Problem with MariaDB
Discussion in 'Bug Reports' started by denisyan, Nov 6, 2024.
  1. denisyan
    denisyan New Member
    7
    12:01 AM
    Hello! Did a fresh install in Alma and somehow MariaDB did not installed?
    I get Unit mariadb.service could not be found. How can i reinstall MariaDB?
    • CentOS Version: AlmaLinux OS 9.4 Minimal
    • Centmin Mod Version Installed: 131.00stable.b058
    • Nginx Version Installed: nginx/1.27.2 (061124-011312-almalinux9-kvm-4a3b366)
    • PHP Version Installed: PHP 8.3.13 (cli) (built: Nov 6 2024 01:35:41) (NTS)
    • MariaDB MySQL Version Installed:
      mysqladmin: connect to server at 'localhost' failed
      error: 'Can't connect to local server through socket '/var/lib/mysql/mysql.sock' (2)'
      Check that mariadbd is running and that the socket: '/var/lib/mysql/mysql.sock' exists!
    • When was last time updated Centmin Mod code base ? : Already up to date.
    • Persistent Config: LETSENCRYPT_DETECT='y'
  2. denisyan
    denisyan New Member
    7
    12:01 AM
    i guess i've messed up with Initial Centmin Mod installation needs to be done as full root user rather than as sudo user and centmin.sh shell based menu needs to be run as full root user., as i've installed cmm with sudo.
  3. denisyan
    denisyan New Member
    7
    12:01 AM
    Well, tried on a fresh install with root — same thing. MariaDB is not here.
    55,915
    12,281
    7:01 AM
  5. denisyan
    denisyan New Member
    7
    12:01 AM
  6. pamamolf
    4,101
    428
    12:01 AM
    Nginx-1.26.x
    Maybe such tests should be done when starting the installation of Centminmod as first step and try to adjust the mirrors if needed and if no working found to notify the user?
  7. denisyan
    denisyan New Member
    7
    12:01 AM
    Snippet of installer log with MariaDB errors. Strange that install failed, but installer keeps on going.
             __  __               _         ____   ____    _   ___     __
            |  \/  |  __ _  _ __ (_)  __ _ |  _ \ | __ )  / | / _ \   / /_
            | |\/| | / _` || '__|| | / _` || | | ||  _ \  | || | | | | '_ \
            | |  | || (_| || |   | || (_| || |_| || |_) | | || |_| |_| (_) |
            |_|  |_| \__,_||_|   |_| \__,_||____/ |____/  |_| \___/(_)\___/
              __   __                   ___              _          _  _
              \ \ / /_   _  _ __ ___   |_ _| _ __   ___ | |_  __ _ | || |
               \ V /| | | || '_ ` _ \   | | | '_ \ / __|| __|/ _` || || |
                | | | |_| || | | | | |  | | | | | |\__ \| |_| (_| || || |
                |_|  \__,_||_| |_| |_| |___||_| |_||___/ \__|\__,_||_||_|
    MariaDB 10.6 YUM install...
                                    ____         _
                                   / ___|   ___ | |_
                                   \___ \  / _ \| __|
                                    ___) ||  __/| |_
                                   |____/  \___| \__|
                __     _            __                                  __
               / /___ | |_  ___    / /_ __ ___   _   _     ___  _ __   / _|
              / // _ \| __|/ __|  / /| '_ ` _ \ | | | |   / __|| '_ \ | |_
             / /|  __/| |_| (__  / / | | | | | || |_| | _| (__ | | | ||  _|
            /_/  \___| \__|\___|/_/  |_| |_| |_| \__, |(_)\___||_| |_||_|
                                                 |___/
    Copying MariaDB my-mdb10.cnf file to /etc/my.cnf
    Dependencies resolved.
     Package             Arch        Version                  Repository       Size
    Removing:
     mytop               noarch      1.7-24.b737f60.el9       @epel            67 k
    Removing unused dependencies:
     perl-DBD-MySQL      x86_64      4.050-13.el9             @appstream      364 k
     perl-DBI            x86_64      1.643-9.el9              @appstream      1.9 M
    Transaction Summary
    Remove  3 Packages
    Freed space: 2.3 M
    Running transaction check
    Transaction check succeeded.
    Running transaction test
    Transaction test succeeded.
