Install Nginx PHP-FPM PHP & Nginx Not Installed By Default.
Discussion in 'Install & Upgrades or Pre-Install Questions' started by Varun, Apr 10, 2018.
    59,718
    3:24 AM
    you can remove those log links now if you want
    i can see the problem, varnish cache yum repo link isn't working for your install - i just tested fresh 123.09beta01 install in Dallas, USA and it worked so maybe geographic network issues with your digitalocean region which region is your droplet in ? i see in log
    update varnish cache 4.1 yum repo config
    curl: (7) Failed connect to packagecloud.io:443; Connection timed out
    What output do you get when you type below commands
    curl -I "https://packagecloud.io/install/repositories/varnishcache/varnish41/config_file.repo?os=centos&dist=7&source=script"
    curl -Iv "https://packagecloud.io/install/repositories/varnishcache/varnish41/config_file.repo?os=centos&dist=7&source=script" 2>&1| grep -A10 'About to connect'
    example output
    HTTP/1.1 200 OK
    Server: nginx
    Date: Tue, 10 Apr 2018 16:28:31 GMT
    Content-Type: text/repo; charset=utf-8
    Connection: keep-alive
    X-Frame-Options: SAMEORIGIN
    X-XSS-Protection: 1; mode=block
    version: 9f1abc2
    ETag: W/"139622dd5c82767fcb5e4d18d5c50720"
    Cache-Control: max-age=0, private, must-revalidate
    X-Request-Id: 38a6eebf-999b-456d-8d0f-e7effe0cb2be
    X-Runtime: 0.076745
    Strict-Transport-Security: max-age=15552000; includeSubDomains
      0     0    0     0    0     0      0      0 --:--:-- --:--:-- --:--:--     0* About to connect() to packagecloud.io port 443 (#0)
    *   Trying 2607:f0d0:2101:270::2...
    * Connected to packagecloud.io (2607:f0d0:2101:270::2) port 443 (#0)
    * Initializing NSS with certpath: sql:/etc/pki/nssdb
    *   CAfile: /etc/pki/tls/certs/ca-bundle.crt
      CApath: none
    * SSL connection using TLS_ECDHE_RSA_WITH_AES_128_GCM_SHA256
    * Server certificate:
    *       subject: CN=packagecloud.io,OU=EssentialSSL,OU=Domain Control Validated
    *       start date: Feb 01 00:00:00 2018 GMT
    *       expire date: Apr 01 23:59:59 2021 GMT
    For folks reading this message and yourself for posting code or output from commands to keep the formatting, you might want to use CODE tags for code How to use forum BBCODE code tags :)
  2. Varun
    Varun Member
    36
    India, Tamil Nadu, Chennai
    10:54 PM
    1.13.11
    For the first cmd i got below response
     curl: (7) Failed to connect to 2607:f0d0:2101:270::2: Network is unreachable
    For the second cmd i got the below reponse
    [16:38][root@jps.joeshop.co.uk ~]# curl -Iv "https://packagecloud.io/install/repositories/varnishcache/varnish41/config_file.repo?os=centos&dist=7&source=script        " 2>&1| grep -A10 'About to connect'
    *   Trying 50.97.198.58...
      0     0    0     0    0     0      0      0 --:--:--  0:00:15 --:--:--     0* Connection timed out
    * Failed to connect to 2607:f0d0:2101:270::2: Network is unreachable
    * Failed connect to packagecloud.io:443; Network is unreachable
    * Closing connection 0
    59,718
    3:24 AM
    what about
    curl -4Is "https://packagecloud.io/install/repositories/varnishcache/varnish41/config_file.repo?os=centos&dist=7&source=script"
    59,718
    3:24 AM
    it could be your server's dns resolver issues what's contents of /etc/resolv.conf ?
    cat /etc/resolv.conf
    and output for these commands
    dig A packagecloud.io +short
    dig AAAA packagecloud.io +short
    dig A google.com +short
    dig AAAA google.com +short
    ping -c4 packagecloud.io
    ping -c4 google.com
    ping6 -c4 packagecloud.io
    ping6 -c4 google.com
  5. Varun
    Varun Member
    36
    10:54 PM
    1.13.11
    Sorry About the delay
    Output for the cmd
    Nothing Just a blank Line ( http://s.svarun.in/pK )
    Output For
    [00:51][root@jps.joeshop.co.uk ~]# cat /etc/resolv.conf
    ; Created by cloud-init on instance boot automatically, do not edit.
