Install Problem with NTPD after install
Discussion in 'Install & Upgrades or Pre-Install Questions' started by denellum, Jan 26, 2017.
  1. denellum
    denellum Member
    88
    22
    Dallas
    1:29 AM
    1.13.8
    10.1.29
    Having issues with NTPD :
    [root@WEB01 log]# ntpdate 3.centos.pool.ntp.org
    25 Jan 17:45:26 ntpdate[2721]: no server suitable for synchronization found
    [root@WEB01 log]# ping 3.centos.pool.ntp.org
    PING 3.centos.pool.ntp.org (64.113.32.5) 56(84) bytes of data.
    64 bytes from nist.netservicesgroup.com (64.113.32.5): icmp_seq=1 ttl=55 time=88.7 ms
    64 bytes from nist.netservicesgroup.com (64.113.32.5): icmp_seq=3 ttl=55 time=88.0 ms
    64 bytes from nist.netservicesgroup.com (64.113.32.5): icmp_seq=4 ttl=55 time=88.0 ms
    64 bytes from nist.netservicesgroup.com (64.113.32.5): icmp_seq=5 ttl=55 time=87.6 ms
    64 bytes from nist.netservicesgroup.com (64.113.32.5): icmp_seq=6 ttl=55 time=88.0 ms
    ^C
    --- 3.centos.pool.ntp.org ping statistics ---
    6 packets transmitted, 5 received, 16% packet loss, time 5006ms
    rtt min/avg/max/mdev = 87.687/88.117/88.716/0.465 ms
    My time is all messed up :/
  2. denellum
    denellum Member
    88
    22
    Dallas
    1:29 AM
    1.13.8
    10.1.29
    An update :
    [root@WEB01 ~]# ntpdate -d pool.ntp.org
    25 Jan 18:06:27 ntpdate[2750]: ntpdate 4.2.6p5@1.2349-o Mon Nov 14 18:25:09 UTC 2016 (1)
    Looking for host pool.ntp.org and service ntp
    host found : 104.131.53.252
    transmit(104.131.53.252)
    transmit(148.167.132.201)
    transmit(45.127.112.2)
    transmit(208.82.104.205)
    104.131.53.252: Server dropped: no data
    148.167.132.201: Server dropped: no data
    45.127.112.2: Server dropped: no data
    208.82.104.205: Server dropped: no data
    server 104.131.53.252, port 123
    stratum 0, precision 0, leap 00, trust 000
    refid [104.131.53.252], delay 0.00000, dispersion 64.00000
    transmitted 4, in filter 4
    reference time: 00000000.00000000 Sun, Dec 31 1899 18:00:00.000
    originate timestamp: 00000000.00000000 Sun, Dec 31 1899 18:00:00.000
    transmit timestamp: dc33bc09.96c666a3 Wed, Jan 25 2017 18:06:33.588
    filter delay: 0.00000 0.00000 0.00000 0.00000
    filter offset: 0.000000 0.000000 0.000000 0.000000
    offset 0.000000
    server 148.167.132.201, port 123
    refid [148.167.132.201], delay 0.00000, dispersion 64.00000
    transmit timestamp: dc33bc09.c9f8d93c Wed, Jan 25 2017 18:06:33.788
    offset 0.000000
    server 45.127.112.2, port 123
    refid [45.127.112.2], delay 0.00000, dispersion 64.00000
    transmit timestamp: dc33bc09.fd2cab14 Wed, Jan 25 2017 18:06:33.988
    offset 0.000000
    server 208.82.104.205, port 123
    refid [208.82.104.205], delay 0.00000, dispersion 64.00000
    transmit timestamp: dc33bc0a.3060f32c Wed, Jan 25 2017 18:06:34.188
    offset 0.000000
    25 Jan 18:06:36 ntpdate[2750]: no server suitable for synchronization found
    44,691
    10,193
    4:29 PM
    Fresh install that has never had working system time ? Is CSF Firewalll running ? It should of whitelisted required ports.
    Example list /root/centminlogs files in date ascending order and grep for install.log
  4. denellum
    denellum Member
    88
    22
    Dallas
    1:29 AM
    1.13.8
    10.1.29
    Just tested it some more (was worn out, spent all day in the hospital so i passed out)
    Alright the culprit seems to be Voxility since ntpd ports are blocked... i have another external ip.(using buyvm with a DDOS ip) what would you recommend me to do to get this working?
    44,691
    10,193
    4:29 PM
    who is your webhost ? if ntpd ports are blocked you'd have issues with ntpd so probably need to find another web host
  6. denellum
    denellum Member
    88
    22
    Dallas
    1:29 AM
    1.13.8
    10.1.29
    I am using buyvm, it works NOT on the DDOS protected IP... they use Voxility, their reponse was :
    But, on my regular IP it works fine...
    What i suggested as "fix" was :
    What do you think Eva? I don't HAVE to use the DDOS ip, but i like the option.
    44,691
    10,193
    4:29 PM
    ah yes with buyvm and ddos protected ips, you want the main server ip being non-ddos protected ip and setup site domain vhosts on ddos protected ip
    in centmin mod 123.09beta01, there's an option for SECOND_IP variable in nginx vhost add routine at centminmod/nginx_addvhost.inc at 123.09beta01 · centminmod/centminmod · GitHub
    # Support secondary dedicated IP configuration for centmin mod
    # nginx vhost generator, so out of the box, new nginx vhosts
    # generated will use the defined SECOND_IP=111.222.333.444 where
    # the IP is a secondary IP addressed added to the server.
    # You define SECOND_IP variable is centmin mod persistent config
    # file outlined at http://centminmod.com/upgrade.html#persistent
    # you manually creat the file at /etc/centminmod/custom_config.inc
    # and add SECOND_IP=yoursecondary_IPaddress variable to it which
    # will be registered with nginx vhost generator routine so that
    # any new nginx vhosts created via centmin.sh menu option 2 or
    # /usr/bin/nv or centmin.sh menu option 22, will have pre-defined
    # SECOND_IP ip address set in the nginx vhost's listen directive
    if [[ -z "$SECOND_IP" ]]; then
      DEDI_IP=""
      DEDI_LISTEN=""
    elif [[ "$SECOND_IP" ]]; then
      DEDI_IP=$(echo $(echo ${SECOND_IP}:))
      DEDI_LISTEN="listen   ${DEDI_IP}80;"
    fi
    if if your ddos protected ip = 1.2.3.4, set in persistent config /etc/centminmod/custom_config.inc
    SECOND_IP=1.2.3.4
    so when you create new nginx vhost via centmin.sh menu option 2 etc, all vhosts use listen 1.2.3.4:80 or 1.2.3.4:443 for vhost directives :)
  8. denellum
    denellum Member
    88
    22
    Dallas
    1:29 AM
    1.13.8
    10.1.29
    So would it be best to delete all previous vhosts and start over once i make this change? that wont be too hard as there are only 2 hosts.
    44,691
    10,193
    4:29 PM
  10. denellum
    denellum Member
    88
    22
    Dallas
    1:29 AM
    1.13.8
    10.1.29
    I just got one reimaging it all (nothing important was on it)... now the last think. I created the custom config file and added the letsencrypt+secondip... i go to create a vhost and say add letsencrypt, its reverting to the main IP, not the DDOS.
    44,691
    10,193
    4:29 PM
    The resulting nginx vhost is? Or the reported domain dns ip displayed? Did you update your domain dns to ddos ip/second ip?
  12. denellum
    denellum Member
    88
    22
    Dallas
    1:29 AM
    1.13.8
    10.1.29
    Like this :
    Domain.com is a top level domain
    your server IP address: nonDDOSip
    current DNS A record IP address for domain.com is: DDOSip
    current DNS A record IP address for www.domain.com is: DDOSip
    44,691
    10,193
    4:29 PM
    Ah probably a bug will have to check it out after i wake up
  14. denellum
    denellum Member
    88
    22
    Dallas
    1:29 AM
    1.13.8
    10.1.29
    Get some rest bud :) ill be here to test for you when you're ready :)
    44,691
    10,193
    4:29 PM
  16. denellum
    denellum Member
    88
    22
    Dallas
    1:29 AM
    1.13.8
    10.1.29
    Works like a charm! On pay day ill subscribe to be a premium member :) Thank you thank you thank you!
    44,691
    10,193
    4:29 PM
    excellent great to hear it's working and much appreciated :D
  18. denellum
    denellum Member
    88
    22
    Dallas
    1:29 AM
    1.13.8
    10.1.29
    eva, something i noticed today... randomly i am getting an "ping: sendmsg: opperation not permitted" when trying to ping an internal IP with my host. all ive done is update centminmod as patches come out :/
    edit : this is only effecting my centminmod servers. disabling csf makes it work.
    44,691
    10,193
    4:29 PM
    Centmin Mod CSF Firewall rate limits pings so probably could be related to that.
    in /etc/csf/csf.conf config file
    # Allow incoming PING
    ICMP_IN = "1"
    # Set the per IP address incoming ICMP packet rate
    # To disable rate limiting set to "0"
    ICMP_IN_RATE = "1/s"
    # Allow outgoing PING
    ICMP_OUT = "1"
    # Set the per IP address outgoing ICMP packet rate (hits per second allowed),
    # e.g. "1/s"
    ICMP_OUT_RATE = "0"
  20. denellum
    denellum Member
    88
    22
    Dallas
    1:29 AM
    1.13.8
    10.1.29
    It's not letting my databases connect either :/ even though i have in the /etc/csf/csf.allow :
    DBA :
    tcp|in|d=3306|s=WEB_INTERNAL_IP
    WEB :
    tcp|out|d=3306|d=DBA_INTERNAL_IP
    side note, if i disable: "csf -x" on the DBA side, everything works.
