1.48-1.el7.centos will be an update
    ---> Package MariaDB-server.x86_64 0:10.1.46-1.el7.centos will be updated
    ---> Package MariaDB-server.x86_64 0:10.1.48-1.el7.centos will be an update
    ---> Package MariaDB-shared.x86_64 0:10.1.46-1.el7.centos will be updated
    ---> Package MariaDB-shared.x86_64 0:10.1.48-1.el7.centos will be an update
    ---> Package OpenEXR-devel.x86_64 0:1.7.1-7.el7 will be updated
    ---> Package OpenEXR-devel.x86_64 0:1.7.1-8.el7 will be an update
    ---> Package OpenEXR-libs.x86_64 0:1.7.1-7.el7 will be updated
    ---> Package OpenEXR-libs.x86_64 0:1.7.1-8.el7 will be an update
    ---> Package apr.x86_64 0:1.4.8-5.el7 will be updated
    ---> Package apr.x86_64 0:1.4.8-7.el7 will be an update
    ---> Package bind-export-libs.x86_64 32:9.11.4-16.P2.el7_8.6 will be updated
    ---> Package bind-export-libs.x86_64 32:9.11.4-26.P2.el7_9.4 will be an update
    ---> Package bind-libs.x86_64 32:9.11.4-16.P2.el7_8.6 will be updated
    ---> Package bind-libs.x86_64 32:9.11.4-26.P2.el7_9.4 will be an update
    ---> Package bind-libs-lite.x86_64 32:9.11.4-16.P2.el7_8.6 will be updated
    ---> Package bind-libs-lite.x86_64 32:9.11.4-26.P2.el7_9.4 will be an update
    ---> Package bind-license.noarch 32:9.11.4-16.P2.el7_8.6 will be updated
    ---> Package bind-license.noarch 32:9.11.4-26.P2.el7_9.4 will be an update
    ---> Package bind-utils.x86_64 32:9.11.4-16.P2.el7_8.6 will be updated
    ---> Package bind-utils.x86_64 32:9.11.4-26.P2.el7_9.4 will be an update
    ---> Package binutils.x86_64 0:2.27-43.base.el7_8.1 will be updated
    ---> Package binutils.x86_64 0:2.27-44.base.el7 will be an update
    ---> Package bluez-libs.x86_64 0:5.44-6.el7 will be updated
    ---> Package bluez-libs.x86_64 0:5.44-7.el7 will be an update
    ---> Package bluez-libs-devel.x86_64 0:5.44-6.el7 will be updated
    ---> Package bluez-libs-devel.x86_64 0:5.44-7.el7 will be an update
    ---> Package centos-release.x86_64 0:7-8.2003.0.el7.centos will be updated
    ---> Package centos-release.x86_64 0:7-9.2009.1.el7.centos will be an update
    ---> Package chkconfig.x86_64 0:1.7.4-1.el7 will be updated
    ---> Package chkconfig.x86_64 0:1.7.6-1.el7 will be an update
    ---> Package cloud-init.x86_64 0:18.5-6.el7.centos.5 will be updated
    ---> Package cloud-init.x86_64 0:19.4-7.el7.centos.3 will be an update
    ---> Package cmake3.x86_64 0:3.17.3-3.el7 will be updated
    ---> Package cmake3.x86_64 0:3.17.5-1.el7 will be an update
    ---> Package cmake3-data.noarch 0:3.17.3-3.el7 will be updated
    ---> Package cmake3-data.noarch 0:3.17.5-1.el7 will be an update
    ---> Package coreutils.x86_64 0:8.22-24.el7 will be updated
    ---> Package coreutils.x86_64 0:8.22-24.el7_9.2 will be an update
    ---> Package cpio.x86_64 0:2.11-27.el7 will be updated
    ---> Package cpio.x86_64 0:2.11-28.el7 will be an update
    ---> Package cpp.x86_64 0:4.8.5-39.el7 will be updated
    ---> Package cpp.x86_64 0:4.8.5-44.el7 will be an update
    ---> Package cups-libs.x86_64 1:1.6.3-43.el7 will be updated
    ---> Package cups-libs.x86_64 1:1.6.3-51.el7 will be an update
    ---> Package curl.x86_64 0:7.29.0-57.el7_8.1 will be updated
    ---> Package curl.x86_64 0:7.29.0-59.el7_9.1 will be an update
    ---> Package dbus.x86_64 1:1.10.24-14.el7_8 will be updated
    ---> Package dbus.x86_64 1:1.10.24-15.el7 will be an update
    ---> Package dbus-libs.x86_64 1:1.10.24-14.el7_8 will be updated
    ---> Package dbus-libs.x86_64 1:1.10.24-15.el7 will be an update
    ---> Package device-mapper.x86_64 7:1.02.164-7.el7_8.2 will be updated
    ---> Package device-mapper.x86_64 7:1.02.170-6.el7_9.3 will be an update
    ---> Package device-mapper-libs.x86_64 7:1.02.164-7.el7_8.2 will be updated
    ---> Package device-mapper-libs.x86_64 7:1.02.170-6.el7_9.3 will be an update
    ---> Package dhclient.x86_64 12:4.2.5-79.el7.centos will be updated
    ---> Package dhclient.x86_64 12:4.2.5-82.el7.centos will be an update
    ---> Package dhcp-common.x86_64 12:4.2.5-79.el7.centos will be updated
    ---> Package dhcp-common.x86_64 12:4.2.5-82.el7.centos will be an update
    ---> Package dhcp-libs.x86_64 12:4.2.5-79.el7.centos will be updated
    ---> Package dhcp-libs.x86_64 12:4.2.5-82.el7.centos will be an update
    ---> Package dmidecode.x86_64 1:3.2-3.el7 will be updated
    ---> Package dmidecode.x86_64 1:3.2-5.el7 will be an update