    nameserver 67.207.67.2
    nameserver 67.207.67.3
    search joeshop.co.uk
    And the last CMDS
    ping -c4 google.com
    Output :
    [00:52][root@jps.joeshop.co.uk ~]# dig A packagecloud.io +short
    50.97.198.58
    [00:52][root@jps.joeshop.co.uk ~]# dig AAAA packagecloud.io +short
    [00:52][root@jps.joeshop.co.uk ~]# dig A google.com +short
    216.58.206.46
    [00:52][root@jps.joeshop.co.uk ~]# dig AAAA google.com +short
    2a00:1450:4009:812::200e
    [00:52][root@jps.joeshop.co.uk ~]# ping -c4 packagecloud.io
    PING packagecloud.io (50.97.198.58) 56(84) bytes of data.
    --- packagecloud.io ping statistics ---
    4 packets transmitted, 0 received, 100% packet loss, time 3000ms
    [00:52][root@jps.joeshop.co.uk ~]# ping -c4 google.com
    PING google.com (216.58.213.110) 56(84) bytes of data.
    64 bytes from lhr25s02-in-f14.1e100.net (216.58.213.110): icmp_seq=1 ttl=57 time=1.84 ms
    64 bytes from lhr25s02-in-f14.1e100.net (216.58.213.110): icmp_seq=2 ttl=57 time=1.25 ms
    64 bytes from lhr25s02-in-f14.1e100.net (216.58.213.110): icmp_seq=3 ttl=57 time=1.31 ms
    64 bytes from lhr25s02-in-f14.1e100.net (216.58.213.110): icmp_seq=4 ttl=57 time=1.29 ms
    --- google.com ping statistics ---
    4 packets transmitted, 4 received, 0% packet loss, time 3005ms
    rtt min/avg/max/mdev = 1.259/1.426/1.840/0.239 ms
    [00:52][root@jps.joeshop.co.uk ~]# ping6 -c4 packagecloud.io
    connect: Network is unreachable
    [00:52][root@jps.joeshop.co.uk ~]# ping6 -c4 google.com
    59,718
    3:24 AM
    I'd contact do support and provide output of those commands you just posted and say packagecloud domain is not resolving with 100% packet loss and you want to double check is there's any issues on digitalocean end. Seems connecting to google was fine though.
    I have updated 123.09beta01 today to check packagecloud connectivity and skip it's setup of varnish cache yum repo if you can't connect. So you can try another fresh install too
  7. Varun
    Varun Member
    36
    10:54 PM
    1.13.11
    Thanks for your fast reply.
    I created a new droplet again and tried all the ping cmds there. (In the same datacenter)
    [01:34][root@jps.joeshop.co.uk ~]# dig A packagecloud.io +short
    50.97.198.58
    [01:34][root@jps.joeshop.co.uk ~]# dig AAAA packagecloud.io +short
    [01:34][root@jps.joeshop.co.uk ~]# dig A google.com +short
    216.58.206.46
    [01:34][root@jps.joeshop.co.uk ~]# dig AAAA google.com +short
    2a00:1450:4009:801::200e
    [01:34][root@jps.joeshop.co.uk ~]# ping -c4 packagecloud.io
    4 packets transmitted, 0 received, 100% packet loss, time 3003ms
    [01:34][root@jps.joeshop.co.uk ~]# ping -c4 google.com
    PING google.com (216.58.206.46) 56(84) bytes of data.
    64 bytes from lhr35s10-in-f14.1e100.net (216.58.206.46): icmp_seq=1 ttl=55 time=1.78 ms
    64 bytes from lhr35s10-in-f14.1e100.net (216.58.206.46): icmp_seq=2 ttl=55 time=1.38 ms
    64 bytes from lhr35s10-in-f14.1e100.net (216.58.206.46): icmp_seq=3 ttl=55 time=1.36 ms
    64 bytes from lhr35s10-in-f14.1e100.net (216.58.206.46): icmp_seq=4 ttl=55 time=1.37 ms
    rtt min/avg/max/mdev = 1.362/1.475/1.781/0.176 ms
    [01:34][root@jps.joeshop.co.uk ~]# ping6 -c4 packagecloud.io
    [01:34][root@jps.joeshop.co.uk ~]# ping6 -c4 google.com
    DO you think it will workout ?
