vBulletin Problem With Redirect loop
Discussion in 'Forum software usage' started by Cr0w, Apr 5, 2015.
  1. Cr0w
    Cr0w Member
    165
    9
    Iran
    9:31 PM
    1.9.x
    5.5
    hi , i installed VBulltien 4.4.2 Patch Level 4 + Dragon Byte Seo 1.4.7
    And i have some redirect problems in some pages
    in DBSEO I have re write urls see below
    showgroups.php ==> staff.html
    click here and see the redirect loop error
    http://forums.mashtyha.com/staff.html
    55,983
    4:01 AM
    If you're rewriting to .html extension files so that PHP services .html files, you need to tell Nginx not to serve .html files (performance wise not ideal so generally best to not rewrite to using .html extensions for php files).
    But if you don't care for slower performance and need to use .html rewrites, then tell Nginx not to serve .html files by editing /usr/local/nginx/conf/staticfiles.conf (can use command short cut to access file = statfilesinc)
    and comment out this part for .html file location match with hash in front of the lines
        #location ~* \.(html|htm|txt)$ {
            #add_header Pragma public;
            #add_header Cache-Control "public, must-revalidate, proxy-revalidate";
            #access_log off;
            #expires 1d;
            #break;
    then restart Nginx server
    service nginx restart
    or use command shortcut
    ngxrestart
  3. Cr0w
    Cr0w Member
    165
    9
    Iran
    9:31 PM
    1.9.x
    5.5
    thanks , you are my man :D . so you suggest not redirect php files to html ?
    55,983
    4:01 AM
    Yeah .html should be left to nginx serving. I'd redirect to friendly urls without any extension at all. Just look at this very forum's urls
  5. Cr0w
    Cr0w Member
    165
    9
    Iran
    9:31 PM
    1.9.x
    5.5
    should i add # to comment those rules ?
    if i do that whats happening is't bad options ?
    i want to change php urls to html :D thats seo suggest from Dragon Byte community
  6. Cr0w
    Cr0w Member
    165
    9
    Iran
    9:31 PM
    1.9.x
    5.5
    55,983
    4:01 AM
    up to you whether to use .html, I personally never rewrite to .html extension files for performance reasons
    what's your full Nginx vhost domain.com.conf contents ? post in CODE tags
  8. Cr0w
    Cr0w Member
    165
    9
    Iran
    9:31 PM
    1.9.x
    5.5
    #server {
    #            listen   80;
    #            server_name forums.mashtyha.com;
    #            return 301 $scheme://www.forums.mashtyha.com$request_uri;
      server_name forums.mashtyha.com ;
    include /usr/local/nginx/conf/pagespeedstatslog.conf;
      # ssi  on;
      access_log /home/nginx/domains/forums.mashtyha.com/log/access.log combined bu$
      error_log /home/nginx/domains/forums.mashtyha.com/log/error.log;
      root /home/nginx/domains/forums.mashtyha.com/public;
      #autoindex  on;
      #autoindex_localtime on;
        try_files $uri $uri/ /dbseo.php;
      include /home/nginx/domains/forums.mashtyha.com/public/nginx.conf;
      rewrite ^/((archive/)?(.*\.php(/.*)?))$ /dbseo.php break;
      if (!-e $request_filename){
      rewrite ^(.+)$ /dbseo.php break;
    here is ;)
    why ? :S
    55,983
    4:01 AM
    why, because my number 1 priority is performance and speed so don't need PHP handling .html files.
    There's your problem similar to Nginx and vBulletin vBSEO
    should be
       try_files $uri $uri/ /dbseo.php?$args;
  10. Cr0w
    Cr0w Member
    165
    9
    Iran
    9:31 PM
    1.9.x
    5.5
    vbseo developers has stoped Supporting that plugin , all webmasters was finding for any plugins for seo
    i found good one named DBSEO ;)
    Im don't want change php to html for optimzing speed ! i just wanna make change at my ugly urls ;)
    nothing was changed the problem still there :D
    The page isn't redirecting properly ,
    55,983
    4:01 AM
    did you restart nginx after changes i suggested ?
  12. Cr0w
    Cr0w Member
    165
    9
    Iran
    9:31 PM
    1.9.x
    5.5
    55,983
    4:01 AM
  14. Cr0w
    Cr0w Member
    165
    9
    Iran
    9:31 PM
    1.9.x
    5.5
    i know but maybe you can convert those codes or maybe found some rules to add on nginx
    55,983
    4:01 AM
    nginx rewrites generally left to end user as Centmin Mod is provided as is so best to ask DBSEO authors as well :)
    checking against vbseo version you might be missing this line though
    location ~ /(.*\.php)$ {
    rewrite ^/(.*)$ /dbseo.php last;
    but definitely check with DBSEO developers
  16. Cr0w
    Cr0w Member
    165
    9
    Iran
    9:31 PM
    1.9.x
    5.5
    they can't give service to our country :(
    nothing was changed still have error :((
    maybe the problem is from fastcgi_params
    55,983
    4:01 AM
    oh i just noticed you have
    what's inside /home/nginx/domains/forums.mashtyha.com/public/nginx.conf ? ( wrap in CODE tags)
  18. Cr0w
    Cr0w Member
    165
    9
    Iran
    9:31 PM
    1.9.x
    5.5
    location ~* \.(png|jpg|jpeg|gif|ico)$
                    expires 30d;
                    log_not_found off;
            location ~ ^((?!dbseo).)*\.php$
            location ~* \.(php)$
                    fastcgi_index index.php;
                    fastcgi_pass unix:/var/run/php5-fpm.sock;
                    include /usr/local/nginx/conf/fastcgi_params;
                    fastcgi_param SCRIPT_FILENAME $document_root$fastcgi_script_nam$
                    fastcgi_param   SCRIPT_NAME        $fastcgi_script_name;
                    fastcgi_param PATH_TRANSLATED $document_root$fastcgi_script_nam$
    location ~ (admincp/|dbseocp/|modcp/|cron|mobiquo|forumrunner|api\.php|reviewpo$
    this
    55,983
    4:01 AM
    there's your problem you duplicated the php.conf include file which is Centmin Mod's default php settings for each Nginx vhost
    remove this part in /home/nginx/domains/forums.mashtyha.com/public/nginx.conf
    55,983
    4:01 AM
    FYI, you never have to set or add php location matches to Nginx vhosts via Centmin Mod as the php.conf include takes care of it
