Install Is this right in the first installing?
Discussion in 'Install & Upgrades or Pre-Install Questions' started by jellday, Dec 17, 2024.
  1. jellday
    jellday Member
    4:53 PM
    1.4.6
    5.5
    • CentOS Version: AlmaLinux 8
    • Centmin Mod Version Installed: 131.00stable
    • Nginx Version Installed: 1.27.2
    • PHP Version Installed: 7.4.33
    • MariaDB MySQL Version Installed: 10.4.34
    • When was last time updated Centmin Mod code base ? :
      [*]SELFSIGNEDSSL_ECDSA='y'
      PHPFINFO='y'
      PHP_OVERWRITECONF='n'
      MARCH_TARGETNATIVE='n'
    I just did a fresh installation on Almalinux 8, and when I checked the information, I got this error:
    Check pure-ftpd Version:
    pure-ftpd v1.0.49
    ● pure-ftpd.service - Pure-FTPd FTP server
       Loaded: loaded (/usr/lib/systemd/system/pure-ftpd.service; enabled; vendor preset: disabled)
      Drop-In: /etc/systemd/system/pure-ftpd.service.d
               └─pidfile.conf
       Active: active (running) since Mon 2024-12-16 08:04:15 EST; 15ms ago
      Process: 474589 ExecStart=/usr/sbin/pure-ftpd /etc/pure-ftpd/pure-ftpd.conf (code=exited, status=0/SUCCESS)
     Main PID: 474590 (pure-ftpd)
        Tasks: 1 (limit: 15667)
       Memory: 1.3M
       CGroup: /system.slice/pure-ftpd.service
               └─474590 /usr/sbin/pure-ftpd /etc/pure-ftpd/pure-ftpd.conf
    Dec 16 08:04:15 racknerd-afdae56 systemd[1]: Starting Pure-FTPd FTP server...
    Dec 16 08:04:15 racknerd-afdae56 systemd[1]: pure-ftpd.service: Can't open PID file /run/pure-ftpd.pid (yet?) after start: No such file or directory
    Dec 16 08:04:15 racknerd-afdae56 pure-ftpd[474590]: (?@?) [DEBUG] Couldn't load the DH parameters file /etc/ssl/private/pure-ftpd-dhparams.pem
    Dec 16 08:04:15 racknerd-afdae56 systemd[1]: Started Pure-FTPd FTP server.
    I am not sure if this is OK in the first install.
    12,576
    6:53 PM
    in /etc/centminmod/custom_config.inc might want to remove the [*] from
    you can ignore pure-ftpd PID messages and for pem file when you first run centmin.sh menu option, it will auto generate the pem file.
  3. jellday
    jellday Member
    4:53 PM
    1.4.6
    5.5
    OK. Thanks a lot.
