Nginx Please help me fix this error after delete domodoamin.com
Discussion in 'Nginx, PHP-FPM & MariaDB MySQL' started by kinhatula, Dec 3, 2018.
  1. kinhatula
    kinhatula New Member
    9
    11:53 PM
    • Nginx Version Installed: i.e. 1.13.3
    • PHP Version Installed: i.e. 5.6.37, 7.0.31, 7.1.21, 7.2.9
    [12:43][[email protected] ~]# systemctl status nginx.service -l
    [B]‚óŹ[/B] nginx.service - SYSV: Nginx is an HTTP(S) server, HTTP(S) reverse proxy and IMAP/POP3 proxy server
       Loaded: loaded (/etc/rc.d/init.d/nginx; bad; vendor preset: disabled)
       Active: [B]failed[/B] (Result: exit-code) since Mon 2018-12-03 12:43:14 +07; 29s ago
      Process: 31061 ExecStart=/etc/rc.d/init.d/nginx start [B](code=exited, status=1/FAILURE)[/B]
    Dec 03 12:43:14 vip.hangmygiasi.net systemd[1]: Starting SYSV: Nginx is an HTTP(S) server, HTTP(S) reverse proxy and IMAP/POP3 proxy server...
    Dec 03 12:43:14 vip.hangmygiasi.net nginx[31061]: Starting nginx: nginx: [emerg] open() "/home/nginx/domains/hangmy.tk/log/access.log" failed (2: No such file or directory)
    Dec 03 12:43:14 vip.hangmygiasi.net nginx[31061]: [FAILED]
    Dec 03 12:43:14 vip.hangmygiasi.net systemd[1]: [B]nginx.service: control process exited, code=exited status=1[/B]
    Dec 03 12:43:14 vip.hangmygiasi.net systemd[1]: [B]Failed to start SYSV: Nginx is an HTTP(S) server, HTTP(S) reverse proxy and IMAP/POP3 proxy server.[/B]
    Dec 03 12:43:14 vip.hangmygiasi.net systemd[1]: [B]Unit nginx.service entered failed state.[/B]
    Dec 03 12:43:14 vip.hangmygiasi.net systemd[1]: [B]nginx.service failed.[/B]
    43,441
    9,862
    2:53 AM
    list exact steps/commands you used to delete the demodomain, as it seems you may have deleted more than just that demodomain vhost file/directories
  3. kinhatula
    9
    11:53 PM
    thanks, i fixed
  4. Meirami
    Meirami Member
    144
    24
    7:53 PM
    How did you fix it?
    43,441
    9,862
    2:53 AM
    You probably deleted /home/nginx/domains/hangmy.tk/log directory by accident so recreating it would fix it usually
    If you accidentally deleted the nginx vhost site directories in /home/nginx, you'll need to recreate them using below commands as root user in SSH just ensure log directory is owned by nginx user/group
    chown -R nginx:nginx /home/nginx/domains/hangmy.tk/log