    Can you do a fresh install again ?
    59,718
    3:24 AM
    Looks like packagecloud is still getting 100% packet loss so on latest 123.09beta01 code varnish cache repo setup will be skipped but rest of centmin mod will install and run find if you don't need varnish cache repo.
    I have no problems with packagecloud on other web hosts so issue is with digitalocean so still may want to contact their tech support
  9. Varun
    Varun Member
    36
    10:54 PM
    1.13.11
    Hi
    I was successfully able to install CENTMIN MOD Stack and able to verify nginx and php version
    but is there any cmd to verify if it got fully installed. ?
    i have used the below cmd to install
    yum -y update; curl -O https://centminmod.com/betainstaller72.sh && chmod 0700 betainstaller72.sh && bash betainstaller72.sh
    59,718
    3:24 AM
    the post install check list at end of initial install should list the main software installed and it's version numbers along with install times
    example here's Upcloud $20/mon 2 cpu Chicago KVM VPS with betainstaller71.sh for PHP 7.1.15 default
    yum -y update; curl -O https://centminmod.com/betainstaller71.sh && chmod 0700 betainstaller71.sh && bash betainstaller71.sh
    Total Curl Installer YUM or DNF Time: 216.0248 seconds
    Total YUM Time: 39.756138386 seconds
    Total YUM or DNF + Source Download Time: 60.3143
    Total Nginx First Time Install Time: 274.5870
    Total PHP First Time Install Time: 288.3554
    Download Zip From Github Time: 3.5494
    Total Time Other eg. source compiles: 316.5700
    Total Centmin Mod Install Time: 939.8267
    Total Install Time (curl yum + cm install + zip download): 1159.4009 seconds
          2  Intel(R) Xeon(R) CPU E5-2687W v4 @ 3.00GHz (2  2999.996 Mhz)
    * Post-Install Check List....
    Check ccache Version:
    ccache version 3.4.1
    Copyright (C) 2009-2018 Joel Rosdahl
    version.
    Check Nginx Version:
    nginx version: nginx/1.13.10
    built by gcc 7.2.1 20170829 (Red Hat 7.2.1-1) (GCC)
    built with OpenSSL 1.1.0h  27 Mar 2018
    TLS SNI support enabled
    configure arguments: --with-ld-opt='-ljemalloc -Wl,-z,relro -Wl,-rpath,/usr/local/lib' --with-cc-opt='-m64 -march=native -DTCP_FASTOPEN=23 -g -O3 -fstack-protector-strong -flto -fuse-ld=gold --param=ssp-buffer-size=4 -Wformat -Werror=format-security -Wimplicit-fallthrough=0 -fcode-hoisting -Wp,-D_FORTIFY_SOURCE=2 -gsplit-dwarf' --sbin-path=/usr/local/sbin/nginx --conf-path=/usr/local/nginx/conf/nginx.conf --with-compat --with-http_stub_status_module --with-http_secure_link_module --with-libatomic --with-http_gzip_static_module --with-http_sub_module --with-http_addition_module --with-http_image_filter_module=dynamic --with-http_geoip_module --with-stream_geoip_module --with-stream_realip_module --with-stream_ssl_preread_module --with-threads --with-stream=dynamic --with-stream_ssl_module --with-http_realip_module --add-dynamic-module=../ngx-fancyindex-0.4.2 --add-module=../ngx_cache_purge-2.4.2 --add-module=../ngx_devel_kit-0.3.0 --add-dynamic-module=../set-misc-nginx-module-0.31 --add-dynamic-module=../echo-nginx-module-0.61 --add-module=../redis2-nginx-module-0.14 --add-module=../ngx_http_redis-0.3.7 --add-module=../memc-nginx-module-0.18 --add-module=../srcache-nginx-module-0.31 --add-dynamic-module=../headers-more-nginx-module-0.33 --with-pcre=../pcre-8.42 --with-pcre-jit --with-zlib=../zlib-cloudflare-1.3.0 --with-http_ssl_module --with-http_v2_module --with-openssl=../openssl-1.1.0h --with-openssl-opt='enable-ec_nistp_64_gcc_128'
    Check PHP-FPM Version:
    PHP 7.1.15 (cli) (built: Mar 28 2018 04:07:45) ( NTS )
    Copyright (c) 1997-2018 The PHP Group
    Zend Engine v3.1.0, Copyright (c) 1998-2018 Zend Technologies
        with Zend OPcache v7.1.15, Copyright (c) 1999-2018, by Zend Technologies
    MariaDB-common-10.1.32-1.el7.centos.x86_64
    MariaDB-devel-10.1.32-1.el7.centos.x86_64
    MariaDB-client-10.1.32-1.el7.centos.x86_64
    MariaDB-shared-10.1.32-1.el7.centos.x86_64
    MariaDB-compat-10.1.32-1.el7.centos.x86_64
    MariaDB-server-10.1.32-1.el7.centos.x86_64
    memcached 1.5.6
    Check CSF Firewall Version:
    csf: v12.01 (generic)
    SIEGE 4.0.4
    Copyright (C) 2017 by Jeffrey Fulmer, et al.
