MariaDB Problems and can't sign in to
Discussion in 'Nginx, PHP-FPM & MariaDB MySQL' started by R0rke, Sep 25, 2017.
  1. R0rke
    R0rke Member
    127
    Iran
    12:20 AM
    1.11.1
    10.1
    • CentOS Version: 7.4(Core)
    • Nginx Version Installed: I don't check it
    • PHP Version Installed: after install, i just update my curl to latest version and I upgrade my PHP to 7.1.9
    • MariaDB MySQL Version Installed: 10.1.26
    • When was last time updated Centmin Mod codebase? : recently its just a fresh install for my friend and latest version
    • Persistent Config:
    cat: /etc/centminmod/custom_config.inc: No such file or directory
    when I trying to connect :
    ERROR 1045 (28000): Access denied for user 'root'@'localhost' (using password: YES)
    sometimes: I have an error with not found : /var/lib/mysql/mysql.sock
    also, i try with the mysql_secure install but connections refusing.
    38,037
    8,356
    6:20 PM
    • how did you update to latest version of curl ?
    • is that SSH command line based connection attempt to mysql ? what was exact command you are using to connect ?
    • was mysql login ever working since initial install ? was the login issue only just a recent issue ?
    • did you successfully run mysql_secure and change mysql root password ? if you did you need to update /root/.my.cnf with updated password too as per FAQ item 35 to be able to run SSH command line connections to mysql without needing to enter mysql username and password
  3. R0rke
    R0rke Member
    127
    Iran
    12:20 AM
    1.11.1
    10.1
    • for updating Curl :
      Wget https://curl.haxx.se/download/curl-7.55.1.tar.gz
      cd /curlfolder
      ./configure
      make
      make install
    • im trying to connect via ssh as root :
      mysql -u root -pThePassword
    • Actually, I don't know because after a fresh install I just simply update the curl and just then try to connect to MySQL but boom. at the end no any success connection to MYSQL
    • I Use mysql_secure but its refusing connection at all .
    Recently I just reloaded my Server os I try to install centminmod Again.
    I did it before I don't have any problems like this dunno just what happened
    38,037
    8,356
    6:20 PM
    Then most likely curl upgrade that way has broken something in the system as that isn't proper way to update curl. You should of probably done it via addons/customcurl.sh https://community.centminmod.com/threads/centmin-mod-curl-7-48-custom-rpms.3703/
    Try just fresh centmin mod install and NOT doing any curl updates and NOT doing mysql_secure run and see if you can connect - the mysql root password is same one listed in /root/.my.cnf for out of box installs
  5. R0rke
    R0rke Member
    127
    Iran
    12:20 AM
    1.11.1
    10.1
    well I got this errors now when I installing new centminmod on fresh os
  6. R0rke
    R0rke Member
    127
    Iran
    12:20 AM
    1.11.1
    10.1
    also problem with running MYSQL MariaDB :|
     service mysqld restart
    Redirecting to /bin/systemctl restart mysqld.service
    Job for mariadb.service failed because the control process exited with error code. See "systemctl status mariadb.service" and "journalctl -xe" for details.
    [01:58][[email protected] ~]# systemctl status mariadb.service
    ● mariadb.service - MariaDB database server
       Loaded: loaded (/usr/lib/systemd/system/mariadb.service; enabled; vendor preset: disabled)
      Drop-In: /etc/systemd/system/mariadb.service.d
               └─migrated-from-my.cnf-settings.conf, openfileslimit.conf, protecthome.conf
       Active: failed (Result: exit-code) since Tue 2017-09-26 01:58:26 +0330; 2min 32s ago
      Process: 12961 ExecStart=/usr/sbin/mysqld $MYSQLD_OPTS $_WSREP_NEW_CLUSTER $_WSREP_START_POSITION (code=exited, status=1/FAILURE)
      Process: 12724 ExecStartPre=/bin/sh -c [ ! -e /usr/bin/galera_recovery ] && VAR= ||   VAR=`/usr/bin/galera_recovery`; [ $? -eq 0 ]   && systemctl set-environment _WSREP_START_POSITION=$VAR || exit 1 (code=exited, status=0/SUCCESS)
      Process: 12722 ExecStartPre=/bin/sh -c systemctl unset-environment _WSREP_START_POSITION (code=exited, status=0/SUCCESS)
     Main PID: 12961 (code=exited, status=1/FAILURE)
       Status: "MariaDB server is down"
    Sep 26 01:58:26 localhost.net mysqld[12961]: 2017-09-26 01:58:26 7f8f1b544900  InnoDB: Error: ... 13
    Sep 26 01:58:26 localhost.net mysqld[12961]: 2017-09-26  1:58:26 140252615559424 [ERROR] Plugi...or.
