PHP-FPM PHP-FPM tuning help!
Discussion in 'Nginx, PHP-FPM & MariaDB MySQL' started by KinderOvO, Nov 12, 2019.
  1. KinderOvO
    KinderOvO Member
    92
    7:32 AM
    1.4
    Hi, I have a 3900x / 64GB memory / 1TB NVME RAID 1 server.
    I'm having php-fpm slowdown issues currently I use the following configs.
    pm = ondemand
    pm.max_children = 30
    pm.start_servers = 8
    pm.min_spare_servers = 4
    pm.max_spare_servers = 12
    pm.max_requests = 5000
    and nginx worker_processes auto i use auto like this
    user nginx nginx;
    worker_processes auto;
    worker_cpu_affinity auto;
    worker_priority -10;
    events {
    worker_connections 100000;
    accept_mutex off;
    accept_mutex_delay 200ms;
    use epoll;
    #multi_accept on;
    how could i better, is there much difference between ondemand and dynamic?
    53,142
    12,108
    7:32 AM
  3. rdan
    1,397
    5:32 AM
  4. Manoj malviya
    Manoj malviya New Member
    19
    3:02 AM
    1.17.6
    10.3.20
    i have a dedicated server which have 128 gb of ram and xeon processor with 1gbps bandwidth. I have installed centminmod on my server but the issue I am facing is that when my traffic raise to 3000 realtime the server stop responding.
    What I am looking for what will be the configuration of php-fpm so it can handle 10000 realtime users
    My configuration is this
    global]
    ; Log level
    ; Possible Values: alert, error, warning, notice, debug
    ; Default Value: notice
    log_level = warning
    emergency_restart_threshold = 10
    emergency_restart_interval = 1m
    process_control_timeout = 10s
    include=/usr/local/nginx/conf/phpfpmd/*.conf
    [www]
    user = nginx
    group = nginx
    listen = 127.0.0.1:9000
    listen.backlog = 65535
    ;listen = /tmp/php5-fpm.sock
    listen.owner = nginx
    listen.group = nginx
    listen.mode = 0660
    pm = static
    pm.max_children = 3072
    pm.start_servers = 100
    pm.min_spare_servers = 10000
    pm.max_spare_servers = 15000
    pm.max_requests = 10000
    ; PHP 5.3.9 setting
    ; The number of seconds after which an idle process will be killed.
    ; Note: Used only when pm is set to 'ondemand'
    ; Default Value: 10s
    rlimit_files = 65536
    rlimit_core = 0
    ; The timeout for serving a single request after which the worker process will
    ; be killed. This option should be used when the 'max_execution_time' ini option
    ; does not stop script execution for some reason. A value of '0' means 'off'.
    ; Available units: s(econds)(default), m(inutes), h(ours), or d(ays)
    ; Default Value: 0
    ;request_terminate_timeout = 0
    ; Default Value: 0
    ;request_slowlog_timeout = 0
    pm.status_path = /phpstatus
    ping.path = /phpping
    ping.response = pong
    ; Limits the extensions of the main script FPM will allow to parse. This can
    ; prevent configuration mistakes on the web server side. You should only limit
    ; FPM to .php extensions to prevent malicious users to use other extensions to
    ; exectute php code.
    ; Note: set an empty value to allow all extensions.
    ; Default Value: .php
    security.limit_extensions = .php
    ; catch_workers_output = yes
    php_admin_value[disable_functions] = shell_exec.
  5. pamamolf
    4,068
    427
    12:32 AM
    Nginx-1.25.x
    You can try something like:
    pm = dynamic
    pm.max_children = 80
    pm.start_servers = 32
    pm.min_spare_servers = 16
    pm.max_spare_servers = 64
    pm.max_requests = 8000
  6. Manoj malviya
    19
    3:02 AM
    1.17.6
    10.3.20
    Will this configuration will able to handle 10000 realtime users?
  7. pamamolf
    4,068
    427
    12:32 AM
    Nginx-1.25.x
    I think so....
  8. Manoj malviya
    19
    3:02 AM
    1.17.6
    10.3.20
    just queries how you calculate this configuration will be right for 10000 users.
    If I need to increase it more what will be the things i need to check
  9. pamamolf
    4,068
    427
    12:32 AM
    Nginx-1.25.x
    It is my personal estimation for your current server cpu cores+threads+ram...
    There are a lot more factors to just say use that numbers and you will be able to handle 10000 users as it depends for example:
    What each user does and what's the cost of each request for php.
    How well is the server optimized.
    How well is your software optimized
    and a lot more.
    But keep in mind that i am not an expert but you can easily test (if you don't have any other recommendations) my recommendation and if you don't like it just revert the edits and do a simple restart of phpfpm :)
