Wordpress Problem After Migration
Discussion in 'Blogs & CMS usage' started by netheroez, Jun 26, 2017.
  1. netheroez
    netheroez New Member
    20
    5:37 PM
    47,843
    10,916
    8:37 PM
    Centmin Mod values security and puts additional measures in place so that end users are also mindful of security. So in your case, you might need to whitelist or unblock the WP plugins related to your 403 permission denied messages.
    If you used centmin.sh menu option 22 auto installer Wordpress Nginx Auto Installer, the default wpsecure conf file at /usr/local/nginx/conf/wpsecure_${vhostname}.conf where vhostname is your domain name, blocks php scripts from executing in wp-content for security
    Below links you can see examples of setting up specific wordpress location matches to punch a hole in the wpsecure blocking to whitelist specific php files that need to be able to run.
    If on Centmin Mod 123.09beta01, you may have ran into the new tools/autoprotect.sh cronjob feature outlined at Beta Branch - autoprotect.sh - apache .htaccess check & migration to nginx deny all | Centmin Mod Community You uploaded scripts may have .htaccess deny from all type files in their directories which may need bypassing autoprotect. It's a security feature that no other nginx based stack has as far as I know :)
  3. netheroez
    20
    5:37 PM
    I use option 2, then i upload wp-content manual.
    restore database manual.
    Now when i upload new image or theme or plugins. I have the same problem.
    47,843
    10,916
    8:37 PM
