Wordpress Problem when add new site wordpress site
Discussion in 'Blogs & CMS usage' started by YuchiRO, Sep 3, 2016.
  1. YuchiRO
    YuchiRO Member
    100
    6
    12:08 PM
    5.5.4
    Hi
    I had problem when add new worpdress site using option 22. Very slow, extrem slow with warning:
    PHP:
    PHP Warning:  Error while sending QUERY packetPID=24133 in /home/nginx/domains/mysite.com/public/wp-includes/wp-db.php on line 1858
    I had 9 running wordpress site on this server, and this is 10th site.
    Thanks.
    54,934
    12,240
    3:08 PM
    To troubleshoot, you need to check the the wp vhost log at /root/centminlogs and instructions under Sharing logs and errors heading for using Pastebin.com or Gists to share a sanitised version of the contents of the initial install log.
    Also post output for the following
    php -v
    php --ini
    php --m
    54,934
    12,240
    3:08 PM
    PHP Warning:  Error while sending QUERY packet. PID=24133 in /home/nginx/domains/mysite.com/public/wp-includes/wp-db.php on line 1858
    Actually line 1858 of wp-includes/wp-db.php is mysql query related at WordPress/wp-db.php at 4.6 · WordPress/WordPress · GitHub so probably your mysql server was slow and/or busy that's why
    did it eventually install and setup wordpress for you though ?
  4. YuchiRO
    YuchiRO Member
    100
    6
    12:08 PM
    5.5.4
    PHP Warning:  Error while sending QUERY packet. PID=7551 in /home/nginx/domains/mysite.com/public/wp-includes/wp-db.php on line 1858
    Installing WP Super Cache (1.4.8)
    Downloading install package from https://downloads.wordpress.org/plugin/wp-super-cache.1.4.8.zip...
    Using cached file '/root/.wp-cli/cache/plugin/wp-super-cache-1.4.8.zip'...
    Unpacking the package...
    Installing the plugin...
    Plugin installed successfully.
    Activating 'wp-super-cache'...
    Success: Plugin 'wp-super-cache' activated.
    Complete install wordpress more than a hour, each plugin cost alot of time to complete install.
    54,934
    12,240
    3:08 PM
    I see. Do you have any automated wordpress database backup scripts or wp backup plugins scheduled around that time ? could be locking your mysql server during backups so the query needed to wait until backups completed
    log and output for commands posted at Problem when add new site wordpress site | Centmin Mod Community ?
    54,934
    12,240
    3:08 PM
    54,934
    12,240
    3:08 PM
    Also what's output of this command (wrap in CODE tags)
    mysqladmin var | egrep "^\| max_allowed_packet|^\| wait_timeout" | tr -s ' '
  8. YuchiRO
    YuchiRO Member
    100
    6
    12:08 PM
    5.5.4
    No, i dont. Other site use default install with option 22.
    New site use option 22 to setup.
    mysqladmin var | grep '^| max_allowed_packet' | tr -s ' '
    | max_allowed_packet | 134217728 |
    54,934
    12,240
    3:08 PM
    looks okay to me for max_allowed_packet but depends on size of all your mysql databases
    what do you get when you manually run these commands for wp-cli
    cd /home/nginx/domains/mysite.com/public
    /usr/bin/wp --info --allow-root
    /usr/bin/wp plugin status --allow-root
    /usr/bin/wp db query "show tables;" --allow-root
    for last query you can mask the table prefix_ if you want
  10. YuchiRO
    YuchiRO Member
    100
    6
    12:08 PM
    5.5.4
    PHP binary:     /usr/local/bin/php
    PHP version:    5.6.24
    php.ini used:   /usr/local/lib/php.ini
    WP-CLI root dir:        phar://wp-cli.phar
    WP-CLI packages dir:
    WP-CLI global config:
    WP-CLI project config:
    WP-CLI version: 0.24.1
    8 installed plugins:
      I akismet                         3.1.11
      I cache-enabler                   1.1.0
      A cdn-enabler                     1.0.3
      A disable-xml-rpc                 1.0.1
      I optimus                         1.4.6
      A sucuri-scanner                  1.8.1
      A wp-super-cache                  1.4.8
      A wp-super-cache-clear-cache-menu 1.4
    Legend: I = Inactive, A = Active
    54,934
    12,240
    3:08 PM
    54,934
    12,240
    3:08 PM
    have you tried updating to php 5.6.25 ?
  13. YuchiRO
    YuchiRO Member
    100
    6
    12:08 PM
    5.5.4
    No, let me update php to 5.6.25.
    I will let you know result after update.
    Thanks.
  14. YuchiRO
    YuchiRO Member
    100
    6
    12:08 PM
    5.5.4
    After update PHP to 5.6.25. Option 22 work like charm.
    Thank spending time to help me.
    How to check cronjob to remove old entry data ( mysite.com - added with option 22 but remove manually)
    Thanks.
    54,934
    12,240
    3:08 PM
    ah so could of been php bug !
    to list cronjobs and then invoke the nano text editor to edit the cronjobs.. exiting nano will save and update your cronjobs
    crontab -l
    crontab -e
    also there's a wp uninstall script generated in output of centmin.sh menu option 22 which should remove stuff too
    from Wordpress Nginx Auto Installer (WP Super Cache)
    Created uninstall script
    /root/tools/wp_uninstall_newdomain2.com.sh
    where newdomain2.com is site domain name
    running the script should remove all newdomain2.com related files including the cronjob and vhost config files except the database itself which you can do manually
    you can check the contents of /root/tools/wp_uninstall_newdomain2.com.sh to see what gets removed to confirm
  16. YuchiRO
    YuchiRO Member
    100
    6
    12:08 PM
    5.5.4
    I adding second new mynewsitedomain and stuck at
    Updated user id ...xxx from my previous message untill now :(
    54,934
    12,240
    3:08 PM
    try editing /etc/my.cnf values to the following for these 2 items and restarting mysql server
    max_allowed_packet = 256M
    wait_timeout = 3600
    54,934
    12,240
    3:08 PM
    if it's still slow, you can re-run centmin.sh menu option 22 on new test domain, but before you do run open a 2nd ssh window connection to your server and double check what mysql processlist is listing via these commands
    create directory, /home/mysqlproclist change into it and create file named mysqlproc.txt then run mysqladmin processlist command in a loop every 1s interval and save output to mysqlproc.txt file
    mkdir -p /home/mysqlproclist
    cd /home/mysqlproclist
    touch mysqlproc.txt
    mysqladmin proc -i1 >> mysqlproc.txt
    this will hang the last command while it saves mysql processlist every 1s interval to mysqlproc.txt file
    then in the other ssh window run centmin.sh menu option 22 to completion.
    then in mysqladmin ssh window hit CTRL+C to end that command
    grab the contents of mysqlproc.txt and post contents of log to pastebin.com or gist.github.com (santised for db name(s) and username(s) as it lists all mysql queries being run for ALL databases on your server.
    54,934
    12,240
    3:08 PM
    From your provided mysqlproc.txt and server load issues at the time, sounds like mysql query /load issues with your other wordpress and web app mysql using scripts at the same time. Centmin Mod is provided as is so optimisation of software related to web app usage is left to the end user.
    2. What's your VPS/Server hardware specifications ? cpu type ? memory available ? disk space ?
    3. Who's your web host ? Different hosts have different limits for server resource usage and some are more restrictive that others so it could just be their resource usage policy you tripped which may or may not be restrictive. If restrictive, then real solution would be finding a better web host. If not restrictive, then it's finding out what caused high cpu load.
    Notes:
