Phusion Passenger Nginx Module for Python & Ruby Deployments
Discussion in 'Add Ons' started by eva2000, Jun 12, 2015.
    55,811
    12,273
    11:56 AM
    Dedicated thread for discussion Centmin Mod .08 beta03's 130.00beta01 latest /addons/passenger.sh implementation for Phusion Passenger Nginx Module for Nginx which allows deployment of both Python, NodeJS, Meteor and Ruby based applications with Nginx.
    Fixed /addons/passenger.sh addon with the following commits in Centmin Mod .08 beta03 at least.
    The /addons/passenger.sh addon installs Phusion Passenger Nginx Module for Nginx which allows you to deploy both Python, NodeJS, Meteor and Ruby based applications with Nginx.
    Unfortunately, Clang compiler has issues compiling Nginx with Phusion Passenger's Nginx module, so if NGINX_PASSENGER=y is set in centmin.sh, the Nginx configure routine auto switches back to GCC compiler. Which works fine
    With Centmin Mod 130.00beta01's addons/passenger.sh as at August 15, 2022
    To install Phusion Passenger for Nginx on Centmin Mod Nginx
    1. run /addons/passenger.sh to install required software including passenger, node.js, ruby, rails, and rubygem
    cd /path/to/addons
    chmod +x passenger.sh
    ./passenger.sh install
    End of install will give next step instructions for completing Phusion Passenger install
    2. then log out of SSH windows session
    3. log back into SSH and and set NGINX_PASSENGER=y in persistent config file /etc/centminmod/custom_config.inc you have or create manually
    4. then run centmin.sh menu option 4 to recompile Nginx
    5. Enable /usr/local/nginx/conf/passenger.conf include file. Scripts will setup a /usr/local/nginx/conf/passenger.conf include file in nginx.conf which by default is commented out.
    http {
    #include /usr/local/nginx/conf/passenger.conf;
    need to uncomment it and restart nginx
    http {
    Contents of /usr/local/nginx/conf/passenger.conf
    passenger_root /usr/local/rvm/gems/ruby-3.1.2/gems/passenger-6.0.14;
    passenger_ruby /usr/local/rvm/bin/ruby;
    passenger_max_pool_size 4;
    Notes:
    • Updated for 123.09beta01 see example here.
    55,811
    12,273
    11:56 AM
    Personally, I am still a noob when it comes to utilising Phusion Passenger Nginx module, so if other users here are more familiar, I welcome any guides or sharing of how you use Phusion Passenger and Nginx with your NodeJS, Python or Ruby web apps :)
  3. Daniel J. Lewis
    Daniel J. Lewis Award-winning podcaster and consultant
    117
    15
    9:56 PM
    1.8.0
    5.6
    I don't think this is switching to GCC. I keep trying this (Nginx 1.9.9) and passenger is not being compiled in with Nginx.
    55,811
    12,273
    11:56 AM
    did you make sure to do steps 2 and 3 above ?
    To troubleshoot, you need to check the nginx upgrade log at /root/centminlogs and instructions under Sharing logs and errors heading for using Pastebin.com or Gists to share a sanitised version of the contents of the nginx upgrade log.
  5. Daniel J. Lewis
    117
    15
    9:56 PM
    1.8.0
    5.6
  6. Daniel J. Lewis
    117
    15
    9:56 PM
    1.8.0
    5.6
    Odd line in the log: inc/nginx_configure.inc: line 433: passenger-config: command not found
    55,811
    12,273
    11:56 AM
    sounds like step 1 for /addons/passenger.sh failed to install properly. You should have a /root/centminlogs log entry for passenger i.e. centminmod_passenger_install_${DT}.log which you can share via pastebin or gist too
  8. Daniel J. Lewis
    117
    15
    9:56 PM
    1.8.0
    5.6
    55,811
    12,273
    11:56 AM
    looks good to me
    Setup /usr/local/nginx/conf/passenger.conf
    Passenger root located at: /usr/local/rvm/gems/ruby-2.2.3/gems/passenger-5.0.22
    [1;32;40m-------------------------------------------
    (B[m[1;33;40mSetup completed...
