PHP-FPM PHP compile problem
Discussion in 'Install & Upgrades or Pre-Install Questions' started by Rhodium, Oct 27, 2024.
  1. Rhodium
    Rhodium New Member
    25
    5
    4:26 PM
    • CentOS Version: Alma Linux 9
    • Centmin Mod Version Installed: 140.00beta01.b156
    • Nginx Version Installed: 1.27.2
    • PHP Version Installed: 8.3.13
    • MariaDB MySQL Version Installed: 10.6.19
    • When was last time updated Centmin Mod code base ? : 27/10/2024
    • Persistent Config:
      LETSENCRYPT_DETECT='y'
      DUALCERTS='y'
      NGINX_STAPLE_CACHE_OVERRIDE='y'
      NGINX_STAPLE_CACHE_TTL='86400'
      AUTOHARDTUNE_NGINXBACKLOG='y'
      ZSTD_LOGROTATE_NGINX='y'
      ZSTD_LOGROTATE_PHPFPM='y'
      SELFSIGNEDSSL_ECDSA='y'
      NGINX_LIBBROTLI='y'
      NGXDYNAMIC_BROTLI='y'
      NEEDRESTART_CHECK='y'
      PHP_BROTLI='y'
      PHP_LZFOUR='y'
      PHP_LZF='y'
      PHP_ZSTD='y'
      DMOTD_PHPCHECK='y'
      PHPFINFO='y'
      MM_CSF_SRC='y'
      MM_LICENSE_KEY='xxxx'
      CF_DNSAPI_GLOBAL='y'
      CF_Token='xxxx'
      CF_Account_ID='xxxx'
      IMAGEMAGICK_SEVEN='y'
    Hi, still getting errors when trying to recompile a new PHP version in AlmaLinux 9. I can compile fine adding this to custom_config.inc: PHP_EXTRAOPTS='--with-libzip=/opt/remi/libzip/lib64/ --with-password-argon2'
    But without i get this error:
    Installing PEAR environment:      /usr/local/lib/php/
    /svr-setup/php-8.3.13/fpm-build/sapi/cli/php: symbol lookup error: /svr-setup/php-8.3.13/fpm-build/sapi/cli/php: undefined symbol: zip_file_is_seekable
    make[1]: *** [Makefile:553: install-pear-installer] Error 127
    make: *** [Makefile:558: install-pear] Error 2
    This is the full log :D
    centminmodlog-20241027
    54,389
    12,198
    1:26 AM
    What output do you get from these commands - wrap in CODE or CODEB bbcode tags
    updatedb
    locate libzip.so
  3. Rhodium
    Rhodium New Member
    25
    5
    4:26 PM
    locate libzip.so
    /opt/remi/libzip/lib64/libzip.so
    /opt/remi/libzip/lib64/libzip.so.5
    /opt/remi/libzip/lib64/libzip.so.5.5
    /svr-setup/libzip-1.10.1/build/lib/libzip.so
    /svr-setup/libzip-1.10.1/build/lib/libzip.so.5
    /svr-setup/libzip-1.10.1/build/lib/libzip.so.5.5
    /usr/lib64/libzip.so.5
    /usr/lib64/libzip.so.5.3
    /usr/share/elasticsearch/jdk/lib/libzip.so
    Maybe its because ImageMagick7 install libzip too?
    54,389
    12,198
    1:26 AM
    Indeed interesting issue on AlmaLinux 9 PHP 8.1.30 works, 8.2.25 and higher don't when non-default optional ImageMagick7 is installed. Though test various fixes now.
  5. Matt
    Matt Well-Known Member
    929
    415
    Rotherham, UK
    3:26 PM
    1.5.15
    MariaDB 10.2
    54,389
    12,198
    1:26 AM
    Just committed to 140.00beta01 a fix when you compile PHP 8.2+ with optional non-default
    IMAGEMAGICK_SEVEN='y'. Took some time to fix as some as of the issues were PHP 8.2 or 8.3 or 8.4 specific. Ended up having to have some workarounds implemented. If you switch to optional non-default IMAGEMAGICK_SEVEN='y' with PHP 7.4+ now will use REMI remi-libzip too while still allowing REMI ImageMagick7 to use it's libzip dependency.