    FOR A PARTICULAR PURPOSE.
    Check mysqlreport version:
    Check pure-ftpd Version:
    pure-ftpd v1.0.42
    Check YUM Repo List
     * base: mirrors.usinternet.com
     * epel: mirror.steadfast.net
     * extras: mirrors.usinternet.com
     * rpmforge: mirror.team-cymru.org
     * updates: mirrors.usinternet.com
    234 packages excluded due to repository priority protections
    repo id                        repo name                             status
    base/7/x86_64                  CentOS-7 - Base                       7,420+2,171
    centos-sclo-rh/x86_64          CentOS-7 - SCLo rh                       6,765+94
    centos-sclo-sclo/x86_64        CentOS-7 - SCLo sclo                          515
    epel/x86_64                    Extra Packages for Enterprise Linux 7  11,522+927
    extras/7/x86_64                CentOS-7 - Extras                             446
    mariadb                        MariaDB                                      30+2
    rpmforge                       RHEL 7 - RPMforge.net - dag               135+110
    updates/7/x86_64               CentOS-7 - Updates                      1,886+530
    !varnishcache_varnish41/x86_64 varnishcache_varnish41                         46
    !varnishcache_varnish41-source varnishcache_varnish41-source                   0
    repolist: 28,765
    mytimes check:
    /usr/bin/mytimes
    Wed Mar 28 04:11:29 UTC 2018  [UTC]
    Wed Mar 28 14:11:29 AEST 2018   [Australia/Brisbane]
    Tue Mar 27 21:11:29 PDT 2018    [America/Los_Angeles]
    Tue Mar 27 23:11:29 CDT 2018    [America/Chicago]
    Wed Mar 28 00:11:29 EDT 2018    [America/New_York]
    Wed Mar 28 00:11:29 EDT 2018    [America/Montreal]
    Wed Mar 28 05:11:29 BST 2018    [Europe/London]
    Wed Mar 28 06:11:29 CEST 2018   [Europe/Berlin]
    Wed Mar 28 11:11:29 +07 2018    [Asia/Bangkok]
    Wed Mar 28 11:11:29 +07 2018    [Asia/Ho_Chi_Minh]
    Wed Mar 28 11:11:29 WIB 2018    [Asia/Jakarta]
    Wed Mar 28 12:11:29 +08 2018    [Asia/Kuala_Lumpur]
    Wed Mar 28 12:11:29 +08 2018    [Asia/Singapore]
    59,718
    3:24 AM
    @Varun looks like you're not the only person who is having packagecloud.io connectivity issues with DigitalOcean web host as @MakeShyft seems to report the same issue at Installer stalls · Issue #109 · centminmod/centminmod. I have thus disabled Varnish Cache yum repo setup by default with new default variable VARNISHREPO_DISABLE='y' on new 123.09beta01 installs until I can figure out why DigitalOcean is having connectivity issues to packagecloud.io.
  12. Varun
    Varun Member
    36
    10:54 PM
    1.13.11
    @eva2000
    Thanks for the update. if there is anything if i could support please let me know.
