Nginx http2 directive Nginx warning only when creating subdomain
Discussion in 'Bug Reports' started by pamamolf, Apr 18, 2026.
    4,129
    11:12 AM
    I just install Centminod latest beta on Almalinux 9 and i added 2 domains for Nginx and all was working great.
    Then i added from menu (the same way) a subdomain and i got the usual warning:
    nginx: [warn] the "listen ... http2" directive is deprecated, use the "http2" directive instead
    Maybe there is a bug for subdomains creation?
    Thanks in advance !
    60,296
    12,609
    7:12 PM
    How did you add these 2 domains ? via centmin.sh menu option 2?
    The warning is cosmetic right now. Your created nginx domain should work. Does it?
    checked all 3 domains nginx vhost config /usr/local/nginx/conf/conf.d/yourdomain.com.ssl.conf ? are they all using same directive/listen format
  3. duderuud
    duderuud Active Member
    328
    98
    The Netherlands
    10:12 AM
    1.29 x
    11.4
    Change
      listen 443 ssl httpd2 reuseport;
      server_name your_server_name.com;
    to
      listen 443 ssl reuseport;
      http2 on;
    This was fixed a while back but this seems like a regression of some sort.
  4. pamamolf
    4,129
    11:12 AM
    yes.
    yes.
    I already adjust what was needed but as i can recall the issue was related only on the subdomain generation and not for the main domains...
    @duderuude
    I think it was as:
      listen 443 ssl http2 reuseport;
    and not as expected:
      http2 on;