    Running transaction
      Preparing        :                                                        1/1
      Erasing          : mytop-1.7-24.b737f60.el9.noarch                        1/3
      Erasing          : perl-DBD-MySQL-4.050-13.el9.x86_64                     2/3
      Erasing          : perl-DBI-1.643-9.el9.x86_64                            3/3
      Running scriptlet: perl-DBI-1.643-9.el9.x86_64                            3/3
      Verifying        : mytop-1.7-24.b737f60.el9.noarch                        1/3
      Verifying        : perl-DBD-MySQL-4.050-13.el9.x86_64                     2/3
      Verifying        : perl-DBI-1.643-9.el9.x86_64                            3/3
    Removed:
      mytop-1.7-24.b737f60.el9.noarch       perl-DBD-MySQL-4.050-13.el9.x86_64
    Complete!
    time yum -q -y install perl-DBI
    Installed:
    real    0m23.752s
    user    0m4.307s
    sys    0m0.722s
    [1;32;40mMariaDB 10.6.x YUM install...
    [m[1;32;40myum -q -y install MariaDB-client MariaDB-common MariaDB-devel MariaDB-server MariaDB-shared --disablerepo=epel
    Last metadata expiration check: 0:00:19 ago on Wed 06 Nov 2024 01:09:30 AM EST.
    Installing:
     MariaDB-client       x86_64    10.6.20-1.el9          mariadb            8.5 M
     MariaDB-common       x86_64    10.6.20-1.el9          mariadb             88 k
     MariaDB-devel        x86_64    10.6.20-1.el9          mariadb            7.9 M
     MariaDB-server       x86_64    10.6.20-1.el9          mariadb             18 M
     MariaDB-shared       x86_64    10.6.20-1.el9          mariadb            131 k
         replacing  mariadb-connector-c.x86_64 3.2.6-1.el9_0
         replacing  mariadb-connector-c-config.noarch 3.2.6-1.el9_0
    Installing dependencies:
     galera-4             x86_64    26.4.20-1.el9          mariadb            1.4 M
     perl-Sys-Hostname    x86_64    1.23-481.el9           appstream           16 k
     rsync                x86_64    3.3.0-1.el9            backports-rsync    413 k
    Installing weak dependencies:
     socat                x86_64    1.7.4.1-5.el9_4.2      appstream          299 k
    Transaction Summary
    Install  9 Packages
    Total download size: 36 M
    Downloading Packages:
    (1/9): perl-Sys-Hostname-1.23-481.el9.x86_64.rp 513 kB/s |  16 kB     00:00
    (2/9): socat-1.7.4.1-5.el9_4.2.x86_64.rpm       4.8 MB/s | 299 kB     00:00
    (3/9): rsync-3.3.0-1.el9.x86_64.rpm             1.3 MB/s | 413 kB     00:00
    (4/9): MariaDB-common-10.6.20-1.el9.x86_64.rpm   81 kB/s |  88 kB     00:01
    (5/9): MariaDB-client-10.6.20-1.el9.x86_64.rpm  5.1 MB/s | 8.5 MB     00:01
    (6/9): MariaDB-server-10.6.20-1.el9.x86_64.rpm   20 MB/s |  18 MB     00:00
    (7/9): MariaDB-shared-10.6.20-1.el9.x86_64.rpm  381 kB/s | 131 kB     00:00
    (8/9): galera-4-26.4.20-1.el9.x86_64.rpm        6.3 MB/s | 1.4 MB     00:00
    [MIRROR] MariaDB-devel-10.6.20-1.el9.x86_64.rpm: Curl error (28): Timeout was reached for https://fastmirror.pp.ua/mariadb/mariadb-10.6.20/yum/rhel/9/x86_64/rpms/MariaDB-devel-10.6.20-1.el9.x86_64.rpm [Failed to connect to fastmirror.pp.ua port 443: Connection timed out]
    [FAILED] MariaDB-devel-10.6.20-1.el9.x86_64.rpm: No more mirrors to try - All mirrors were already tried without success
    The downloaded packages were saved in cache until the next successful transaction.
    You can remove cached packages by executing 'yum clean packages'.
    Error: Error downloading packages:
      MariaDB-devel-10.6.20-1.el9.x86_64: Cannot download, all mirrors were already tried without success
    real    1m3.417s
    user    0m1.663s
    sys    0m0.320s
                __     _            __                                  __
                                                 |___/
                                          _           _                  _
      ___  ___   _ __ ___   _ __    __ _ | |_    ___ | |__    ___   ___ | | __ ___
     / __|/ _ \ | '_ ` _ \ | '_ \  / _` || __|  / __|| '_ \  / _ \ / __|| |/ // __|
    | (__| (_) || | | | | || |_) || (_| || |_  | (__ | | | ||  __/| (__ |   < \__ \
     \___|\___/ |_| |_| |_|| .__/  \__,_| \__|  \___||_| |_| \___| \___||_|\_\|___/
                           |_|
                       ____                      _   __  _
                      / ___|  _ __    ___   ___ (_) / _|(_)  ___
                      \___ \ | '_ \  / _ \ / __|| || |_ | | / __|
                       ___) || |_) ||  __/| (__ | ||  _|| || (__
                      |____/ | .__/  \___| \___||_||_|  |_| \___|
                             |_|
                __     _            __                                  __
                                                 |___/
                                      _   _                          _  _
        _ __ ___   _   _  ___   __ _ | | | |_  _ __ ___   _ __    __| |(_) _ __
       | '_ ` _ \ | | | |/ __| / _` || | | __|| '_ ` _ \ | '_ \  / _` || || '__|
       | | | | | || |_| |\__ \| (_| || | | |_ | | | | | || |_) || (_| || || |
       |_| |_| |_| \__, ||___/ \__, ||_|  \__||_| |_| |_|| .__/  \__,_||_||_|
                   |___/          |_|                    |_|
                                         _
                              ___   ___ | |_  _   _  _ __
                             / __| / _ \| __|| | | || '_ \
                             \__ \|  __/| |_ | |_| || |_) |
                             |___/ \___| \__| \__,_|| .__/
                                                    |_|
    setup /var/log/mysqld.log
    chown: invalid user: ‘mysql:mysql’
    -rw------- 1 root root 0 Nov  6 01:10 /var/log/mysqld.log
    systemctl restart mariadb.service
    Failed to restart mariadb.service: Unit mariadb.service not found.
    NotifyAccess=none
    ManagedOOMSwap=auto
    ManagedOOMMemoryPressure=auto
    ManagedOOMMemoryPressureLimit=0
    ManagedOOMPreference=none
    LimitNOFILE=1073741816
    LimitNOFILESoft=1073741816
    OOMScoreAdjust=0
                         ____   _                _
                        |  _ \ | | _   _   __ _ (_) _ __   ___
                        | |_) || || | | | / _` || || '_ \ / __|
                        |  __/ | || |_| || (_| || || | | |\__ \
                        |_|    |_| \__,_| \__, ||_||_| |_||___/
                                          |___/
    Installing MariaDB 10 plugins
    mysql -e "INSTALL SONAME 'metadata_lock_info';"
    /usr/local/src/centminmod/inc/mariadb_install106.inc: line 1181: mysql: command not found
    mysql -e "INSTALL SONAME 'query_cache_info';"
    /usr/local/src/centminmod/inc/mariadb_install106.inc: line 1183: mysql: command not found
    mysql -e "INSTALL SONAME 'query_response_time';"
    /usr/local/src/centminmod/inc/mariadb_install106.inc: line 1185: mysql: command not found
    mysql -t -e "SELECT * FROM mysql.plugin;"
    /usr/local/src/centminmod/inc/mariadb_install106.inc: line 1192: mysql: command not found
    mysql -t -e "SHOW PLUGINS;"
    /usr/local/src/centminmod/inc/mariadb_install106.inc: line 1194: mysql: command not found
    mysql -t -e "SHOW ENGINES;"
    /usr/local/src/centminmod/inc/mariadb_install106.inc: line 1196: mysql: command not found
    Installed:
    Last metadata expiration check: 0:00:04 ago on Wed 06 Nov 2024 01:10:54 AM EST.
     Package         Architecture   Version                 Repository         Size
    Installing:
     postfix         x86_64         2:3.5.9-24.el9          appstream         1.4 M
    Transaction Summary
    Install  1 Package
    Total download size: 1.4 M
    Installed size: 4.4 M
    postfix-3.5.9-24.el9.x86_64.rpm                  11 MB/s | 1.4 MB     00:00
    Total                                           2.1 MB/s | 1.4 MB     00:00
    Running transaction
      Preparing        :                                                        1/1
      Running scriptlet: postfix-2:3.5.9-24.el9.x86_64                          1/1
      Installing       : postfix-2:3.5.9-24.el9.x86_64                          1/1
      Verifying        : postfix-2:3.5.9-24.el9.x86_64                          1/1
    Installed:
    Complete!
    real    0m9.887s
    user    0m6.675s
    sys    0m1.395s
    Last metadata expiration check: 0:00:14 ago on Wed 06 Nov 2024 01:10:54 AM EST.
    Installing:
    Transaction Summary
    Install  4 Packages
    Total download size: 8.7 M
    (1/4): perl-Sys-Hostname-1.23-481.el9.x86_64.rp 507 kB/s |  16 kB     00:00
    (2/4): MariaDB-common-10.6.20-1.el9.x86_64.rpm   81 kB/s |  88 kB     00:01
    (3/4): MariaDB-client-10.6.20-1.el9.x86_64.rpm  5.1 MB/s | 8.5 MB     00:01
    [MIRROR] MariaDB-shared-10.6.20-1.el9.x86_64.rpm: Curl error (28): Timeout was reached for https://fastmirror.pp.ua/mariadb/mariadb-10.6.20/yum/rhel/9/x86_64/rpms/MariaDB-shared-10.6.20-1.el9.x86_64.rpm [Failed to connect to fastmirror.pp.ua port 443: Connection timed out]
    (4/4): MariaDB-shared-10.6.20-1.el9.x86_64.rpm  8.2 kB/s | 131 kB     00:15
    Total                                           542 kB/s | 8.7 MB     00:16
    Running transaction
      Preparing        :                                                        1/1
      Installing       : MariaDB-shared-10.6.20-1.el9.x86_64                    1/6
      Running scriptlet: MariaDB-shared-10.6.20-1.el9.x86_64                    1/6
      Installing       : MariaDB-common-10.6.20-1.el9.x86_64                    2/6
    warning: /etc/my.cnf created as /etc/my.cnf.rpmnew
      Installing       : perl-Sys-Hostname-1.23-481.el9.x86_64                  3/6
      Installing       : MariaDB-client-10.6.20-1.el9.x86_64                    4/6
      Obsoleting       : mariadb-connector-c-3.2.6-1.el9_0.x86_64               5/6
      Obsoleting       : mariadb-connector-c-config-3.2.6-1.el9_0.noarch        6/6
      Running scriptlet: mariadb-connector-c-config-3.2.6-1.el9_0.noarch        6/6
      Verifying        : perl-Sys-Hostname-1.23-481.el9.x86_64                  1/6
      Verifying        : MariaDB-client-10.6.20-1.el9.x86_64                    2/6
      Verifying        : MariaDB-common-10.6.20-1.el9.x86_64                    3/6
      Verifying        : MariaDB-shared-10.6.20-1.el9.x86_64                    4/6
      Verifying        : mariadb-connector-c-3.2.6-1.el9_0.x86_64               5/6
      Verifying        : mariadb-connector-c-config-3.2.6-1.el9_0.noarch        6/6
    Installed:
      MariaDB-client-10.6.20-1.el9.x86_64   MariaDB-common-10.6.20-1.el9.x86_64
      MariaDB-shared-10.6.20-1.el9.x86_64   perl-Sys-Hostname-1.23-481.el9.x86_64
    Complete!
    Creating /etc/logrotate.d/mysql file
    Creating /etc/logrotate.d/mysql-slowlog file
    /var/log/mysqld.log {
      create 600 mysql mysql
      dateext
      notifempty
      daily
      rotate 8
      missingok
      compress
      sharedscripts
      postrotate
      if test -x /usr/bin/mysqladmin && /usr/bin/mysqladmin ping &>/dev/null
      then
        env HOME=/root/ /usr/bin/mysql -e 'select @@global.long_query_time into @lqt_save; set global long_query_time=2000; select sleep(2); FLUSH LOGS; select sleep(2); set global long_query_time=@lqt_save;'
      fi
      endscript
    /var/lib/mysql/slowq.log {
      dateext
      notifempty
      daily
      rotate 8
      missingok
      compress
      sharedscripts
      postrotate
      # just if mysqld is really running
      then
        env HOME=/root/ /usr/bin/mysql -e 'select @@global.long_query_time into @lqt_save; set global long_query_time=2000; set global slow_query_log = 0; select sleep(2); FLUSH LOGS; select sleep(2); set global long_query_time=@lqt_save; set global slow_query_log = 1;' > /var/log/mysqladmin.flush-logs 2>&1
      fi
      endscript
    Current mysql log directories:
    ls -lh /var/log/ | egrep 'mysql|mysql-slowlog'
    -rw-------  1 root   root      0 Nov  6 01:10 mysqld.log
    mysql logrotation /etc/logrotate.d/mysql & /etc/logrotate.d/mysql-slowlog setup completed
                _   _                   ___         _  _    _         _
               | \ | |  ___ __      __ |_ _| _ __  (_)| |_ (_)  __ _ | |
               |  \| | / _ \\ \ /\ / /  | | | '_ \ | || __|| | / _` || |
               | |\  ||  __/ \ V  V /   | | | | | || || |_ | || (_| || |
               |_| \_| \___|  \_/\_/   |___||_| |_||_| \__||_| \__,_||_|
                __     _            __                                  __
                                                 |___/
    new initial /etc/my.cnf
    [client]
    [mysql]
    max_allowed_packet = 48M
    [mysqld]
    local-infile=0
    ignore_db_dirs=lost+found
    character-set-server=utf8mb4
    datadir=/var/lib/mysql
    #bind-address=127.0.0.1
    # by eva2000
    # centminmod.com
    tmpdir=/home/mysqltmp
    innodb=ON
    #skip-federated
    ##skip-pbxt
    ##skip-pbxt_statistics
    #skip-archive
    #skip-name-resolve
    #old_passwords
    back_log = 200
    max_connections = 200
    key_buffer_size = 32M
    myisam_sort_buffer_size = 64M
    myisam_max_sort_file_size = 2048M
    join_buffer_size = 128K
    read_buffer_size = 128K
    sort_buffer_size = 256K
    table_definition_cache = 8192
    table_open_cache = 4096
    thread_cache_size = 128
    wait_timeout = 1800
    connect_timeout = 10
    tmp_table_size = 128M
    max_heap_table_size = 128M
    #max_seeks_for_key = 4294967295
    #group_concat_max_len = 1024
    net_buffer_length = 8192
    max_connect_errors = 100000
    concurrent_insert = 2
    read_rnd_buffer_size = 256K
    bulk_insert_buffer_size = 8M
    # query_cache boost for MariaDB >10.1.2+
    # https://community.centminmod.com/posts/30811/
    query_cache_limit = 1024K
    query_cache_size = 64M
    query_cache_type = 1
    query_cache_min_res_unit = 2K
    query_prealloc_size = 262144
    default-storage-engine = InnoDB
    log_warnings=1
    slow_query_log=0
    long_query_time=1
    log-error=/var/log/mysqld.log
    # innodb settings
    innodb_purge_threads=1
    innodb_file_per_table = 1
    innodb_open_files = 4000
    innodb_buffer_pool_size = 192M
    ## https://mariadb.com/kb/en/mariadb/xtradbinnodb-server-system-variables/#innodb_buffer_pool_instances
    #innodb_buffer_pool_instances=1
    innodb_log_file_size = 128M
    innodb_log_buffer_size = 8M
    innodb_lock_wait_timeout=50
    innodb_flush_method = O_DIRECT
    # 200 * # DISKS
    innodb_io_capacity = 200
    innodb_io_capacity_max = 2000
    innodb_read_io_threads = 2
    innodb_write_io_threads = 2
    innodb_flush_neighbors = 1
    # mariadb settings
    [mariadb]
    #thread-pool-size= 20
    #extra-port=3307
    #extra-max-connections=1
    userstat = 0
    key_cache_segments = 1
    aria_group_commit = none
    aria_log_file_size = 32M
    aria_pagecache_buffer_size = 32M
    aria_sort_buffer_size = 32M
    [mariadb-5.5]
    #ignore_db_dirs=
    query_cache_strip_comments=0
    innodb_read_ahead = linear
    innodb_log_block_size = 512
    [mysqld_safe]
    #nice = -5
    open-files-limit = 8192
    [mysqldump]
    default-character-set=utf8mb4
    quick
    [myisamchk]
    key_buffer = 32M
    sort_buffer = 16M
    read_buffer = 16M
    write_buffer = 16M
    [mysqlhotcopy]
    interactive-timeout
    [mariadb-10.0]
    # 2 variables needed to switch from XtraDB to InnoDB plugins
    #plugin-load=ha_innodb
    #ignore_builtin_innodb
    ## MariaDB 10 only save and restore buffer pool pages
    ## warm up InnoDB buffer pool on server restarts
    #innodb_buffer_pool_dump_at_shutdown=1
    #innodb_buffer_pool_load_at_startup=1
    innodb_buffer_pool_populate=0
    ## Disabled settings
    performance_schema=OFF
    innodb_stats_on_metadata=OFF
    innodb_sort_buffer_size=2M
    innodb_online_alter_log_max_size=128M
    [mariadb-10.6]
    #innodb_file_format = Barracuda
    innodb_default_row_format = dynamic
    # performance regressions
    # https://jira.mariadb.org/browse/MDEV-16337
    # https://jira.mariadb.org/browse/MDEV-20697
