Install phpmyadmin.sh issue and general question
Discussion in 'Add Ons' started by EvilGenius, Sep 14, 2017.
  1. EvilGenius
    EvilGenius New Member
    6
    6:15 AM
    MariaDB 10
    • Centmin Mod Version Installed: 123.08stable
    • Nginx Version Installed: 1.11.10
    • PHP Version Installed: 7.1.0
    • MariaDB MySQL Version Installed: 10.0.21
    • When was last time updated Centmin Mod code base ? : 2 days ago after i installed centmin mod
    • Persistent Config: no
    Hello,
    What i wanna ask is the following in step 1 of the start guide where you set hostname i kinda can't understand what exactly am i supposed to put.
    So my domain name is mangamaid.com my VPS is on linode.com so i used for hostname maid.mangamaid.com cause in the example we have hostname.domain.com so i though this should be fitting as if i haven't understand wrong hostname is just a name you give? I might have understood wrong of course hence my question here.
    In the etc/hosts file i have put the following line
    ServerIP maid.mangamaid.com maid
    Example was: IP hostname.domainname.com hostname
    I decided to first set the server before installing Xenforo so i installed phpmyadmin with the phpmyadmin.sh and it gave me the following
    Create update script:
    /root/tools/phpmyadmin_update.sh
    Create uninstall script:
    /root/tools/phpmyadmin_uninstall.sh
    Password protected 26123_mysqladmin24109
    at path /usr/local/nginx/html/26123_mysqladmin24109
    config.inc.php at: /usr/local/nginx/html/26123_mysqladmin24109/config.inc.php
      WEB url:
      https://maid.mangamaid.com/26123_mysqladmin24109
    Login with your MySQL root username / password
    phpmyadmin htaccess login details:
    Username: Username
    Password: PW
    Allowed IP address: MyIpAdress
    phpmyadmin update script at: /root/tools/phpmyadmin_update.sh
    Add your own cron job to automatically run the update script i.e.
      15 01 * * * /root/tools/phpmyadmin_update.sh
    phpmyadmin uninstall script at: /root/tools/phpmyadmin_uninstall.sh
    SSL vhost: /usr/local/nginx/conf/conf.d/phpmyadmin_ssl.conf
    php-fpm includes: /usr/local/nginx/conf/php_26123_mysqladmin24109.conf
    php-fpm pool conf: /usr/local/nginx/conf/phpfpmd/phpfpm_myadmin.conf
    dedicated php-fpm pool user: phpmyadmin
    dedicated php-fpm pool group: nginx
    dedicated php error log: /var/log/php_myadmin_error.log
    SSL vhost access log: /var/log/nginx/localhost_ssl.access.log
    SSL vhost error log: /var/log/nginx/localhost_ssl.error.log
    Total phpmyadmin Install Time: 44.063835725 seconds
    phpmyadmin install log located at:
    /root/centminlogs/centminmod_phpmyadmin_install_130917-184215.log
    But then when i try to go on https://maid.mangamaid.com/26123_mysqladmin24109 it can't reach the site, but when i try with ipadress/26123_mysqladmin24109/ with IP address it reaches
    So my question is how do i need to set my host settings so it can be reached with mangamaid.com/..../ or how is it supposed to be setup because mangamaid.com is going to be my Xenforo Forum address too.
    Also when i login in ipadress/26123_mysqladmin24109/ with the given name and pw from the installation i get error 502 bad gateway.
    Thanks for the help beforehand also i checked the phpmyadmin log for the 502 error, but there is nothing in it.
    @eva2000 As advised i made the thread public one hope i made it in the right forum though feel free to change the place if needed. Thanks.
    50,891
    11,793
    2:15 PM
    Getting Started Guide Step 1 outlines the very first thing to do after centmin mod install is to setup working main hostname on server which includes adding the main hostname's DNS A record in your case maid.managamaid.com DNS A record pointing to server IP address
    IIRC it's something that was fixed in 123.09beta01 but not in 123.08stable for phpmyadmin.sh installer. Double check in /usr/local/etc/php-fpm.conf that this line is uncommented without semi colon in front
    include=/usr/local/nginx/conf/phpfpmd/*.conf
    if has semi-colon in front, remove it and restart nginx and php-fpm
    nprestart
    For 123.08stable when you run php upgrades via centmin.sh menu option 5 and if it prompts to replace php-fpm.conf, answer no instead. As replacing php-fpm disables and comments out the include=/usr/local/nginx/conf/phpfpmd/*.conf line again disable phpmyadmin's php config which resides in /usr/local/nginx/conf/phpfpmd/. While this was fixed in 123.09beta01 hence why 123.09beta01 has more fixes and improvements and is highly recommended.