    ---> Package dracut.x86_64 0:033-568.el7 will be updated
    ---> Package dracut.x86_64 0:033-572.el7 will be an update
    ---> Package dracut-config-generic.x86_64 0:033-568.el7 will be updated
    ---> Package dracut-config-generic.x86_64 0:033-572.el7 will be an update
    ---> Package dracut-config-rescue.x86_64 0:033-568.el7 will be updated
    ---> Package dracut-config-rescue.x86_64 0:033-572.el7 will be an update
    ---> Package dracut-network.x86_64 0:033-568.el7 will be updated
    ---> Package dracut-network.x86_64 0:033-572.el7 will be an update
    ---> Package e2fsprogs.x86_64 0:1.42.9-17.el7 will be updated
    ---> Package e2fsprogs.x86_64 0:1.42.9-19.el7 will be an update
    ---> Package e2fsprogs-devel.x86_64 0:1.42.9-17.el7 will be updated
    ---> Package e2fsprogs-devel.x86_64 0:1.42.9-19.el7 will be an update
    ---> Package e2fsprogs-libs.x86_64 0:1.42.9-17.el7 will be updated
    ---> Package e2fsprogs-libs.x86_64 0:1.42.9-19.el7 will be an update
    ---> Package elfutils-default-yama-scope.noarch 0:0.176-4.el7 will be updated
    ---> Package elfutils-default-yama-scope.noarch 0:0.176-5.el7 will be an update
    ---> Package elfutils-devel.x86_64 0:0.176-4.el7 will be updated
    ---> Package elfutils-devel.x86_64 0:0.176-5.el7 will be an update
    ---> Package elfutils-libelf.x86_64 0:0.176-4.el7 will be updated
    ---> Package elfutils-libelf.x86_64 0:0.176-5.el7 will be an update
    ---> Package elfutils-libelf-devel.x86_64 0:0.176-4.el7 will be updated
    ---> Package elfutils-libelf-devel.x86_64 0:0.176-5.el7 will be an update
    ---> Package elfutils-libs.x86_64 0:0.176-4.el7 will be updated
    ---> Package elfutils-libs.x86_64 0:0.176-5.el7 will be an update
    ---> Package expat.x86_64 0:2.1.0-11.el7 will be updated
    ---> Package expat.x86_64 0:2.1.0-12.el7 will be an update
    ---> Package expat-devel.x86_64 0:2.1.0-11.el7 will be updated
    ---> Package expat-devel.x86_64 0:2.1.0-12.el7 will be an update
    ---> Package file.x86_64 0:5.11-36.el7 will be updated
    ---> Package file.x86_64 0:5.11-37.el7 will be an update
    ---> Package file-libs.x86_64 0:5.11-36.el7 will be updated
    ---> Package file-libs.x86_64 0:5.11-37.el7 will be an update
    ---> Package fio.x86_64 0:3.7-1.el7 will be updated
    ---> Package fio.x86_64 0:3.7-2.el7 will be an update
    ---> Package freetype.x86_64 0:2.8-14.el7 will be updated
    ---> Package freetype.x86_64 0:2.8-14.el7_9.1 will be an update
    ---> Package freetype-devel.x86_64 0:2.8-14.el7 will be updated
    ---> Package freetype-devel.x86_64 0:2.8-14.el7_9.1 will be an update
    ---> Package galera.x86_64 0:25.3.29-1.rhel7.el7.centos will be updated
    ---> Package galera.x86_64 0:25.3.31-1.el7.centos will be an update
    ---> Package gcc.x86_64 0:4.8.5-39.el7 will be updated
    ---> Package gcc.x86_64 0:4.8.5-44.el7 will be an update
    ---> Package gcc-c++.x86_64 0:4.8.5-39.el7 will be updated
    ---> Package gcc-c++.x86_64 0:4.8.5-44.el7 will be an update
    ---> Package gd.x86_64 0:2.0.35-26.el7 will be updated
    ---> Package gd.x86_64 0:2.0.35-27.el7_9 will be an update
    ---> Package gd-devel.x86_64 0:2.0.35-26.el7 will be updated
    ---> Package gd-devel.x86_64 0:2.0.35-27.el7_9 will be an update
    ---> Package ghostscript.x86_64 0:9.25-2.el7_7.3 will be updated
    ---> Package ghostscript.x86_64 0:9.25-5.el7 will be an update
    ---> Package glib2.x86_64 0:2.56.1-5.el7 will be updated
    ---> Package glib2.x86_64 0:2.56.1-8.el7 will be an update
    ---> Package glib2-devel.x86_64 0:2.56.1-5.el7 will be updated
    ---> Package glib2-devel.x86_64 0:2.56.1-8.el7 will be an update
    ---> Package glibc.x86_64 0:2.17-307.el7.1 will be updated
    ---> Package glibc.x86_64 0:2.17-323.el7_9 will be an update
    ---> Package glibc-common.x86_64 0:2.17-307.el7.1 will be updated
    ---> Package glibc-common.x86_64 0:2.17-323.el7_9 will be an update
    ---> Package glibc-devel.x86_64 0:2.17-307.el7.1 will be updated
    ---> Package glibc-devel.x86_64 0:2.17-323.el7_9 will be an update
    ---> Package glibc-headers.x86_64 0:2.17-307.el7.1 will be updated
    ---> Package glibc-headers.x86_64 0:2.17-323.el7_9 will be an update
    ---> Package graphviz.x86_64 0:2.30.1-21.el7 will be updated
    ---> Package graphviz.x86_64 0:2.30.1-22.el7 will be an update
    ---> Package gssproxy.x86_64 0:0.7.0-28.el7 will be updated
