Install problem on Centminmod beta
Discussion in 'Install & Upgrades or Pre-Install Questions' started by Cr0w, Mar 25, 2016.
  1. Cr0w
    Cr0w Member
    165
    9
    Iran
    11:15 AM
    1.9.x
    5.5
    54,857
    12,238
    5:45 PM
    when you do you get these errors ?
    fresh install ?
    1. Upgrading the actual Centmin Mod code outlined at Upgrade Centmin Mod - CentminMod.com LEMP Nginx web stack for CentOS This is heart of Centmin Mod where the code is the engine that runs centmin.sh shell based menu and all the automation you're accustomed to.
    2. Upgrade software that Centmin Mod installed or manages. For this part following outline at Upgrade - How to upgrade Centmin Mod | Centmin Mod Community
  3. Cr0w
    Cr0w Member
    165
    9
    Iran
    11:15 AM
    1.9.x
    5.5
    09 beta01 latest version .
    using menu option 1 install
    centos 7.1 x86_x64
    ram : 2gb
    cpu 2core 2.x ghz
    KVM VPS
    54,857
    12,238
    5:45 PM
    cheers fixed the no such file or directory messages in update to 123.09beta01 for fresh centmin.sh menu option 1 installs, the /usr/local/nginx/conf directory doesn't exist yet until after installs :)
  5. Cr0w
    Cr0w Member
    165
    9
    Iran
    11:15 AM
    1.9.x
    5.5
    cheers . you are the best , best developer in the world . centminmod is my love :D :headphone:
