Nginx Problem with logrotate (and solution)
Discussion in 'Beta release code' started by wmtech, Jun 6, 2025.
  1. wmtech
    wmtech Active Member
    187
    44
    1:17 PM
    At version 9 (and prob. 10 also) OSs (Alma, Rocky, etc.) the logrotate systemd unit file is hardened with
    ProtectSystem=full
    This creates a problem with the default centminmod setup where logs in /usr/local/nginx/logs needs to be rotated.
    "ProtectSystem=full" mounts the /usr, /boot, /efi and /etc read-only for all processes invoked by this unit (logrotate).
    When logrotate runs and needs to handle a file in "/usr/local/nginx/logs" it fails, stops and creates the error
    logrotate: error: unable to handle /usr/local/nginx/logs/error.log: Read-only file system
    It has to be started manually after that and will fail again when the next run gets to that log file.
    The solution is to either comment out
    #ProtectSystem=full
    in "/lib/systemd/system/logrotate.service" OR to add that entry into the file:
    ReadWritePaths=/usr/local/nginx/logs
    to allow processing logs in that directory.
    After that change you need to reload the daemon and restart logrotate:
    systemctl daemon-reload
    systemctl restart logrotate
    Hope this helps other people seeing the same problem.
    58,895
    12,490
    9:17 PM
    Thanks for the bug report. Fixed in latest 140.00beta01, 132.00stable and 131.00stable updates, you can pull down via command: cmupdate and run and exit centmin.sh menu once.
    Manually you would need to remove your systemd service file edit first for your case.
    Folks only on EL9 like AlmaLinux/Rocky Linux 9, can also manually do fix via these steps
        # Create drop-in directory
        mkdir -p /etc/systemd/system/logrotate.service.d/
        # Create override file
    cat > /etc/systemd/system/logrotate.service.d/centminmod.conf << 'EOF'
    [Service]
    EOF
        # Reload and restart
    Which should create a file at override file at /etc/systemd/system/logrotate.service.d/centminmod.conf with contents of
    [Service]
    after logrotate service restart, you should see the override file listed in Drop-In of status command
    systemctl status logrotate --no-pager -l
    It's normal to see for status = Active: inactive (dead) since as logrotate on EL9 runs on a timer so runs and exits after completion with code=exited, status=0/SUCCESS
    ○ logrotate.service - Rotate log files
         Loaded: loaded (/usr/lib/systemd/system/logrotate.service; static)
        Drop-In: /etc/systemd/system/logrotate.service.d
                 └─centminmod.conf
         Active: inactive (dead) since Sat 2025-06-07 16:55:35 UTC; 6s ago
    TriggeredBy: ● logrotate.timer
           Docs: man:logrotate(8)
                 man:logrotate.conf(5)
        Process: 3844376 ExecStart=/usr/sbin/logrotate /etc/logrotate.conf (code=exited, status=0/SUCCESS)
       Main PID: 3844376 (code=exited, status=0/SUCCESS)
            CPU: 49ms
    This only applies to EL9+, EL8 - like AlmaLinux/Rocky Linux 8 and CentOS 7 don't have this