    ---> Package gssproxy.x86_64 0:0.7.0-29.el7 will be an update
    ---> Package gtk-update-icon-cache.x86_64 0:3.22.30-5.el7 will be updated
    ---> Package gtk-update-icon-cache.x86_64 0:3.22.30-6.el7 will be an update
    ---> Package hunspell.x86_64 0:1.3.2-15.el7 will be updated
    ---> Package hunspell.x86_64 0:1.3.2-16.el7 will be an update
    ---> Package hwdata.x86_64 0:0.252-9.5.el7 will be updated
    ---> Package hwdata.x86_64 0:0.252-9.7.el7 will be an update
    ---> Package initscripts.x86_64 0:9.49.49-1.el7 will be updated
    ---> Package initscripts.x86_64 0:9.49.53-1.el7_9.1 will be an update
    ---> Package iproute.x86_64 0:4.11.0-25.el7_7.2 will be updated
    ---> Package iproute.x86_64 0:4.11.0-30.el7 will be an update
    ---> Package iptables.x86_64 0:1.4.21-34.el7 will be updated
    ---> Package iptables.x86_64 0:1.4.21-35.el7 will be an update
    ---> Package iptables-devel.x86_64 0:1.4.21-34.el7 will be updated
    ---> Package iptables-devel.x86_64 0:1.4.21-35.el7 will be an update
    ---> Package iptables-services.x86_64 0:1.4.21-34.el7 will be updated
    ---> Package iptables-services.x86_64 0:1.4.21-35.el7 will be an update
    ---> Package iptables-utils.x86_64 0:1.4.21-34.el7 will be updated
    ---> Package iptables-utils.x86_64 0:1.4.21-35.el7 will be an update
    ---> Package iwl7260-firmware.noarch 0:25.30.13.0-76.el7 will be updated
    ---> Package iwl7260-firmware.noarch 0:25.30.13.0-80.el7_9 will be an update
    ---> Package kernel.x86_64 0:3.10.0-1160.15.2.el7 will be installed
    ---> Package kernel-devel.x86_64 0:3.10.0-1160.15.2.el7 will be installed
    ---> Package kernel-headers.x86_64 0:3.10.0-1127.18.2.el7 will be updated
    ---> Package kernel-headers.x86_64 0:3.10.0-1160.15.2.el7 will be an update
    ---> Package kernel-tools.x86_64 0:3.10.0-1127.18.2.el7 will be updated
    ---> Package kernel-tools.x86_64 0:3.10.0-1160.15.2.el7 will be an update
    ---> Package kernel-tools-libs.x86_64 0:3.10.0-1127.18.2.el7 will be updated
    ---> Package kernel-tools-libs.x86_64 0:3.10.0-1160.15.2.el7 will be an update
    ---> Package kexec-tools.x86_64 0:2.0.15-43.el7 will be updated
    ---> Package kexec-tools.x86_64 0:2.0.15-51.el7_9.1 will be an update
    ---> Package kpartx.x86_64 0:0.4.9-131.el7 will be updated
    ---> Package kpartx.x86_64 0:0.4.9-134.el7_9 will be an update
    ---> Package krb5-devel.x86_64 0:1.15.1-46.el7 will be updated
    ---> Package krb5-devel.x86_64 0:1.15.1-50.el7 will be an update
    ---> Package krb5-libs.x86_64 0:1.15.1-46.el7 will be updated
    ---> Package krb5-libs.x86_64 0:1.15.1-50.el7 will be an update
    ---> Package libX11.x86_64 0:1.6.7-2.el7 will be updated
    ---> Package libX11.x86_64 0:1.6.7-3.el7_9 will be an update
    ---> Package libX11-common.noarch 0:1.6.7-2.el7 will be updated
    ---> Package libX11-common.noarch 0:1.6.7-3.el7_9 will be an update
    ---> Package libX11-devel.x86_64 0:1.6.7-2.el7 will be updated
    ---> Package libX11-devel.x86_64 0:1.6.7-3.el7_9 will be an update
    ---> Package libblkid.x86_64 0:2.23.2-63.el7 will be updated
    ---> Package libblkid.x86_64 0:2.23.2-65.el7_9.1 will be an update
    ---> Package libcom_err.x86_64 0:1.42.9-17.el7 will be updated
    ---> Package libcom_err.x86_64 0:1.42.9-19.el7 will be an update
    ---> Package libcom_err-devel.x86_64 0:1.42.9-17.el7 will be updated
    ---> Package libcom_err-devel.x86_64 0:1.42.9-19.el7 will be an update
    ---> Package libcroco.x86_64 0:0.6.12-4.el7 will be updated
    ---> Package libcroco.x86_64 0:0.6.12-6.el7_9 will be an update
    ---> Package libcurl.x86_64 0:7.29.0-57.el7_8.1 will be updated
    ---> Package libcurl.x86_64 0:7.29.0-59.el7_9.1 will be an update
    ---> Package libcurl-devel.x86_64 0:7.29.0-57.el7_8.1 will be updated
    ---> Package libcurl-devel.x86_64 0:7.29.0-59.el7_9.1 will be an update
    ---> Package libgcc.x86_64 0:4.8.5-39.el7 will be updated
    ---> Package libgcc.x86_64 0:4.8.5-44.el7 will be an update
    ---> Package libgomp.x86_64 0:4.8.5-39.el7 will be updated
    ---> Package libgomp.x86_64 0:4.8.5-44.el7 will be an update
    ---> Package libgs.x86_64 0:9.25-2.el7_7.3 will be updated
    ---> Package libgs.x86_64 0:9.25-5.el7 will be an update
    ---> Package libgs-devel.x86_64 0:9.25-2.el7_7.3 will be updated
    ---> Package libgs-devel.x86_64 0:9.25-5.el7 will be an update
