Problem with domain resolve
Discussion in 'Virtual Private Server (VPS) hosting' started by pamamolf, Jun 25, 2014.
    12,579
    9:40 PM
    i do both www A record and nginx redirect as it won't work if you don't resolve www via DNS
  2. pamamolf
    4,128
    2:40 PM
    How can i do this on nginx?
    12,579
    9:40 PM
    .07 betas menu option 2 used to create Nginx vhosts already has a commented out template for non-www redirect to www
    i.e. add domain1.com via centmin.sh menu option 2
    Centmin Mod 1.2.3-eva2000.07 - http://centminmod.com
                       Centmin Mod Menu
    1).  Centmin Install
    2).  Add Nginx vhost domain
    5).  PHP Upgrade / Downgrade
    6).  XCache Re-install
    7).  APC Cache Re-install
    8).  XCache Install
    9).  APC Cache Install
    14). SELinux disable
    16). Change SSHD Port Number
    20). NSD Re-install
    22). Exit
    Enter option [ 1 - 22 ] 2
    Enter vhost domain name you want to add (without www. prefix): domain1.com
    Reloading nginx:                                           [  OK  ]
    vhost for domain1.com created successfully
    vhost conf file for domain1.com created: /usr/local/nginx/conf/conf.d/domain1.com.conf
    upload files to /home/nginx/domains/domain1.com/public
    vhost log files directory is /home/nginx/domains/domain1.com/log
    Current vhost listing at: /usr/local/nginx/conf/conf.d/
    Jun 21  13:10   798    ssl.conf
    Jun 21  13:10   1.1K   demodomain.com.conf
    Jun 25  08:02   1.5K   virtual.conf
    Jun 25  23:53   1.3K   domain1.com.conf
    The domain1 vhost file /usr/local/nginx/conf/conf.d/domain1.com.conf has
    #server {
    #            listen   80;
    #            server_name domain1.com;
    #            return 301 $scheme://www.domain1.com$request_uri;
    just uncomment and nginx restart
                listen   80;
  4. pamamolf
    4,128
    2:40 PM
    But this is not what i want:
    i need this:
    redirect from www to non-www
    12,579
    9:40 PM
    reverse it then
                listen   80;
                server_name www.domain1.com;
                return 301 $scheme://domain1.com$request_uri;
  6. pamamolf
    4,128
    2:40 PM
    Problem solved 100% with namecheap :)
    I hope Godaddy to fix the problem soon.....
    12,579
    9:40 PM
    Glad to hear.. a good reliable and fast DNS provider makes all the difference - hence why I use DNSMadeEasy ;)
  8. pamamolf
    4,128
    2:40 PM
    I know that they are the best !
    This is what i hate on them :)
    5 Million Queries per Month * Limit
    12,579
    9:40 PM
    Business plan = 10m queries/month
    I'm only using 2-3m out of 10m per month heh
  10. rdan
    7:40 PM
    Use CloudFlare DNS, no limit and it's FREE ;)
    I'm using it for more than 1 month already without any problem.
  11. dorobo
    dorobo Active Member
    420
    104
    7:40 PM
    latest
    latest
    You're not using the CDN, just the DNS?
    So is your setting like this?
    12,579
    9:40 PM
    Yeah you can just use Cloudflare for DNS and turn off CDN :)
  13. pamamolf
    4,128
    2:40 PM
    Ok thanks :)
  14. Matt
    Matt Well-Known Member
    937
    415
    Rotherham, UK
    12:40 PM
    1.5.15
    MariaDB 10.2
    I usually get through 1.5m per month, but have been able to decrease that as I've increased the TTL on the records now I'm happy with my hosting provider.
    12,579
    9:40 PM
    yeah I use more as centminmod.com uses DNSMadeEasy's DNS/IP failover for haproxy load balanced OpenVZ VPSes (can't edit sysctl.conf so work around via DME to keep hosting costs cheaper than switching all load balanced VPSes to KVM or Xen for sysctl.conf access :) )
  16. rdan
    7:40 PM
    Do not pause or your domain or else your website will be unreachable, just change the dns settings into this:
  17. Andy
    Andy Active Member
    546
    90
    6:40 AM
    I have a similar issue.
    I want to redirect www to non-www via ssl. I got a Namecheap PositiveSSL cert that I'm not 100% certain if they cover both www and non-www. I got it issued for domain.com
    the problem is when I got to Domain Name Registration and Web Hosting | Domain.com it goes to Domain Name Registration and Web Hosting | Domain.com and not Domain Name Registration and Web Hosting | Domain.com
    # redirect from www to non-www
                listen 80;
                server_name www.bvtot.com;
                return 301 $scheme://bvtot.com$request_uri;
            listen 443 ssl spdy;
            ssl_certificate      /usr/local/nginx/conf/ssl/bvtot.com/bvtot.com-unified.crt;
            ssl_certificate_key  /usr/local/nginx/conf/ssl/bvtot.com/bvtot.com.key;
    12,579
    9:40 PM
    that's one you normally don't see accounted for but can be done via this entry within the SPDY SSL server context under root
    for
    https://www.domain.com
    to
    https://domain.com
    using 302 non-permanent redirect to test with first before using 301 permanent - test works for my sslspdy.com domain
         ## redirect www to nowww
          if ($host = 'www.sslspdy.com' ) {
             return 302 https://$server_name$request_uri;
    i.e. working
    curl -I https://www.sslspdy.com/
    HTTP/1.1 302 Moved Temporarily
    Server: nginx centminmod
    Date: Wed, 15 Oct 2014 20:47:23 GMT
    Content-Type: text/html
    Content-Length: 154
    Connection: keep-alive
    Strict-Transport-Security: max-age=31536000
    Alternate-Protocol: 443:npn-spdy/3
    within SPDY SSL server context
    SNIPPED REST
      root /home/nginx/domains/sslspdy.com/public;
  19. Andy
    Andy Active Member
    546
    90
    6:40 AM
    Thank you George,
    You still left the 302 in your final code. It should be 301.
    I have been reading and trying all the solution I found via stackoverflow but none work.
    This is most recent one I tried Redirect non-www to www over SSL with Nginx - Server Fault
    In any case, your solution works but I always be interested if there is a more optimal solution or if we have any overheard if we do the checking for every connection.
    12,579
    9:40 PM
    yeah left 302 so folks can test it first before changing it to 301