    (B[m[1;32;40m-------------------------------------------
    only thing i can think of is step 2 and 3 above being missed as the path wouldn't have been setup for that same user SSH session until you log out and back in
    check /usr/local/nginx/conf/passenger.conf exists and try recompiling nginx again via centmin.sh menu option 4 and see
    55,811
    12,273
    11:56 AM
    also what's output for
    which passenger-config
    and
    passenger-config --nginx-addon-dir
  11. Daniel J. Lewis
    117
    15
    9:56 PM
    1.8.0
    5.6
    Maybe this is the problem. My server requires sudo. sudo bash doesn't have the paths set, but is the install script maybe not fully setup to support a sudo-required interface?
    /usr/local/nginx/conf/passenger.conf does exist.
    which returns /usr/local/rvm/gems/ruby-2.2.3/bin/passenger-config.
    55,811
    12,273
    11:56 AM
    indeed.. Centmin Mod is full root non-sudo only :D
  13. Daniel J. Lewis
    117
    15
    9:56 PM
    1.8.0
    5.6
    Okay. I was stupid. That was the problem.
    I was running this on Vagrant, and that defaults to a non-root user on "vagrant ssh," but that can be changed.
    Thanks for the help!
    55,811
    12,273
    11:56 AM
    excellent :)
  15. Juli112
    Juli112 New Member
    3:56 AM
    1.9.9
    I also get the "inc/nginx_configure.inc: line 433: passenger-config: command not found" Error in my nginx upgrade Log...
    Passenger installation went through fine but while building nginx I get the passenger-config not found error.
    which passenger-config does also return nothing and passenger-config is an unknown command...
    Here are my logs:
    Passenger Install: pastebin.com/EVKq9zMx
    Nginx Config: pastebin.com/jkasDVaa
    Nginx -V: pastebin.com/17gMkXmJ
    55,811
    12,273
    11:56 AM
    did you log out of SSH session after passenger.sh addon install ?
    Passenger root located at: /usr/local/rvm/gems/ruby-2.2.4/gems/passenger-5.0.23
    (B[m
    Log out and log back into your SSH session
    to complete the next setup steps bellow
    Instructions also at https://community.centminmod.com/threads/3282
    Uncomment lines in /usr/local/nginx/conf/passenger.conf to enable passenger
    Nginx needs to have passenger nginx module compiled for it to work
    1. edit centmin.sh and set NGINX_PASSENGER=y
    2. run centmin.sh menu option 4 to recompile Nginx
    3. uncomment/enable /usr/local/nginx/conf/passenger.conf include file in nginx.conf
    4. then check that passenger module is in list of nginx modules via command:
    nginx -V
    This script only installs passenger, node.js, ruby, rails, rubygem and is provided as is.
    See Phusion Passenger documentation at for deployment and configuration at:
    * http://www.modrails.com/documentation/Users%20guide%20Nginx.html
    * https://github.com/phusion/passenger/wiki/Phusion-Passenger%3A-Node.js-tutorial
    to complete the next setup steps above
    Total Phusion Passenger Install Time: 28.889722720 seconds
  17. Juli112
    Juli112 New Member
    3:56 AM
    1.9.9
    Yes, I logged out after passenger addon install...
    I even tried a fresh centos 7 install now but got the same error again ("inc/nginx_configure.inc: line 433: passenger-config: command not found")
    55,811
    12,273
    11:56 AM
    what type of web hosting and server you using ? Xen, OpenVZ, KVM or dedicated ? who's web host ? are you by any chance using or setup sudo users ?
    and
    55,811
    12,273
    11:56 AM
    @Juli112 think i found the problem and solution, testing it out now :)
    55,811
    12,273
    11:56 AM
    Updated both 123.08stable and 123.09beta01 with fix, so you can update your copy via centmin.sh menu option 23 submenu options 1 and 2 or just 2 if you previously have ran submenu option 1
    1. Upgrading the actual Centmin Mod code outlined at Upgrade Centmin Mod - CentminMod.com LEMP Nginx web stack for CentOS This is heart of Centmin Mod where the code is the engine that runs centmin.sh shell based menu and all the automation you're accustomed to.
    2. Upgrade software that Centmin Mod installed or manages. For this part following outline at Upgrade - How to upgrade Centmin Mod | Centmin Mod Community
