PHP-FPM Problem with PHP-FPM multiple pool
Discussion in 'Nginx, PHP-FPM & MariaDB MySQL' started by vahn18, Nov 7, 2014.
  1. vahn18
    vahn18 New Member
    9:06 PM
    Hi, I've been using Centminmod for my production server for a month now.
    It's been running flawlessly. All the tutorials are great in directing me what to do.
    I'm a beginner btw =)
    Currently my server is running PHP-FPM on port 9000 (default settings) and everything's working fine.
    The server is going to host like 8 vhosts. And I wanted to create a separated pool for some of my vhosts.
    So I'm trying to add a new pool using UNIX socket. But I got no luck.
    I keep geeting
    [error] 28271#0: *5 FastCGI sent in stderr: "Primary script unknown" while reading response header from upstream, ...
    here's my setup:
    in conf/php-blogs.conf (copied from php.conf because it's working fine for the default pools)
    location ~ \.php$ {
        try_files $uri =404;
        fastcgi_split_path_info ^(.+\.php)(/.+)$;
        #fastcgi_pass   127.0.0.1:9001;
        fastcgi_pass   unix:/tmp/phpfpm_blogs.sock;
        fastcgi_index  index.php;
        #fastcgi_param  SCRIPT_FILENAME  $document_root$fastcgi_script_name;
        fastcgi_param  SCRIPT_FILENAME    $request_filename;
    in conf/phpfpmd/pool_blogs.conf (copied from phpmyadmin, also because it works just fine)
    [blogs]
    user = blogs
    group = nginx
    ;listen = 127.0.0.1:9001
    listen = /tmp/phpfpm_blogs.sock
    listen.owner=blogs
    listen.group=nginx
    pm = ondemand
    pm.max_children = 5
    pm.start_servers = 1
    pm.min_spare_servers = 1
    pm.max_spare_servers = 3
    pm.max_requests = 1000
    pm.process_idle_timeout = 1800s;
    rlimit_files = 65536
    rlimit_core = 0
    ;request_terminate_timeout = 0
    ;request_slowlog_timeout = 0
    slowlog = /var/log/php-fpm/blogs-slow.log
    security.limit_extensions = .php .php3 .php4 .php5
    ;php_admin_value[open_basedir] = /usr/local/nginx/html/1234_mysqladmin1234:/tmp
    php_flag[display_errors] = off
    php_admin_value[error_log] = /var/log/php-fpm/blogs-error.log
    php_admin_flag[log_errors] = on
    php_admin_value[memory_limit] = 128M
    php_admin_value[max_execution_time] = 1800
    php_admin_value[post_max_size] = 32M
    php_admin_value[upload_max_filesize] = 32M
    and in my vhost.conf
      # ssi  on;
      access_log /home/nginx/domains/domain.com/log/access.log combined buffer=32k;
      try_files            $uri $uri/ /index.php;
      include /usr/local/nginx/conf/php_blogs.conf;
    serving static contents work just fine.
    but when i access any php file, i just keep getting that STDERR: "Primary script unknown"
    and changin UNIX socket to port 9001 also gives me this error...
    Where did I go wrong? =(
    55,796
    12,271
    9:06 PM
  3. vahn18
    vahn18 New Member
    9:06 PM
    Thank you for that reference link =)
