Problem with domain resolve
Discussion in 'Virtual Private Server (VPS) hosting' started by pamamolf, Jun 25, 2014.
  1. Andy
    Andy Active Member
    546
    90
    6:40 AM
    When I'm using spdycheck to check one of my domains
    SPDYCheck: Testing Websites for SPDY Support
    It reports that it still allow http access. I don't get it. If you use the browser to go to that domain using http, it will redirect to http but when I curl it, it doesn't show redirection
    curl -I http://truongtot.vn
    HTTP/1.1 200 OK
    Server: nginx centminmod
    Connection: keep-alive
    Vary: Accept-Encoding
    Date: Fri, 12 Dec 2014 23:44:56 GMT
    X-Page-Speed: 1.9.32.2-4321
    Cache-Control: max-age=0, no-cache
    this is my conf
    # redirect from www to non-www
                listen 80;
                server_name www.truongtot.vn;
                return 301 https://truongtot.vn$request_uri;
    12,579
    9:40 PM
    you have a single nginx vhost .conf file for truongtot.vn ? what's it's full contents ? post in CODE tags
    edit: i see you accidentally set in step 1 of Getting started guide, the hostname of server to truongtot.vn which is same as your domain at http://truongtot.vn/ instead setting hostname to something like hostname.truongtot.vn
  3. Andy
    Andy Active Member
    546
    90
    6:40 AM
    uname -n
    ryan.truongtot.vn
    I gotta admit it was bit confusing following your Getting started guide because you used alternatively between host and hostname and I don't know when I should do what. Your example used hostname as well instead of the real one you used on one of your domain.
    Content of my /etc/hosts
    127.0.0.1   localhost localhost.localdomain localhost4 localhost4.localdomain4
    ::1         localhost localhost.localdomain localhost6 localhost6.localdomain6
    128.199.140.175 ryan ryan.truongtot.vn
    2400:6180:0:d0::143:8001 ryan ryan.truongtot.vn
  4. Andy
    Andy Active Member
    546
    90
    6:40 AM
      listen 80;
      listen 443 ssl spdy;
      server_name truongtot.vn;
      ssl_certificate  /usr/local/nginx/conf/ssl/truongtot.vn/ssl-unified.crt;
      ssl_certificate_key  /usr/local/nginx/conf/ssl/truongtot.vn/ssl.key;
      ssl_protocols TLSv1 TLSv1.1 TLSv1.2;
      ssl_session_cache  shared:SSL:10m;
      ssl_session_timeout  10m;
    ssl_ciphers ECDHE-RSA-AES128-GCM-SHA256:ECDHE-ECDSA-AES128-GCM-SHA256:ECDHE-RSA-AES256-GCM-SHA384:ECDHE-ECDSA-AES256-GCM-SHA384:DHE-RSA-AES128-GCM-SHA256:DHE-DSS-AES128-GCM-$
      ssl_prefer_server_ciphers  on;
      add_header Strict-Transport-Security "max-age=31536000;";
      resolver 8.8.8.8;
      ssl_stapling on;
      ssl_stapling_verify on;
      ssl_trusted_certificate /usr/local/nginx/conf/ssl/truongtot.vn/ssl-trusted.crt;
      # ssi  on;
      access_log /home/nginx/domains/truongtot.vn/log/access.log combined buffer=32k;
      error_log /home/nginx/domains/truongtot.vn/log/error.log;
    ## redirect www to no-www
      if ($host = 'www.truongtot.vn' ) {
      return 301 https://$server_name$request_uri;
    root /home/nginx/domains/truongtot.vn/public;
    location /data {
      location ~ \.html$ {
      internal;
      internal;
      location /internal_data {
      location ~ \.(?:data|html|php)$ {
      internal;
      internal;
      location /library {
      location ~ \.(?:default|html|php|txt|xml)$ {
      internal;
      internal;
      index index.php;
    12,579
    9:40 PM
    I see what you mean, will fix that to use hostname as example.
    as to vhost you're missing the non-www in server_name at
      listen 80;
      server_name truongtot.vn www.truongtot.vn;
