Nginx Problem Install
Discussion in 'Nginx, PHP-FPM & MariaDB MySQL' started by KinderOvO, Jan 25, 2015.
  1. KinderOvO
    KinderOvO Member
    92
    12:43 AM
    1.4
    After install Centmin error on start services.
    /etc/init.d/nginx: line 70: 15125 Segmentation fault (core dumped) $nginx -t -c $NGINX_CONF_FILE
    55,811
    12,272
    12:43 AM
  3. KinderOvO
    KinderOvO Member
    92
    12:43 AM
    1.4
    [root@teste centmin-v1.2.3mod]# service nginx restart
    /etc/init.d/nginx: line 70:   316 Segmentation fault      (core dumped) $nginx -t -c $NGINX_CONF_FILE
    [root@teste centmin-v1.2.3mod]# nginx -V
    nginx version: nginx/1.7.9
    built by gcc 4.4.7 20120313 (Red Hat 4.4.7-11) (GCC)
    TLS SNI support enabled
    configure arguments: --with-cc-opt='-I/svr-setup/staticlibssl/include -I/usr/include' --with-ld-opt='-L/svr-setup/staticlibssl/lib -Wl,-rpath -lssl -lcrypto -ldl -lz' --sbin-path=/usr/local/sbin/nginx --conf-path=/usr/local/nginx/conf/nginx.conf --with-http_ssl_module --with-http_gzip_static_module --with-http_stub_status_module --with-http_sub_module --with-http_addition_module --with-http_image_filter_module --with-http_secure_link_module --with-http_flv_module --with-http_realip_module --with-openssl-opt=enable-tlsext --add-module=../ngx-fancyindex-ngx-fancyindex --add-module=../ngx_cache_purge-2.3 --add-module=../headers-more-nginx-module-0.25 --add-module=../nginx-accesskey-2.0.3 --add-module=../nginx-http-concat-master --with-http_dav_module --add-module=../nginx-dav-ext-module-0.0.3 --with-openssl=../openssl-1.0.2 --with-libatomic --with-pcre=../pcre-8.35 --with-pcre-jit --with-http_spdy_module --add-module=../ngx_pagespeed-release-1.9.32.3-beta
    tested 2 dedicated servers, similar error.
    32gb memory, centos 6 x64
    55,811
    12,272
    12:43 AM
    do you use ngx_pagespeed or webdav features at all ? try to troubleshoot this by disabling these and updating PCRE to 8.3.6 in centmin.sh and then recompile Nginx via centmin.sh menu option 4 setting nginx to 1.7.9 version
    in centmin.sh set the following before recompile Nginx via centmin.sh menu option 4
    NGINX_WEBDAV=n
    NGINX_PCREVER='8.36'
    NGINX_PAGESPEED=n
  5. Matt Williams
    537
    104
    Virginia, USA
    10:43 AM
    latest
    I'm getting this error right after the install.
    [root@vps ~]# service nginx start
    Starting nginx: /bin/bash: line 1: 23984 Segmentation fault /usr/local/sbin/nginx -c /usr/local/nginx/conf/nginx.conf
    [FAILED]
    Never had this issue before as always things went smoothly during the install
  6. Matt Williams
    537
    104
    Virginia, USA
    10:43 AM
    latest
    Did a recompile with menu option 4 and still the same above error
    55,811
    12,272
    12:43 AM
    can you provide info asked in 2nd post above too
  8. Matt Williams
    537
    104
    Virginia, USA
    10:43 AM
    latest
    It's a OpenVZ Container | installed the .07 stable which installed nginx 1.7.9 | Memory 2GB
    I run the following everytime:
    yum -y install bc wget unzip nano yum-plugin-fastestmirror
    cd /usr/local/src
    wget http://centminmod.com/download/centmin-v1.2.3-eva2000.07.zip
    unzip centmin-v1.2.3-eva2000.07.zip
    cd centmin-v1.2.3mod
    chmod +x centmin.sh
    yum clean all
    ./centmin.sh
    Then menu option 1. I installed 4 last night with no issue - this is the first time this has happen to me.
    55,811
    12,272
    12:43 AM
    hmm wonder if it's like .08 beta and OpenVZ + CentOS7..
    Last night i did test .07 install of latest on KVM VPS without problems.. need to try OpenVZ then
    Only thing I can think of right now is how Centmin Mod uses ngx_pagespeed from their github master repo and not version specific release so their master could of introduced code that messes with Nginx
    Try installing but edit centmin.sh line 187 first and set to no the following
    NGINX_PAGESPEEDGITMASTER=n   # Install ngx_pagespeed from official github master instead
  10. Matt Williams
    537
    104
    Virginia, USA
    10:43 AM
    latest
    The .08 beta worked just fine on OpenVZ | centos-7-x86_64 - I'll test the .07 stable with pagespeed off in a few moments
    55,811
    12,272
    12:43 AM
    Now that's weird as have folks reporting nginx server ain't restarting on CenOS 7 + OpenVZ with .08 beta... weird
    still installs ngx_pagespeed module just the source is different.. with set to =n it uses official version release.. with set to =y it uses master repository release
    55,811
    12,272
    12:43 AM
    55,811
    12,272
    12:43 AM