    #join_cache_level=0
    optimizer_use_condition_selectivity=1
    ## wsrep specific
    # wsrep_on=OFF
    # wsrep_provider
    # wsrep_cluster_address
    # binlog_format=ROW
    # default_storage_engine=InnoDB
    # innodb_autoinc_lock_mode=2
    # innodb_doublewrite=1
    # query_cache_size=0
    # Defragmenting unused space on InnoDB tablespace
    innodb_defragment=1
    innodb_defragment_n_pages=7
    innodb_defragment_stats_accuracy=0
    innodb_defragment_fill_factor_n_recs=20
    innodb_defragment_fill_factor=0.9
    innodb_defragment_frequency=40
    # page compression
    # 10.1+ https://mariadb.com/kb/en/mariadb/compression/
    #innodb_compression_algorithm=zlib
    #innodb_use_fallocate=0
    #innodb_use_mtflush=0
    #innodb_mtflush_threads=4
    [1;32;40mexclude line exists... adding exclude line for mysql*
    [1;32;40m* Starting MariaDB Secure Installation
    /usr/local/src/centminmod/inc/mariadb_install106.inc: line 1471: mysql_upgrade: command not found
    Failed to stop mariadb.service: Unit mariadb.service not loaded.
    Failed to start mariadb.service: Unit mariadb.service not found.
    Installed:
      fio-3.35-1.el9.x86_64                   fio-engine-http-3.35-1.el9.x86_64
      fio-engine-libaio-3.35-1.el9.x86_64     fio-engine-nbd-3.35-1.el9.x86_64
      fio-engine-rados-3.35-1.el9.x86_64      fio-engine-rbd-3.35-1.el9.x86_64
      fio-engine-rdma-3.35-1.el9.x86_64       libnbd-1.18.1-4.el9_4.x86_64
      librados2-2:16.2.4-5.el9.x86_64         librbd1-2:16.2.4-5.el9.x86_64
      librdmacm-48.0-1.el9.x86_64
    ERROR 2002 (HY000): Can't connect to local server through socket '/var/lib/mysql/mysql.sock' (2)
    Full Reads: 24165
    Full Writes: 19931
    innodb_io_capacity = 1000
    /etc/my.cnf adjustment
    existing value:
    new value:
    innodb io threads adjustment
    existing value:
    new value:
    Restart MySQL server for io thread changes
    [1;32;40m* MariaDB installed
    After MariaDB installation
    Wed Nov  6 01:11:56 AM EST 2024
    Failed to enable unit: Unit file mariadb.service does not exist.
    [1;33;40m-------------------------------------------------------
    [m[1;32;40mMySQL root user password set
    [m[1;32;40mMySQL root user added to /root/.my.cnf
    [m[1;33;40m-------------------------------------------------------
    [m[1;32;40mMySQL root password:
    [1;32;40m* Installing PHP
    PHP VERSION ID: 80313
    Initial Install PHPMVER: 8.3
    buildconf: Checking installation
    buildconf: autoconf version 2.69 (ok)
    buildconf: Forcing buildconf. The configure files will be regenerated.
    buildconf: Cleaning cache and configure files
    buildconf: Rebuilding configure
    buildconf: Rebuilding main/php_config.h.in
    buildconf: Run ./configure to proceed with customizing the PHP build.
    PHP configure stage
    55,915
    12,281
    7:01 AM
    Thanks for the info. Unfortunately the mirror is dynamic and could be from AlmaLinux's own mirroring too. So the mirror your server picked up due to geolocation IP info gave you a blocked mirror or none working one.
    Can you post the contents of the MariaDB yum repo file via command beloe
    cat /etc/yum.repos.d/mariadb.repo
  9. denisyan
    denisyan New Member
    7
    12:01 AM
    [mariadb]
    name = MariaDB
    baseurl = https://yum.mariadb.org/10.6/rhel9-amd64
    module_hotfixes=1
    gpgkey=https://yum.mariadb.org/RPM-GPG-KEY-MariaDB
    gpgcheck=1
    exclude=MariaDB-Galera-server
    I've executed manually
    yum install mariadb-server
    and server installed, somehow. However i don't quite sure that it installed properly. WP via command 22 installed and working too.
    55,915
    12,281
    7:01 AM
    Could if been a temp mirror connectivity issue. Try reloading fresh AlmaLinux 9 and do a new Centmin Mod Install and see.
