MariaDB potential problem while importing database
Discussion in 'Nginx, PHP-FPM & MariaDB MySQL' started by hitman, Feb 8, 2017.
  1. hitman
    hitman Member
    126
    11
    8:55 PM
    • Nginx Version Installed: 1.11.9
    • PHP Version Installed: 5.6.30
    well this is a fresh install on a new server and this is kind of weird
    i am transfering 2 sites to the new server and i have set up mysql users and databases and now i am trying to import the databases
    i first "use" the database, and then "source" from the sql file
    http://i.imgur.com/SVxU1hJ.png
    here is the screenshot
    problem is that after the first rows it says "database changed"
    many rows are affected and at the end the imported database does not have the name of the database i used with "use databasename" but it has the name it used to in the old server
    anyone care to explaing what is happening cause i find it a bit strange
    please note that the sites seem to be working fine
  2. Jimmy
    390
    1:55 PM
    I use this and it works great for me:
    Restore MySQL Database (RESTORE)
    # mysql -u <username> -p <database> < /path/to/<database>_backup_date.sql
    55,239
    12,253
    3:55 AM
    If you want db imported into new db name use myysql import Jimmy's way
