Nginx PHP-FPM PHP 7.0 auto_prepend Operation not permitted
Discussion in 'Nginx, PHP-FPM & MariaDB MySQL' started by Cryptso, Aug 27, 2017.
  1. Cryptso
    Cryptso New Member
    8:18 AM
    • Nginx Version Installed: 1.13.4
    • PHP Version Installed: 7.0.18
    tail /var/log/php_myadmin_error.log
    [26-Aug-2017 21:31:29 UTC] PHP Fatal error: Unknown: Failed opening required '/home/nginx/domains/mydomain.net/public/xyz_file.php' (include_path='.:/usr/local/lib/php') in Unknown on line 0
    [26-Aug-2017 21:32:20 UTC] PHP Warning: Unknown: open_basedir restriction in effect. File(/home/nginx/domains/mydomain.net/public/xyz_file.php) is not within the allowed path(s): (/usr/local/nginx/html/5352_mysqladmin4431:/tmp) in Unknown on line 0
    [26-Aug-2017 21:37:56 UTC] PHP Fatal error: Unknown: Failed opening required '/home/nginx/domains/mydomain.net/public/xyz_file.php' (include_path='.:/usr/local/lib/php') in Unknown on line 0
    38,035
    8,356
    5:18 PM
    You installed phpmyadmin.sh addon and it's /usr/local/nginx/conf/phpfpmd/phpfpm_myadmin.conf php-fpm pool config has open_basedir set via directive php_admin_value[open_basedir]
    but other vhosts shouldn't have open_basedir set anymore with 123.09beta01. Also check open_basedir messages read FAQ item 26
    what are you specifically doing auto_prepend wise ?
  3. Cryptso
    Cryptso New Member
    8:18 AM
    With auto_prepend i'm loading MySQL connection for my multi-lvl domains.
    Thanks for advice. Fixed this problem - additionally i had to change user and group privileges for phpmyadmin
    38,035
    8,356
    5:18 PM
    Glad to hear :)
