Wordpress Plugin installation issue - arrowchat 500 internal
Discussion in 'Blogs & CMS usage' started by Matt Williams, Dec 2, 2015.
  1. Matt Williams
    468
    90
    Virginia, USA
    5:54 AM
    latest
    Trying to install Arrowchat and getting to the database config, I see:
    I have tried just about everything I know to do. Any suggestions on trying to hunt down why a 500 is coming up?
    38,664
    8,538
    7:54 PM
    what is arrowchat ? heh
  3. Matt Williams
    468
    90
    Virginia, USA
    5:54 AM
    latest
    38,664
    8,538
    7:54 PM
    well no idea, but what is remote address to ? centmin mod server or some other server ? CSF Firewall whitelisted the remote ip ?
  5. Matt Williams
    468
    90
    Virginia, USA
    5:54 AM
    latest
    it's the VPS IP address. I just used 111.111.1111 as an example
    38,664
    8,538
    7:54 PM
    unfortunately might want to ask arrowchat folks
  7. Matt Williams
    468
    90
    Virginia, USA
    5:54 AM
    latest
    So you don't think the 500 error could be anything on the server side? Anything I could check for maybe? I don't see any errors in nginx logs or the domain error logs
  8. Matt Williams
    468
    90
    Virginia, USA
    5:54 AM
    latest
    Turns out that this junk plugin isn't compatible with PHP 7 - Dropped down to 5.6.15 and it worked just fine. Clients happy and I'm happy (y) Thanks for the help @eva2000 !
    38,664
    8,538
    7:54 PM
    ah i searched wp plugin directory on arrowchat plugin was last updated 5yrs ago it seems .. same one ?
  10. Matt Williams
    468
    90
    Virginia, USA
    5:54 AM
    latest
    38,664
    8,538
    7:54 PM
    Guess that answers your questions, you're lucky it works with PHP 5.4 let alone PHP 5.6 !
