Install MariaDB Problem with Starting MariaDB
Discussion in 'Install & Upgrades or Pre-Install Questions' started by R0rke, Dec 22, 2018.
  1. R0rke
    R0rke Member
    128
    Iran
    9:04 AM
    1.11.1
    10.1
    • Nginx Version Installed: nginx/1.15.7
    • PHP Version Installed: PHP 5.6.39
    • MariaDB MySQL Version Installed: can't detect
    • When was last time updated Centmin Mod code base? : its latest fresh install
    • Persistent Config: there is no config done by me.
    cat: /etc/centminmod/custom_config.inc: No such file or directory
    I installed Centminmod latest version via git on fresh Centos 7.
    and this happened after install
    also MariaDB not working
     Unit mariadb.service has begun starting up.
    Dec 21 17:07:59 local.host mysqld[32248]: 2018-12-21 17:07:59 140559429667072 [Note] /usr/sbin/mysqld (mysqld 10.1.37-MariaDB) starting as process 32
    Dec 21 17:07:59 local.host mysqld[32248]: 2018-12-21 17:07:59 140559429667072 [Note] InnoDB: Using mutexes to ref count buffer pool pages
    Dec 21 17:07:59 local.host mysqld[32248]: 2018-12-21 17:07:59 140559429667072 [Note] InnoDB: The InnoDB memory heap is disabled
    Dec 21 17:07:59 local.host mysqld[32248]: 2018-12-21 17:07:59 140559429667072 [Note] InnoDB: Mutexes and rw_locks use GCC atomic builtins
    Dec 21 17:07:59 local.host mysqld[32248]: 2018-12-21 17:07:59 140559429667072 [Note] InnoDB: GCC builtin __atomic_thread_fence() is used for memory b
    Dec 21 17:07:59 local.host mysqld[32248]: 2018-12-21 17:07:59 140559429667072 [Note] InnoDB: Compressed tables use zlib 1.2.7
    Dec 21 17:07:59 local.host mysqld[32248]: 2018-12-21 17:07:59 140559429667072 [Note] InnoDB: Using Linux native AIO
    Dec 21 17:07:59 local.host mysqld[32248]: 2018-12-21 17:07:59 140559429667072 [Note] InnoDB: Using SSE crc32 instructions
    Dec 21 17:07:59 local.host mysqld[32248]: 2018-12-21 17:07:59 140559429667072 [ERROR] mysqld: Can't create/write to file '/home/mysqltmp/ib6swavP' (E
    Dec 21 17:07:59 local.host mysqld[32248]: 2018-12-21 17:07:59 7fd68ae00900  InnoDB: Error: unable to create temporary file; errno: 13
    Dec 21 17:07:59 local.host mysqld[32248]: 2018-12-21 17:07:59 140559429667072 [ERROR] Plugin 'InnoDB' init function returned error.
    Dec 21 17:07:59 local.host mysqld[32248]: 2018-12-21 17:07:59 140559429667072 [ERROR] Plugin 'InnoDB' registration as a STORAGE ENGINE failed.
    Dec 21 17:07:59 local.host mysqld[32248]: 2018-12-21 17:07:59 140559429667072 [Note] Plugin 'FEEDBACK' is disabled.
    Dec 21 17:07:59 local.host mysqld[32248]: 2018-12-21 17:07:59 140559429667072 [ERROR] Unknown/unsupported storage engine: InnoDB
    Dec 21 17:07:59 local.host mysqld[32248]: 2018-12-21 17:07:59 140559429667072 [ERROR] Aborting
    Dec 21 17:07:59 local.host systemd[1]: mariadb.service: main process exited, code=exited, status=1/FAILURE
    Dec 21 17:07:59 local.host systemd[1]: Failed to start MariaDB 10.1.37 database server.
    -- Subject: Unit mariadb.service has failed
    -- Defined-By: systemd
    -- Unit mariadb.service has failed.
    38,678
    8,540
    2:04 AM
    seems related to
    for 100% sure method use the installers these days
    if there isn't any data on newly installed 123.09beta01, easiest way is just reload fresh CentOS 7 OS, and re-install fresh centminmod 123.09beta01
    or you need to troubleshoot this install
    Example for 123.09beta01 and newer list /root/centminlogs files in date ascending order and grep for installer_*
    ls -lahrt /root/centminlogs | grep installer_*
    example output returns install log at /root/centminlogs both a the full log and minimal log (smaller in size with some stuff filtered out)
    -rw-r--r-- 1 root root 4.3M Jul 12 09:06 installer_120718-083445.log
    -rw-r--r-- 1 root root 826K Jul 12 10:20 installer_120718-083445_minimal.log
    Example for 123.08stable list /root/centminlogs files in date ascending order and grep for install.log
    for 123.08stable
    cat /root/centminlogs/installer_120718-083445_minimal.log
  3. R0rke
    R0rke Member
    128
    Iran
    9:04 AM
    1.11.1
    10.1
    I do reinstall after a fresh installation of centos, but still same issue.
    i can't use installers cause i do some custom changes before install.
    i send logs in a private message to u. I'm not able to post them on Pastebin cause of limitation on free users or guests on their website.
    38,678
    8,540
    2:04 AM