    Sep 26 01:58:26 localhost.net mysqld[12961]: 2017-09-26  1:58:26 140252615559424 [ERROR] Plugi...ed.
    Sep 26 01:58:26 localhost.net mysqld[12961]: 2017-09-26  1:58:26 140252615559424 [Note] Plugin...ed.
    Sep 26 01:58:26 localhost.net mysqld[12961]: 2017-09-26  1:58:26 140252615559424 [ERROR] Unkno...oDB
    Sep 26 01:58:26 localhost.net mysqld[12961]: 2017-09-26  1:58:26 140252615559424 [ERROR] Aborting
    Sep 26 01:58:26 localhost.net systemd[1]: mariadb.service: main process exited, code=exited, s...URE
    Sep 26 01:58:26 localhost.net systemd[1]: Failed to start MariaDB database server.
    Sep 26 01:58:26 localhost.net systemd[1]: Unit mariadb.service entered failed state.
    Sep 26 01:58:26 localhost.net systemd[1]: mariadb.service failed.
    Hint: Some lines were ellipsized, use -l to show in full.
    AND
    [[email protected] centminmod]# journalctl -xe"
    Sep 26 01:52:04 localhost.net polkitd[625]: Registered Authentication Agent for unix-process:12050:4616622 (system bus name :1.124 [/usr/bin/pkttyage
    Sep 26 01:52:04 localhost.net systemd[1]: Starting MariaDB database server...
    -- Subject: Unit mariadb.service has begun start-up
    -- Defined-By: systemd
    -- Unit mariadb.service has begun starting up.
    Sep 26 01:52:05 localhost.net mysqld[12305]: 2017-09-26  1:52:05 140304384760064 [Note] /usr/sbin/mysqld (mysqld 10.1.27-MariaDB) starting as process
    Sep 26 01:52:05 localhost.net mysqld[12305]: 2017-09-26  1:52:05 140304384760064 [Note] InnoDB: Using mutexes to ref count buffer pool pages
    Sep 26 01:52:05 localhost.net mysqld[12305]: 2017-09-26  1:52:05 140304384760064 [Note] InnoDB: The InnoDB memory heap is disabled
    Sep 26 01:52:05 localhost.net mysqld[12305]: 2017-09-26  1:52:05 140304384760064 [Note] InnoDB: Mutexes and rw_locks use GCC atomic builtins
    Sep 26 01:52:05 localhost.net mysqld[12305]: 2017-09-26  1:52:05 140304384760064 [Note] InnoDB: GCC builtin __atomic_thread_fence() is used for memor
    Sep 26 01:52:05 localhost.net mysqld[12305]: 2017-09-26  1:52:05 140304384760064 [Note] InnoDB: Compressed tables use zlib 1.2.7
    Sep 26 01:52:05 localhost.net mysqld[12305]: 2017-09-26  1:52:05 140304384760064 [Note] InnoDB: Using Linux native AIO
    Sep 26 01:52:05 localhost.net mysqld[12305]: 2017-09-26  1:52:05 140304384760064 [Note] InnoDB: Using SSE crc32 instructions
    Sep 26 01:52:05 localhost.net mysqld[12305]: 2017-09-26  1:52:05 140304384760064 [ERROR] mysqld: Can't create/write to file '/home/mysqltmp/ib43Vp8Q'
    Sep 26 01:52:05 localhost.net mysqld[12305]: 2017-09-26 01:52:05 7f9b29039900  InnoDB: Error: unable to create temporary file; errno: 13
    Sep 26 01:52:05 localhost.net mysqld[12305]: 2017-09-26  1:52:05 140304384760064 [ERROR] Plugin 'InnoDB' init function returned error.