    ---> Package libibverbs.x86_64 0:22.4-4.el7_8 will be updated
    ---> Package libibverbs.x86_64 0:22.4-5.el7 will be an update
    ---> Package libkadm5.x86_64 0:1.15.1-46.el7 will be updated
    ---> Package libkadm5.x86_64 0:1.15.1-50.el7 will be an update
    ---> Package libmount.x86_64 0:2.23.2-63.el7 will be updated
    ---> Package libmount.x86_64 0:2.23.2-65.el7_9.1 will be an update
    ---> Package libpaper.x86_64 0:1.1.24-8.el7.remi will be updated
    ---> Package libpaper.x86_64 0:1.1.24-9.el7 will be an update
    ---> Package libpng.x86_64 2:1.5.13-7.el7_2 will be updated
    ---> Package libpng.x86_64 2:1.5.13-8.el7 will be an update
    ---> Package libpng-devel.x86_64 2:1.5.13-7.el7_2 will be updated
    ---> Package libpng-devel.x86_64 2:1.5.13-8.el7 will be an update
    ---> Package librdmacm.x86_64 0:22.4-4.el7_8 will be updated
    ---> Package librdmacm.x86_64 0:22.4-5.el7 will be an update
    ---> Package libsmartcols.x86_64 0:2.23.2-63.el7 will be updated
    ---> Package libsmartcols.x86_64 0:2.23.2-65.el7_9.1 will be an update
    ---> Package libss.x86_64 0:1.42.9-17.el7 will be updated
    ---> Package libss.x86_64 0:1.42.9-19.el7 will be an update
    ---> Package libssh2.x86_64 0:1.8.0-3.el7 will be updated
    ---> Package libssh2.x86_64 0:1.8.0-4.el7 will be an update
    ---> Package libstdc++.x86_64 0:4.8.5-39.el7 will be updated
    ---> Package libstdc++.x86_64 0:4.8.5-44.el7 will be an update
    ---> Package libstdc++-devel.x86_64 0:4.8.5-39.el7 will be updated
    ---> Package libstdc++-devel.x86_64 0:4.8.5-44.el7 will be an update
    ---> Package libteam.x86_64 0:1.29-1.el7 will be updated
    ---> Package libteam.x86_64 0:1.29-3.el7 will be an update
    ---> Package libtiff.x86_64 0:4.0.3-32.el7 will be updated
    ---> Package libtiff.x86_64 0:4.0.3-35.el7 will be an update
    ---> Package libtiff-devel.x86_64 0:4.0.3-32.el7 will be updated
    ---> Package libtiff-devel.x86_64 0:4.0.3-35.el7 will be an update
    ---> Package libuuid.x86_64 0:2.23.2-63.el7 will be updated
    ---> Package libuuid.x86_64 0:2.23.2-65.el7_9.1 will be an update
    ---> Package libuuid-devel.x86_64 0:2.23.2-63.el7 will be updated
    ---> Package libuuid-devel.x86_64 0:2.23.2-65.el7_9.1 will be an update
    ---> Package libuv.x86_64 1:1.38.0-2.el7 will be updated
    ---> Package libuv.x86_64 1:1.41.0-1.el7 will be an update
    ---> Package libvpx.x86_64 0:1.3.0-5.el7_0 will be updated
    ---> Package libvpx.x86_64 0:1.3.0-8.el7 will be an update
    ---> Package libvpx-devel.x86_64 0:1.3.0-5.el7_0 will be updated
    ---> Package libvpx-devel.x86_64 0:1.3.0-8.el7 will be an update
    ---> Package libwmf-lite.x86_64 0:0.2.8.4-41.el7_1 will be updated
    ---> Package libwmf-lite.x86_64 0:0.2.8.4-44.el7 will be an update
    ---> Package libxml2.x86_64 0:2.9.1-6.el7.4 will be updated
    ---> Package libxml2.x86_64 0:2.9.1-6.el7.5 will be an update
    ---> Package libxml2-devel.x86_64 0:2.9.1-6.el7.4 will be updated
    ---> Package libxml2-devel.x86_64 0:2.9.1-6.el7.5 will be an update
    ---> Package libxml2-python.x86_64 0:2.9.1-6.el7.4 will be updated
    ---> Package libxml2-python.x86_64 0:2.9.1-6.el7.5 will be an update
    ---> Package libxslt.x86_64 0:1.1.28-5.el7 will be updated
    ---> Package libxslt.x86_64 0:1.1.28-6.el7 will be an update
    ---> Package libxslt-devel.x86_64 0:1.1.28-5.el7 will be updated
    ---> Package libxslt-devel.x86_64 0:1.1.28-6.el7 will be an update
    ---> Package linux-firmware.noarch 0:20191203-76.gite8a0f4c.el7 will be updated
    ---> Package linux-firmware.noarch 0:20200421-80.git78c0348.el7_9 will be an update
    ---> Package lshw.x86_64 0:B.02.18-14.el7 will be updated
    ---> Package lshw.x86_64 0:B.02.18-17.el7 will be an update
    ---> Package mesa-khr-devel.x86_64 0:18.3.4-7.el7_8.1 will be updated
    ---> Package mesa-khr-devel.x86_64 0:18.3.4-12.el7_9 will be an update
    ---> Package mesa-libEGL.x86_64 0:18.3.4-7.el7_8.1 will be updated
    ---> Package mesa-libEGL.x86_64 0:18.3.4-12.el7_9 will be an update
    ---> Package mesa-libGL.x86_64 0:18.3.4-7.el7_8.1 will be updated
    ---> Package mesa-libGL.x86_64 0:18.3.4-12.el7_9 will be an update
    ---> Package mesa-libGL-devel.x86_64 0:18.3.4-7.el7_8.1 will be updated
    ---> Package mesa-libGL-devel.x86_64 0:18.3.4-12.el7_9 will be an update
    ---> Package mesa-libgbm.x86_64 0:18.3.4-7.el7_8.1 will be updated
