SSL Problem with Forward Secrecy in SSLLabs Test
Discussion in 'Domains, DNS, Email & SSL Certificates' started by CarlosMST, Sep 30, 2014.
  1. CarlosMST
    CarlosMST Member
    Aug 9, 2014
    8:11 PM
    Hello @eva2000 I have a problem with my SSL Test Result.
    I followed your guide Nginx HTTPS / SSL Google SPDY configuration
    Here is the first part of my current nginx vhost configuration:
    # FIRST BLOCK
    # Redireccionar peticion http (puerto 80) a "https sin wwww"
      server_name mydomain.net www.mydomain.net;
      return 301 https://mydomain.net$request_uri;
    # SECOND BLOCK
    # Redireccionar peticion https (puerto 443) a "https sin wwww"
      listen 443;
      ssl on;
      ssl_certificate      /usr/local/nginx/conf/ssl/mydomain/ssl-bundle.crt;
      ssl_certificate_key  /usr/local/nginx/conf/ssl/mydomain/ssl.key;
      server_name www.mydomain.net;
      # Bloquear paises
      if ($allow_visit = no) {
        return 403;
    # THIRD BLOCK
    # El resto de la configuracion
    # https SSL SPDY vhost
            listen 443 ssl spdy;
                server_name mydomain.net;
            ssl_certificate      /usr/local/nginx/conf/ssl/mydomainnet/ssl-bundle.crt;
            ssl_certificate_key  /usr/local/nginx/conf/ssl/mydomainnet/ssl.key;
            ssl_protocols SSLv3 TLSv1 TLSv1.1 TLSv1.2;
            ssl_session_cache      shared:SSL:20m;
            ssl_session_timeout  4h;
            ssl_session_tickets on;
            ssl_ciphers ECDHE-RSA-AES128-GCM-SHA256:ECDHE-ECDSA-AES128-GCM-SHA256:ECDHE-RSA-AES256-GCM-SHA384:ECDHE-ECDSA-AES256-GCM-SHA384:DHE-RSA-AES128-GCM-SHA256:DHE-DSS-AES128-GCM-SHA256:kEDH+AESGCM:ECDHE-RSA-AES128-SHA256:ECDHE-ECDSA-AES128-SHA256:ECDHE-RSA-AES128-SHA:ECDHE-ECDSA-AES128-SHA:ECDHE-RSA-AES256-SHA384:ECDHE-ECDSA-AES256-SHA384:ECDHE-RSA-AES256-SHA:ECDHE-ECDSA-AES256-SHA:DHE-RSA-AES128-SHA256:DHE-RSA-AES128-SHA:DHE-DSS-AES128-SHA256:DHE-RSA-AES256-SHA256:DHE-DSS-AES256-SHA:DHE-RSA-AES256-SHA:AES128-GCM-SHA256:AES256-GCM-SHA384:ECDHE-RSA-RC4-SHA:ECDHE-ECDSA-RC4-SHA:AES128:AES256:RC4-SHA:HIGH:!aNULL:!eNULL:!EXPORT:!DES:!3DES:!MD5:!PSK:!kEDH:!EDH:!CAMELLIA;
            add_header Strict-Transport-Security "max-age=31536000; includeSubdomains;";
            # nginx 1.5.9+ or higher
            # http://nginx.org/en/docs/http/ngx_http_spdy_module.html#spdy_headers_comp
            # http://nginx.org/en/docs/http/ngx_http_ssl_module.html#ssl_buffer_size
            spdy_headers_comp 1;
            ssl_buffer_size 4k;
            # enable ocsp stapling
            ssl_stapling on;
            ssl_stapling_verify on;
            #ssl_trusted_certificate /usr/local/nginx/conf/ssl/mydomainnet/ssl-trusted.crt;
            resolver 8.8.8.8 valid=300s;
    I have ssl_ciphers configured and ssl_prefer_server_ciphers on; I think this is for preferred ciphers order, but the SSL labs test not recognize this, my test is here:
    The test mark the server dont support Forward Secrecy and the server has no preference.
    I tried to change the order of the configuration lines but no results.
    Could you help me please?
    Thanks in advance.
    55,916
    12,281
    11:11 AM
    nice read at SSL - HTTPS as a Google ranking signal | Centmin Mod Community
    I haven't checked those cipher orders in a while as I use a custom set for Cloudflare RC4 Kill patch and for OpenSSL 1.02-beta3 chacha20_poly1305 cipher support.
    i believe the ssllab error of no server cipher preference, it could be due to your SECOND BLOCK which is listening on 443 which doesn't have all SSL cipher and other SSL settings
    problem block
    # SECOND BLOCK
      listen 443;
      ssl on;
      # Bloquear paises
        return 403;
  3. rdan
    1,412
    9:11 AM
  4. CarlosMST
    CarlosMST Member
    Aug 9, 2014
    8:11 PM
  5. rdan
    1,412
    9:11 AM
    We're using that on our Live Forums.
  6. CarlosMST
    CarlosMST Member
    Aug 9, 2014
    8:11 PM
    @eva2000 @RoldanLT how to implement Cloudflare RC4 kill patch on my centminmod server?
    Cloudflare supports SSL websites for free?
    What is the cost of this service?
    Thanks.
    55,916
    12,281
    11:11 AM
    instructions are outlined in @RoldanLT linked post at Nginx - Nginx ssl cipher suite | Centmin Mod Community
    it's not Cloudflare service so no cost, it's just a patch to OpenSSL which Cloudflare made which I applied to Centmin Mod's Nginx OpenSSL static version - see
  8. CarlosMST
    CarlosMST Member
    Aug 9, 2014
    8:11 PM