    Sep 26 01:52:05 localhost.net mysqld[12305]: 2017-09-26  1:52:05 140304384760064 [ERROR] Plugin 'InnoDB' registration as a STORAGE ENGINE failed.
    Sep 26 01:52:05 localhost.net mysqld[12305]: 2017-09-26  1:52:05 140304384760064 [Note] Plugin 'FEEDBACK' is disabled.
    Sep 26 01:52:05 localhost.net mysqld[12305]: 2017-09-26  1:52:05 140304384760064 [ERROR] Unknown/unsupported storage engine: InnoDB
    Sep 26 01:52:05 localhost.net mysqld[12305]: 2017-09-26  1:52:05 140304384760064 [ERROR] Aborting
    Sep 26 01:52:05 localhost.net systemd[1]: mariadb.service: main process exited, code=exited, status=1/FAILURE
    Sep 26 01:52:05 localhost.net systemd[1]: Failed to start MariaDB database server.
    -- Subject: Unit mariadb.service has failed
    -- Unit mariadb.service has failed.
    -- The result is failed.
    Sep 26 01:52:05 localhost.net systemd[1]: Unit mariadb.service entered failed state.
    Sep 26 01:52:05 localhost.net systemd[1]: mariadb.service failed.
    Sep 26 01:52:05 localhost.net polkitd[625]: Unregistered Authentication Agent for unix-process:12050:4616622 (system bus name :1.124, object path /or
    38,037
    8,356
    6:20 PM
    Might need your install log and info to troubleshoot.
    Example list /root/centminlogs files in date ascending order and grep for install.log
  8. R0rke
    R0rke Member
    127
    Iran
    12:20 AM
    1.11.1
    10.1
    you can check the first post about the version of os or ...
    I'm using VMware
    its fresh install
    method : ./centmin.sh install
    Unfortunately, I can't post logs on pastebin because its size
    I just post here u can check it by nodepad++
    38,037
    8,356
    6:20 PM
    Centmin Mod 123.09beta01 official way to install as per install page https://centminmod.com/install.html is via installers curl command so wonder if that is the problem.
    I just tested fresh 123.09beta01 install and MariaDB 10.1.27 works fine and can no log via mysql root user.
    38,037
    8,356
    6:20 PM
    from your log seems mysql failed to restart after updating max open files limit so installed fine just couldn't restart so latter mysql root password setup would probably of failed to run
    Update MariaDB 10 setting for ProtectHome=false
    setup /var/log/mysqld.log
    -rw-------. 1 mysql mysql 0 Sep 26 01:32 /var/log/mysqld.log
    Initial Install: Update MariaDB 10 setting for LimitNOFILE=262144
    systemctl restart mysql.service
                 __  __               _         ____   ____    _   ___
    so a mysql server restart and then check the logs for clues
    mysqlrestart
    or
    then check logs
    journalctl -u mariadb --no-pager
    • Useful Useful x 1
  11. R0rke
    R0rke Member
    127
    Iran
    12:20 AM
    1.11.1
    10.1
    38,037
    8,356
    6:20 PM
    that shouldn't happen
    Sep 26 01:52:05 localhost.net mysqld[12305]: 2017-09-26  1:52:05 140304384760064 [ERROR] mysqld: Can't create/write to file '/home/mysqltmp/ib43Vp8Q' (Errcode: 13 "Permission denied")
    as centmin mod creates a /etc/systemd/system/mariadb.service.d/protecthome.conf with contents to disable that protection and allow /home/mysqltmp
    [Service]
    ProtectSystem=false
    ProtectHome=false
    what does contents of your /etc/systemd/system/mariadb.service.d/protecthome.conf contain ?
    cat /etc/systemd/system/mariadb.service.d/protecthome.conf
  13. R0rke
    R0rke Member
    127
    Iran
    12:20 AM
    1.11.1
    10.1
    [Service]
    ProtectSystem=false
    ProtectHome=false
    38,037
    8,356
    6:20 PM
    That looks right so shouldn't cause the error you are experiencing hmmm
    38,037
    8,356
    6:20 PM
    For now for temp workaround you can comment out tmpdir option in /etc/my.cnf and restart MariaDB MySQL and set the mysql root password.
