phpmyadmin does not work
Discussion in 'System Administration' started by Josephm, Apr 21, 2015.
  1. Josephm
    Josephm Active Member
    132
    44
    5:36 AM
    1.9.5
    10.0.21
    when I upgrade PHP to 5.6.8 and Xcache to 3.2.0, I can't access my phpmyadmin site. I got error message
    [SIZE=6][B]phpMyAdmin - Error[/B][/SIZE]
    Error during session start; please check your PHP and/or webserver log file and configure your PHP installation properly. Also ensure that cookies are enabled in your browser.
    I tried to find session.save_path in /usr/local/lib/php.ini, changed it to session.save_path = "/tmp" but it does not work.
    Anyone ever seen same issue?
    Thank you,
    55,380
    12,255
    8:36 AM
    if you're tweaking php defaults best to not edit php.ini if you want them to survive php upgrades. Instead create a custom .ini file in /etc/centminmod/php.d/ for example .08 beta has a new custom file at /etc/centminmod/php.d/a_customphp.ini and add the change to that to override php.ini
    have you tried clearing your browser cache ? try that first
  3. Josephm
    132
    44
    5:36 AM
    1.9.5
    10.0.21
    Thanks for comment, I needed to chmod 777 for /tmp as well. Now it's OK :)
    55,380
    12,255
    8:36 AM
    for /tmp use
    chmod 1777 /tmp