    ---> Package mesa-libgbm.x86_64 0:18.3.4-12.el7_9 will be an update
    ---> Package mesa-libglapi.x86_64 0:18.3.4-7.el7_8.1 will be updated
    ---> Package mesa-libglapi.x86_64 0:18.3.4-12.el7_9 will be an update
    ---> Package microcode_ctl.x86_64 2:2.1-61.10.el7_8 will be updated
    ---> Package microcode_ctl.x86_64 2:2.1-73.8.el7_9 will be an update
    ---> Package net-snmp.x86_64 1:5.7.2-48.el7_8.1 will be updated
    ---> Package net-snmp.x86_64 1:5.7.2-49.el7_9.1 will be an update
    ---> Package net-snmp-agent-libs.x86_64 1:5.7.2-48.el7_8.1 will be updated
    ---> Package net-snmp-agent-libs.x86_64 1:5.7.2-49.el7_9.1 will be an update
    ---> Package net-snmp-devel.x86_64 1:5.7.2-48.el7_8.1 will be updated
    ---> Package net-snmp-devel.x86_64 1:5.7.2-49.el7_9.1 will be an update
    ---> Package net-snmp-libs.x86_64 1:5.7.2-48.el7_8.1 will be updated
    ---> Package net-snmp-libs.x86_64 1:5.7.2-49.el7_9.1 will be an update
    ---> Package net-snmp-utils.x86_64 1:5.7.2-48.el7_8.1 will be updated
    ---> Package net-snmp-utils.x86_64 1:5.7.2-49.el7_9.1 will be an update
    ---> Package nfs-utils.x86_64 1:1.3.0-0.66.el7_8 will be updated
    ---> Package nfs-utils.x86_64 1:1.3.0-0.68.el7 will be an update
    ---> Package nspr.x86_64 0:4.21.0-1.el7 will be updated
    ---> Package nspr.x86_64 0:4.25.0-2.el7_9 will be an update
    ---> Package nss.x86_64 0:3.44.0-7.el7_7 will be updated
    ---> Package nss.x86_64 0:3.53.1-3.el7_9 will be an update
    ---> Package nss-softokn.x86_64 0:3.44.0-8.el7_7 will be updated
    ---> Package nss-softokn.x86_64 0:3.53.1-6.el7_9 will be an update
    ---> Package nss-softokn-freebl.x86_64 0:3.44.0-8.el7_7 will be updated
    ---> Package nss-softokn-freebl.x86_64 0:3.53.1-6.el7_9 will be an update
    ---> Package nss-sysinit.x86_64 0:3.44.0-7.el7_7 will be updated
    ---> Package nss-sysinit.x86_64 0:3.53.1-3.el7_9 will be an update
    ---> Package nss-tools.x86_64 0:3.44.0-7.el7_7 will be updated
    ---> Package nss-tools.x86_64 0:3.53.1-3.el7_9 will be an update
    ---> Package nss-util.x86_64 0:3.44.0-4.el7_7 will be updated
    ---> Package nss-util.x86_64 0:3.53.1-1.el7_9 will be an update
    ---> Package openldap.x86_64 0:2.4.44-21.el7_6 will be updated
    ---> Package openldap.x86_64 0:2.4.44-22.el7 will be an update
    ---> Package openldap-devel.x86_64 0:2.4.44-21.el7_6 will be updated
    ---> Package openldap-devel.x86_64 0:2.4.44-22.el7 will be an update
    ---> Package openssl.x86_64 1:1.0.2k-19.el7 will be updated
    ---> Package openssl.x86_64 1:1.0.2k-21.el7_9 will be an update
    ---> Package openssl-devel.x86_64 1:1.0.2k-19.el7 will be updated
    ---> Package openssl-devel.x86_64 1:1.0.2k-21.el7_9 will be an update
    ---> Package openssl-libs.x86_64 1:1.0.2k-19.el7 will be updated
    ---> Package openssl-libs.x86_64 1:1.0.2k-21.el7_9 will be an update
    ---> Package percona-release.noarch 0:1.0-13 will be updated
    ---> Package percona-release.noarch 0:1.0-26 will be an update
    ---> Package perl.x86_64 4:5.16.3-295.el7 will be updated
    ---> Package perl.x86_64 4:5.16.3-299.el7_9 will be an update
    ---> Package perl-ExtUtils-Embed.noarch 0:1.30-295.el7 will be updated
    ---> Package perl-ExtUtils-Embed.noarch 0:1.30-299.el7_9 will be an update
    ---> Package perl-ExtUtils-Install.noarch 0:1.58-295.el7 will be updated
    ---> Package perl-ExtUtils-Install.noarch 0:1.58-299.el7_9 will be an update
    ---> Package perl-Pod-Escapes.noarch 1:1.04-295.el7 will be updated
    ---> Package perl-Pod-Escapes.noarch 1:1.04-299.el7_9 will be an update
    ---> Package perl-devel.x86_64 4:5.16.3-295.el7 will be updated
    ---> Package perl-devel.x86_64 4:5.16.3-299.el7_9 will be an update
    ---> Package perl-libs.x86_64 4:5.16.3-295.el7 will be updated
    ---> Package perl-libs.x86_64 4:5.16.3-299.el7_9 will be an update
    ---> Package perl-macros.x86_64 4:5.16.3-295.el7 will be updated
    ---> Package perl-macros.x86_64 4:5.16.3-299.el7_9 will be an update
    ---> Package procps-ng.x86_64 0:3.3.10-27.el7 will be updated
    ---> Package procps-ng.x86_64 0:3.3.10-28.el7 will be an update
    ---> Package python.x86_64 0:2.7.5-88.el7 will be updated
    ---> Package python.x86_64 0:2.7.5-90.el7 will be an update
    ---> Package python-devel.x86_64 0:2.7.5-88.el7 will be updated
    ---> Package python-devel.x86_64 0:2.7.5-90.el7 will be an update
