phpmyadmin.sh Addon
Discussion in 'Add Ons' started by eva2000, May 25, 2014.
  1. FAPM
    FAPM Member
    58
    12:32 PM
    1.9.2
    10.0.20
    Hi ALL,
    The addon phpmyadmin does not work correctly on the Centmin Mod Version 1.2.3 eva2000.08
    The version installed by default: 4.5.0-dev
    Git Version: 2ffaaf9 fron master branch
    Php Version: 5.5.27
    MariaDB: 10.0.20
    For example, when creating a new user:
    # 1064 - You have an error in your SQL syntax; check the manual That corresponds to your version of MariaDB server for the right syntax to use near 'BY' password '' at line 1
    The selected user was not found in the privilege table.
    The phpMyAdmin configuration storage is not completely configured, some extended features have been deactivated. Find out why.
    Or alternately go to 'Operations' tab of any database to set it up there.
    Note: phpMyAdmin gets the users' privileges directly from MySQL's privilege tables. The content of these tables may differ from the privileges the server uses, if they have been changed manually. In this case, you should reload the privileges before you continue.
    12,578
    8:32 PM
    sounds like you're trying to select a user not create one ? can you list the exact steps you are doing to create a new user in phpmyadmin ?
    if not you can try the addons/mysqladmin_shell.sh addon instead mysqladmin_shell.sh Shell based Addon | Centmin Mod Community
  3. FAPM
    FAPM Member
    58
    12:32 PM
    1.9.2
    10.0.20
    User accounts / Add user account / User name, host %, password, authentification plugin mysql native password, create database with same name and grant all privilefes, and GO
    #1064 - You have an error in your SQL syntax; check the manual that corresponds to your MariaDB server version for the right syntax to use near 'BY 'tWbRRmh3CGsE6acE'' at line 1
    CREATE USER 'pshop'@'%' IDENTIFIED WITH mysql_native_password BY '***';GRANT USAGE ON *.* TO 'database'@'%' REQUIRE NONE WITH MAX_QUERIES_PER_HOUR 0 MAX_CONNECTIONS_PER_HOUR 0 MAX_UPDATES_PER_HOUR 0 MAX_USER_CONNECTIONS 0;
  4. FAPM
    FAPM Member
    58
    12:32 PM
    1.9.2
    10.0.20
    And for a creation of a database:
    Notice
    in ./libraries/navigation/Nodes/Node_Database.class.php#386
    Undefined index: navigationhiding
    Backtrace
    ./libraries/navigation/NavigationTree.class.php#566: Node_Database->getHiddenItems(string 'group')
    ./libraries/navigation/NavigationTree.class.php#342: PMA_NavigationTree->_addDbContainers(
    object,
    string '',
    integer 0,
    ./libraries/navigation/NavigationTree.class.php#298: PMA_NavigationTree->_buildPathPart(
    array,
    string '',
    string '',
    string '',
    string '',
    ./libraries/navigation/NavigationTree.class.php#866: PMA_NavigationTree->_buildPath()
    ./libraries/navigation/Navigation.class.php#50: PMA_NavigationTree->renderPath()
    ./navigation.php#75: PMA_Navigation->getDisplay()
    12,578
    8:32 PM
    extra ' in password probably throwing things off.. make sure password characters are accepted by mysql
    what version of PHP are you using ?
    or clear browser cache phpMyAdmin update to 4.3.6 generates "Undefined index: navwork" error - Stack Overflow
    interesting Undefined index: navwork · Issue #11142 · phpmyadmin/phpmyadmin · GitHub
  6. FAPM
    FAPM Member
    58
    12:32 PM
    1.9.2
    10.0.20
    Is a password generated by phpmyadmin
    It works perfectly with a similar password on mysqladmin_shell.sh
    Tested on freshly installed centminmod (base config)
    12,578
    8:32 PM
    no phpmyadmin you need to generate your own password as does mysqladmin_shell.sh
  8. FAPM
    FAPM Member
    58
    12:32 PM
    1.9.2
    10.0.20
    This is phpmyadmin that generates the password: "Generate password" => tWbRRmh3CGsE6acE
    12,578
    8:32 PM
    i see what you mean you can generate a password via phpmyadmin.. never used it myself or use phpmyadmin for user management or database creation as i use SSH command line - same steps used in addons/mysqladmin_shell.sh which always works
    Problem seems to be phpmyadmin using IDENTIFIED WITH mysql_native_password BY instead of IDENTIFIED BY PASSWORD instead this works
  10. FAPM
    FAPM Member
    58
    12:32 PM
    1.9.2
    10.0.20
    Yes, mysqladmin_shell it's perfect, it works fine :)
    I just want to escalate the issue to the forum ;)
    12,578
    8:32 PM
    12,578
    8:32 PM
    This query should work too with IDENTIFIED VIA mysql_native_password USING
    so not working
    working
    or
  13. FAPM
    FAPM Member
    58
    12:32 PM
    1.9.2
    10.0.20
    Noted :)
    Thank you Eva2000
  14. Vija
    Vija New Member
    11
    3:32 AM
    I just installed Centmin Mod 1.2.3-eva2000.08 with phpmyadmin addon.. I am not able to get the phpmyadmin to work.. i keep getting 404 error..
    12,578
    8:32 PM
    what url you trying to access ? is it behind https as phpmyadmin.sh addon only sets up install on https:// and not http://
    what if you try uninstall and reinstall ?
    to uninstall
    /root/tools/phpmyadmin_uninstall.sh
  16. Vija
    Vija New Member
    11
    3:32 AM
    I did that and didn't work.. the problem I am seeing is how the server hostname is created https://hostname.cinebuffer.com/2471_mysqladmin21680
    - It is the correct server hostname but for some reason not working outside.. so, I tried changing the url to cinebuffer.com/2471_mysqladmin21680 even that's not working
    also tried going to with ip address of server still 404
    12,578
    8:32 PM
    problem is you don't have a valid A record for DNS if that is the actual server main hostname = hostname.cinebuffer.com
    you can check at https://www.whatsmydns.net/#A/hostname.cinebuffer.com should return an ip for your server for A record check like your domain cinebuffer.com does https://www.whatsmydns.net/#A/cinebuffer.com
    Getting Started Guide Step 1 covers ensuring having valid DNS record for your main hostname
    FYI, ip works for me when I access https://YOURIP/2471_mysqladmin21680 remember only https:// will work not http://
    FYI, for privacy and security, you'd want to uninstall and reinstall so you get a new url with random generated url characters that isn't the one posted above :)
  18. Vija
    Vija New Member
    11
    3:32 AM
    IP works for you? for me it doesnt?
    12,578
    8:32 PM
    ah correction yes i see 404 after the self-signed ssl cert prompt where i click continue.
    12,578
    8:32 PM
    what do you get from output from SSH command line as root user when you type the following ?
    /usr/local/nginx/html is the public web root for main hostname's nginx vhost setup
    ls -lah /usr/local/nginx/html | grep 'mysqladmin'
