vBulletin Problem With Redirect loop
Discussion in 'Forum software usage' started by Cr0w, Apr 5, 2015.
  1. Cr0w
    Cr0w Member
    165
    9
    Iran
    7:22 PM
    1.9.x
    5.5
    i remove this lines
     location ~* \.(php)$
                    fastcgi_index index.php;
                    fastcgi_pass unix:/var/run/php5-fpm.sock;
                    include /usr/local/nginx/conf/fastcgi_params;
                    fastcgi_param SCRIPT_FILENAME $document_root$fastcgi_script_nam$
                    fastcgi_param   SCRIPT_NAME        $fastcgi_script_name;
                    fastcgi_param PATH_TRANSLATED $document_root$fastcgi_script_nam$
    but nothing changed :((
  2. Cr0w
    Cr0w Member
    165
    9
    Iran
    7:22 PM
    1.9.x
    5.5
    include /usr/local/nginx/conf/php.conf; remove this line ?
  3. Cr0w
    Cr0w Member
    165
    9
    Iran
    7:22 PM
    1.9.x
    5.5
    http://0up.ir/do.php?imgf=d_6fb8b.png
    see this image
    1:52 AM
    remove that and you break all PHP functionality in Centmin Mod Nginx.
    1:52 AM
  6. Cr0w
    Cr0w Member
    165
    9
    Iran
    7:22 PM
    1.9.x
    5.5
    if Without modify .htaccess file on apache
    there is nginx.conf on nginx webserver
    then why have problem with redirect ? :|
    1:52 AM
    pretty sure is you misconfigured and doubled up with inclusion of /home/nginx/domains/forums.mashtyha.com/public/nginx.conf
    the last output you posted of /home/nginx/domains/forums.mashtyha.com/public/nginx.conf was within nano/text editor so cut of word wrapped text so can you post output via cat command
    cat /home/nginx/domains/forums.mashtyha.com/public/nginx.conf
    honestly I don't provide free support for such things but curious what you have set
    1:52 AM
    same with yourdomain.com.conf use cat to post output to make sure you don't cut of non-wrapped lines in text editor
    cat /usr/local/nginx/conf/conf.d/forums.mashtyha.com.conf
