Pre - load
Discussion in 'System Administration' started by Pawel4IT, May 5, 2020.
  1. Pawel4IT
    Pawel4IT New Member
    11:45 AM
    I would need through the cURL command and the paralellel option to generate requests for all the contents of my site;
    pages, posts, products, etc.
    It's possible ?
    46,655
    10,590
    7:45 PM
    Yes if you Google search for preload or prewarm cache with wget or curl, you will find lots of examples. Just test which works best for you.
  3. Pawel4IT
    Pawel4IT New Member
    11:45 AM
    thank you