    ---> Package python-libs.x86_64 0:2.7.5-88.el7 will be updated
    ---> Package python-libs.x86_64 0:2.7.5-90.el7 will be an update
    ---> Package python-magic.noarch 0:5.11-36.el7 will be updated
    ---> Package python-magic.noarch 0:5.11-37.el7 will be an update
    ---> Package python-perf.x86_64 0:3.10.0-1127.18.2.el7 will be updated
    ---> Package python-perf.x86_64 0:3.10.0-1160.15.2.el7 will be an update
    ---> Package python-requests.noarch 0:2.6.0-9.el7_8 will be updated
    ---> Package python-requests.noarch 0:2.6.0-10.el7 will be an update
    --> Processing Dependency: python-urllib3 >= 1.10.2-1 for package: python-requests-2.6.0-10.el7.noarch
    ---> Package python-rpm-macros.noarch 0:3-32.el7 will be updated
    ---> Package python-rpm-macros.noarch 0:3-34.el7 will be an update
    ---> Package python-srpm-macros.noarch 0:3-32.el7 will be updated
    ---> Package python-srpm-macros.noarch 0:3-34.el7 will be an update
    ---> Package python2-rpm-macros.noarch 0:3-32.el7 will be updated
    ---> Package python2-rpm-macros.noarch 0:3-34.el7 will be an update
    ---> Package python3.x86_64 0:3.6.8-13.el7 will be updated
    ---> Package python3.x86_64 0:3.6.8-18.el7 will be an update
    ---> Package python3-libs.x86_64 0:3.6.8-13.el7 will be updated
    ---> Package python3-libs.x86_64 0:3.6.8-18.el7 will be an update
    ---> Package python3-pip.noarch 0:9.0.3-7.el7_7 will be updated
    ---> Package python3-pip.noarch 0:9.0.3-8.el7 will be an update
    ---> Package rdma-core.x86_64 0:22.4-4.el7_8 will be updated
    ---> Package rdma-core.x86_64 0:22.4-5.el7 will be an update
    ---> Package rpm.x86_64 0:4.11.3-43.el7 will be updated
    ---> Package rpm.x86_64 0:4.11.3-45.el7 will be an update
    ---> Package rpm-build-libs.x86_64 0:4.11.3-43.el7 will be updated
    ---> Package rpm-build-libs.x86_64 0:4.11.3-45.el7 will be an update
    ---> Package rpm-devel.x86_64 0:4.11.3-43.el7 will be updated
    ---> Package rpm-devel.x86_64 0:4.11.3-45.el7 will be an update
    ---> Package rpm-libs.x86_64 0:4.11.3-43.el7 will be updated
    ---> Package rpm-libs.x86_64 0:4.11.3-45.el7 will be an update
    ---> Package rpm-python.x86_64 0:4.11.3-43.el7 will be updated
    ---> Package rpm-python.x86_64 0:4.11.3-45.el7 will be an update
    ---> Package rsyslog.x86_64 0:8.24.0-52.el7_8.2 will be updated
    ---> Package rsyslog.x86_64 0:8.24.0-57.el7_9 will be an update
    ---> Package screen.x86_64 0:4.1.0-0.25.20120314git3c2946.el7 will be updated
    ---> Package screen.x86_64 0:4.1.0-0.26.20120314git3c2946.el7 will be an update
    ---> Package sed.x86_64 0:4.2.2-6.el7 will be updated
    ---> Package sed.x86_64 0:4.2.2-7.el7 will be an update
    ---> Package selinux-policy.noarch 0:3.13.1-266.el7_8.1 will be updated
    ---> Package selinux-policy.noarch 0:3.13.1-268.el7_9.2 will be an update
    ---> Package selinux-policy-targeted.noarch 0:3.13.1-266.el7_8.1 will be updated
    ---> Package selinux-policy-targeted.noarch 0:3.13.1-268.el7_9.2 will be an update
    ---> Package strace.x86_64 0:4.24-4.el7 will be updated
    ---> Package strace.x86_64 0:4.24-6.el7 will be an update
    ---> Package subversion.x86_64 0:1.7.14-14.el7 will be updated
    ---> Package subversion.x86_64 0:1.7.14-16.el7 will be an update
    ---> Package subversion-libs.x86_64 0:1.7.14-14.el7 will be updated
    ---> Package subversion-libs.x86_64 0:1.7.14-16.el7 will be an update
    ---> Package sudo.x86_64 0:1.8.23-9.el7 will be updated
    ---> Package sudo.x86_64 0:1.8.23-10.el7_9.1 will be an update
    ---> Package systemd.x86_64 0:219-73.el7_8.9 will be updated
    ---> Package systemd.x86_64 0:219-78.el7_9.3 will be an update
    ---> Package systemd-devel.x86_64 0:219-73.el7_8.9 will be updated
    ---> Package systemd-devel.x86_64 0:219-78.el7_9.3 will be an update
    ---> Package systemd-libs.x86_64 0:219-73.el7_8.9 will be updated
    ---> Package systemd-libs.x86_64 0:219-78.el7_9.3 will be an update
    ---> Package systemd-sysv.x86_64 0:219-73.el7_8.9 will be updated
    ---> Package systemd-sysv.x86_64 0:219-78.el7_9.3 will be an update
    ---> Package systemtap-sdt-devel.x86_64 0:4.0-11.el7 will be updated
    ---> Package systemtap-sdt-devel.x86_64 0:4.0-13.el7 will be an update
    ---> Package teamd.x86_64 0:1.29-1.el7 will be updated
    ---> Package teamd.x86_64 0:1.29-3.el7 will be an update
    ---> Package tuned.noarch 0:2.11.0-8.el7 will be updated
    ---> Package tuned.noarch 0:2.11.0-11.el7_9 will be an update
    ---> Package tzdata.noarch 0:2020a-1.el7 will be updated
    ---> Package tzdata.noarch 0:2021a-1.el7 will be an update
    ---> Package util-linux.x86_64 0:2.23.2-63.el7 will be updated
    ---> Package util-linux.x86_64 0:2.23.2-65.el7_9.1 will be an update
    ---> Package vim-minimal.x86_64 2:7.4.629-6.el7 will be updated
    ---> Package vim-minimal.x86_64 2:7.4.629-8.el7_9 will be an update
    ---> Package xfsprogs.x86_64 0:4.5.0-20.el7 will be updated
    ---> Package xfsprogs.x86_64 0:4.5.0-22.el7 will be an update
    ---> Package yum.noarch 0:3.4.3-167.el7.centos will be updated
    ---> Package yum.noarch 0:3.4.3-168.el7.centos will be an update
    ---> Package zlib.x86_64 0:1.2.7-18.el7 will be updated
    ---> Package zlib.x86_64 0:1.2.7-19.el7_9 will be an update
    ---> Package zlib-devel.x86_64 0:1.2.7-18.el7 will be updated
    ---> Package zlib-devel.x86_64 0:1.2.7-19.el7_9 will be an update
    ---> Package zstd.x86_64 0:1.4.5-3.el7 will be updated
    ---> Package zstd.x86_64 0:1.4.7-1.el7 will be an update
    ---> Package kernel.x86_64 0:3.10.0-1062.1.1.el7 will be erased
    ---> Package kernel-devel.x86_64 0:3.10.0-1062.1.1.el7 will be erased
    11:32 PM
    What output do you get for these commands
    pip list -o
    yum list updates cloud-init
    yum list updates cloud-init --disableplugin=versionlock,priorities --disableexcludes=main
    yum list updates python-requests
    yum list updates python-requests --disableplugin=versionlock,priorities --disableexcludes=main
  7. fly
    fly Member
    109
    16
    9:32 AM
    This:
    pip list -o
    DEPRECATION: Python 2.7 reached the end of its life on January 1st, 2020. Please upgrade your Python as Python 2.7 is no longer maintained. pip 21.0 will drop support for Python 2.7 in January 2021. More details about Python 2 support in pip can be found at https://pip.pypa.io/en/latest/development/release-process/#python-2-support
    Package                      Version  Latest   Type
    awscli                       1.18.183 1.19.22  wheel
    Babel                        0.9.6    2.9.0    wheel
    backports.ssl-match-hostname 3.5.0.1  3.7.0.1  sdist
    botocore                     1.19.23  1.20.22  wheel
    chardet                      2.2.1    4.0.0    wheel
    colorama                     0.3.9    0.4.4    wheel
    configobj                    4.7.2    5.0.6    sdist
    decorator                    3.4.0    4.4.2    wheel
    docutils                     0.14     0.16     wheel
    futures                      3.2.0    3.3.0    wheel
    Glances                      3.1.4.1  3.1.6.2  sdist
    iniparse                     0.4      0.5      wheel
    ipaddress                    1.0.16   1.0.23   wheel
    IPy                          0.75     1.1      sdist
    Jinja2                       2.7.2    2.11.3   wheel
    jmespath                     0.9.3    0.10.0   wheel
    jsonpatch                    1.2      1.31     wheel
    jsonpointer                  1.9      2.0      wheel
    kitchen                      1.1.1    1.2.6    sdist
    MarkupSafe                   0.11     1.1.1    wheel
    pip                          20.2.2   20.3.4   wheel
    prettytable                  0.7.2    1.0.1    wheel
    psutil                       5.7.2    5.8.0    wheel
    py-cpuinfo                   5.0.0    7.0.0    sdist
    pyasn1                       0.4.4    0.4.8    wheel
    pycurl                       7.19.0   7.43.0.5 sdist
    pygobject                    3.22.0   3.36.1   sdist
    pyparsing                    1.5.6    2.4.7    wheel
    pyserial                     2.6      3.5      wheel
    python-dateutil              2.7.3    2.8.1    wheel
    pyudev                       0.15     0.22.0   sdist
    pyxattr                      0.5.1    0.6.1    sdist
    PyYAML                       3.10     5.4.1    wheel
    requests                     2.6.0    2.25.1   wheel
    rsa                          3.4.2    4.7.1    sdist
    s3transfer                   0.3.3    0.3.4    wheel
    six                          1.9.0    1.15.0   wheel
    urlgrabber                   3.10     4.1.0    sdist
    urllib3                      1.25.10  1.26.3   wheel
    WARNING: You are using pip version 20.2.2; however, version 20.3.4 is available.