  3. EvilGenius
    6
    6:15 AM
    MariaDB 10
    Hello, so i decided to just do a little reinstall of my server and go with
    • Nginx Version Installed: 1.11.10 (Not sure if this is what the 123.09beta01 installs by default)
    • MariaDB MySQL Version Installed: 10.1.26
    • When was last time updated Centmin Mod code base ? : 3h ago
    I have added DNS A Record with value being the server IP. I did wait ~1-2h giving it time to run through.
    But now i am getting the following issues:
    I get "The site can't be reached" with the link given to me when i installed phpmyadmin.sh neither can i reach it if i change it to the ip address.
    This is how my php-fpm.conf looks like currently:
    [global]
    ; Log level
    ; Possible Values: alert, error, warning, notice, debug
    ; Default Value: notice
    log_level = warning
    emergency_restart_threshold = 10
    emergency_restart_interval = 1m
    process_control_timeout = 10s
    [www]
    user = nginx
    group = nginx
    listen = 127.0.0.1:9000
    ;listen.backlog = -1
    ;listen = /tmp/php5-fpm.sock
    listen.owner = nginx
    listen.group = nginx
    listen.mode = 0660
    pm = ondemand
    pm.max_children = 16
    pm.start_servers = 8
    pm.min_spare_servers = 4
    pm.max_spare_servers = 12
    pm.max_requests = 1000
    ; PHP 5.3.9 setting
    ; The number of seconds after which an idle process will be killed.
    ; Note: Used only when pm is set to 'ondemand'
    ; Default Value: 10s
    rlimit_files = 65536
    rlimit_core = 0
    ; The timeout for serving a single request after which the worker process will
    ; be killed. This option should be used when the 'max_execution_time' ini option
    ; does not stop script execution for some reason. A value of '0' means 'off'.
    ; Available units: s(econds)(default), m(inutes), h(ours), or d(ays)
    ; Default Value: 0
    ;request_terminate_timeout = 0
    ; Default Value: 0
    ;request_slowlog_timeout = 0
    pm.status_path = /phpstatus
    ping.path = /phpping
    ping.response = pong
    ; Limits the extensions of the main script FPM will allow to parse. This can
    ; prevent configuration mistakes on the web server side. You should only limit
    ; FPM to .php extensions to prevent malicious users to use other extensions to
    ; exectute php code.
    ; Note: set an empty value to allow all extensions.
    ; Default Value: .php
    security.limit_extensions = .php .php3 .php4 .php5
    ; catch_workers_output = yes
    This is my phpmyadmin_https.conf
    location ^~ /MySqlAdminLocation/ {
    <------>#try_files $uri $uri/ /MySqlAdminLocation/index.php?$args;
    <------>include /usr/local/nginx/conf/MySqlAdmin.conf;
    <------>auth_basic      "Private Access";
    <------>auth_basic_user_file  /usr/local/nginx/conf/htpassphpmyadmin;
    <------>allow 127.0.0.1;
    <------>allow MyIpAdress;
    <------>#deny all;
    50,891
    11,793
    2:15 PM
  5. EvilGenius
    6
    6:15 AM
    MariaDB 10
  6. EvilGenius
    6
    6:15 AM
    MariaDB 10
    Hello, just wanna tell how i fixed my issue for future people who have that issue.
    Since i had bought domain from namecheap.com and my VPS was in linode.com i had to just add linodes nameservers
    ns1.linode.com
    ns2.linode.com
    ns3.linode.com
    ns4.linode.com
    ns5.linode.com
    In namecheap.com and then just make a DNS record with mangamaid.com in Linode in their DNS manager they make a default A record and all and all worked
    Still thanks for the help.
    50,891
    11,793
    2:15 PM
    thanks for the update/info :)
