POEdit and FTP does not work
Discussion in 'Other Centmin Mod Installed software' started by tininho, May 22, 2019.
  1. tininho
    tininho Premium Member Premium Member
    87
    24
    Nordic
    4:40 PM
    Trying to translate Wordpress with POEdit Pro, but I can't connect to server's FTP with it.
    Since POEdit does not support self-signed SSL certs, I have switched the server to accept non-SSL connections, but I get timeout error on Poedit.
    Cyberduck connects normally. The settings (IP, username, password and connection type) are identical.
    grep pure-ftpd /var/log/messages | tail -25
    tail -10 /var/log/lfd.log
    Both log files do not react to any of POedit's connection attempts so there is nothing debug.
    POEdit has responded so far with only this: "Timeouts are typically due to the server’s firewall silently dropping connections."
    How can debug this or fix the problem?
    • CentOS Version: Centos 7.6
    • Nginx Version Installed:1.17
    • PHP Version Installed: 7.3
    • MariaDB MySQL Version Installed:10.4
    44,456
    10,157
    11:40 PM
    Centmin Mod pure-ftpd only supports TLS FTP connections and thus requires the self-signed SSL cert. You can't connect without it and security wise you shouldn't. Never used POEdit so no idea about that other than maybe trying alternatives if there are any ?
    However, if it's only for once off translation efforts, you can disable TLS self-signed ftp temporarily - instructions can read at Pure-FTPD Virtual FTP Users - under heading How to Disable Pure-FTPD Forced TLS/SSL Encrypted Mode?
    I'd re-enable forced TLS encrypted FTP after you have done the translations though.
    44,456
    10,157
    11:40 PM
    for this make sure firewalls on your client ftp side computers also aren't restricted see https://centminmod.com/ftp.html#firewalls - CSF Firewall configured by Centmin Mod should already have appropriate configuration on Centmin Mod server pure-ftpd side at least. If you have firewalls in front of Centmin Mod server though i.e. cloud firewall then you need to configure them for passive connections too.
  4. tininho
    87
    24
    Nordic
    4:40 PM
    Poedit allows to use collaborative translating together with machine translations. This makes the translation process so much faster and more convenient compared to, well, everything.
    And yes, I can connect to FTP (insecure & SSL) with Cyberduck.
    I can't connect to FTP (insecure & SSL) with POEdit (tried to disable the firewall, modifying pureftp conf file, no luck).
    I can connect other servers with POEdit.
    So the mystery remains. I got around the problem with linking local folder to server's folder.
    44,456
    10,157
    11:40 PM
  6. tininho
    87
    24
    Nordic
    4:40 PM
    I thank you for your responsiveness and willingness to help.
    So, from POEdit: "your server *is* blocking connections from api.poedit.net, which is where Poedit proxies connections through. That you don’t see anything in your logs is a matter of configuration on your end, but the packets evidently are dropped (not rejected), and it is not limited to port 21 (I tried 80 too)."
    Problem solved with:
    csf -a 172.104.150.128
    44,456
    10,157
    11:40 PM
    Ah so POEdit communicates outside of your server to a remote host - that would explain it as CSF Firewall would of prevented the inbound connection. So yes whitelisting IP in CSF Firewall is one way of doing it
  8. tininho
    87
    24
    Nordic
    4:40 PM
    Indeed, I was not aware of this nor did it cross my mind :)