    You should consider upgrading via the '/usr/bin/python2 -m pip install --upgrade pip' command.
    # yum list updates cloud-init
    Updated Packages
    cloud-init.x86_64        19.4-7.el7.centos.3        updates
    # yum list updates cloud-init --disableplugin=versionlock,priorities --disableexcludes=main
    Updated Packages
    # yum list updates python-requests
     * epel: mirror.genesisadaptive.com
    Updated Packages
    python-requests.noarch        2.6.0-10.el7        base
    # yum list updates python-requests --disableplugin=versionlock,priorities --disableexcludes=main
    Updated Packages
    11:32 PM
    what if you do this before trying yum update again
    sudo yes | pip uninstall urllib3
    yum -y reinstall python-urllib3
    yum -y update
  9. fly
    fly Member
    109
    16
    9:32 AM
    I was able to get it removed:
    # sudo yes | pip uninstall urllib3
    Found existing installation: urllib3 1.25.10
    Uninstalling urllib3-1.25.10:
      Would remove:
        /usr/lib/python2.7/site-packages/urllib3-1.25.10.dist-info/*
        /usr/lib/python2.7/site-packages/urllib3/*
    Proceed (y/n)?   Successfully uninstalled urllib3-1.25.10
    But not reinstalled:
    # yum -y reinstall python-urllib3
    No Match for argument: python-urllib3
    Error: Nothing to do
    If needed:
    # yum search urllib3
     * base: mirror.centos.org
     * centos-sclo-rh: mirror.centos.org
     * centos-sclo-sclo: mirror.centos.org
     * extras: mirror.centos.org
     * updates: mirror.centos.org
    =========================================================================================================== N/S matched: urllib3 ============================================================================================================
    python34-urllib3.noarch : Python 3.6 HTTP library with thread-safe connection pooling and file post
    python36-urllib3.noarch : Python 3.6 HTTP library with thread-safe connection pooling and file post
    rh-mongodb36-python-urllib3.noarch : Python HTTP library with thread-safe connection pooling and file post
    rh-python38-python-urllib3.noarch : Python HTTP library with thread-safe connection pooling and file post
    sclo-python27-python-urllib3.noarch : Python HTTP library with thread-safe connection pooling and file post
    sclo-python35-python-urllib3.noarch : Python HTTP library with thread-safe connection pooling and file post
    11:32 PM
    oh i locked that package from memory, so try
    yum -y reinstall python-urllib3 --disableplugin=versionlock,priorities --disableexcludes=main
  11. fly
    fly Member
    109
    16
    9:32 AM
    Still nothing
    # yum -y reinstall python-urllib3 --disableplugin=versionlock,priorities --disableexcludes=main
    epel/x86_64/metalink        |  13 kB  00:00:00
    base        | 3.6 kB  00:00:00
    centos-sclo-rh        | 3.0 kB  00:00:00
    centos-sclo-sclo        | 3.0 kB  00:00:00
    epel        | 4.7 kB  00:00:00
    extras        | 2.9 kB  00:00:00
    mariadb        | 2.9 kB  00:00:00
    newrelic        | 2.5 kB  00:00:00
    newrelic-infra/x86_64/signature        |  836 B  00:00:00
    newrelic-infra/x86_64/signature        | 2.5 kB  00:00:01 !!!
    percona-release-x86_64        | 2.9 kB  00:00:00
    rpmforge        | 1.9 kB  00:00:00
    updates        | 2.9 kB  00:00:00
    (1/2): epel/x86_64/updateinfo        | 1.0 MB  00:00:00
    (2/2): epel/x86_64/primary_db        | 6.9 MB  00:00:00
    Package(s) python-urllib3 available, but not installed.
    11:32 PM
    what about
    yum list python-urllib3 --disableplugin=versionlock,priorities --disableexcludes=main
  13. fly
    fly Member
    109
    16
    9:32 AM
    # yum list python-urllib3 --disableplugin=versionlock,priorities --disableexcludes=main
    Available Packages
    python-urllib3.noarch        1.10.2-7.el7        base
  14. fly
    fly Member
    109
    16
    9:32 AM
    Any other ideas?
    11:32 PM
    try just install instead of reinstall
    yum -y install python-urllib3 --disableplugin=versionlock,priorities --disableexcludes=main
  16. fly
    fly Member
    109
    16
    9:32 AM
    Oh yes! That worked.
    IIRC, when I orginally created this thread, the urllib3 thing caused an issue with AWS cloud-init. Should that be a problem now? I'm assuming no, since its still installed.
    11:32 PM
    IIRC your original problem was Centmin Mod installs removed cloud-init yum package as a consequence of remove/updating python-urllib3 and using pip urllib3. But I updated Centmin Mod to not remove cloud-init. So in theory it should work still. Probably best to spin up a test AWS EC2 instance and install Centmin Mod and see if restore works.
