Install PHP 7.0.20 installation errors on fresh centmin installation
Discussion in 'Install & Upgrades or Pre-Install Questions' started by noly, Jul 29, 2017.
  1. noly
    noly Premium Member Premium Member
    93
    13
    Germany
    3:40 AM
    1.13.x
    10.x
    • Nginx Version Installed: 1.13.3
    • PHP Version Installed: 7.0.20
    • MariaDB MySQL Version Installed: 10.1.25
    • When was last time updated Centmin Mod code base ? : code is uptodate
    • Persistent Config:
      NGXDYNAMIC_NGXPAGESPEED='y'
      NGINX_PAGESPEED='y'
    On a fresh centmin installation when upgrading to PHP 7.0.20 i get the following errors...
    HTTP/1.1 404 Not Found
    PHP was not installed properly
    configure: error: utf8_mime2text() has new signature, but U8T_CANONICAL is missing. This should not happen. Check config.log for additional information.
    php_configure.inc make -j2
    make: *** No targets specified and no makefile found.  Stop.
    real    0m0.002s
    user    0m0.000s
    sys    0m0.002s
    make: *** No rule to make target `install'.  Stop.
    real    0m0.002s
    user    0m0.002s
    sys    0m0.000s
    strip PHP binary...
    ls: cannot access /usr/local/bin/php: No such file or directory
    ls: cannot access /usr/local/bin/php-cgi: No such file or directory
    strip: '/usr/local/bin/php': No such file
    strip: '/usr/local/bin/php-cgi': No such file
    Starting php-fpm /etc/init.d/php-fpm: line 69: /usr/local/sbin/php-fpm: No such file or directory
     failed
    PHPMUVER = 7.0
    PHP_PGO = n
    make -j2
    real    0m0.002s
    user    0m0.002s
    sys    0m0.000s
    Sat Jul 29 12:08:28 UTC 2017
    Error: 2, PHP make failed (1.2.3-eva2000.09.005)
  2. ArisC
    ArisC Active Member
    116
    29
    4:40 AM
    Nginx Latest
    MariaDB Latest
    Try 7.0.21
    • Optimistic Optimistic x 1
  3. noly
    93
    13
    Germany
    3:40 AM
    1.13.x
    10.x
    Same same. :-/
  4. ArisC
    ArisC Active Member
    116
    29
    4:40 AM
    Nginx Latest
    MariaDB Latest
    38,664
    8,538
    12:40 PM
  6. ArisC
    ArisC Active Member
    116
    29
    4:40 AM
    Nginx Latest
    MariaDB Latest
    Im Getting the same error.... Clean Installation Let'sEncrypt="y" also getting 403 forbidden...
    38,664
    8,538
    12:40 PM
    • What version of Centmin Mod ? .07 stable or .08 stable or .09 beta01 ? Was it fresh install or upgrade ? How long ago did you install Centmin Mod ? There's numerous code changes, bug fixes over time, so ensure you have latest Centmin Mod code installed by upgrading your Centmin Mod code as instructed below.
    • What version of PHP used ? Did you upgrade or downgrade PHP recently ? Which version did you upgrade from ?
    • If you upgrade to PHP 7.0.* it doesn't support memcache, igbinary, geoip or imagick PHP extensions. If you're testing PHP 7, on restarting PHP-FPM you will get some PHP warnings that some PHP extensions are unable to load as PHP 7 doesn't support them. So all you need to do is delete the releveant *.ini files for them
    Every centmin.sh menu option has a full server log created with time stamped file name at /root/centminlogs. You can check that specific error log for clues or copy and paste log contents and post to pastebin.com or gist.github.com for sharing.
    To troubleshoot, you need to check the the php upgrade logs at /root/centminlogs and instructions under Sharing logs and errors heading for using Pastebin.com or Gists to share a sanitised version of the contents of the nginx_upgrade and php_upgrade logs. You can see full details at How to troubleshoot Centmin Mod initial install issues
    if you type this command it lists all logs in date ascending order so latest log at bottom
    ls -lArt /root/centminlogs
    so copy the entire contents of latest php_upgrade log to gist.github.com or pastebin.com
    you can use grep to filter the logs, i.e. look for nginx_upgrade or php in log name
    ls -lahrt /root/centminlogs/ | egrep 'nginx_upgrade|php_upgrade'
    -rw-r--r--  1 root root  2.6M Oct  3 03:48 centminmod_1.2.3-eva2000.09.001_031016-034409_php_upgrade.log
    -rw-r--r--  1 root root  664K Oct 12 09:24 centminmod_1.2.3-eva2000.09.001_121016-092406_nginx_upgrade.log
    So the last php upgrade log was named centminmod_1.2.3-eva2000.09.001_031016-034409_php_upgrade.log and located at /root/centminlogs/centminmod_1.2.3-eva2000.09.001_031016-034409_php_upgrade.log
    then use cat command to output the contents of that log.
    cat /root/centminlogs/centminmod_1.2.3-eva2000.09.001_031016-034409_php_upgrade.log
    then select and copy and paste output to pastebin.com or gist.github.com file to share. If your SSH client's scroll buffer isn't large enough using cat might not output the entire log file contents, so you may need to download the log and use local text editor to open and copy and paste.
    so only need content of a specific log, in this case most recent php_upgrade.log logs
    1. Upgrading the actual Centmin Mod code outlined at Upgrade Centmin Mod - CentminMod.com LEMP Nginx web stack for CentOS This is heart of Centmin Mod where the code is the engine that runs centmin.sh shell based menu and all the automation you're accustomed to.
    2. Upgrade software that Centmin Mod installed or manages. For this part following outline at Upgrade - How to upgrade Centmin Mod | Centmin Mod Community
  8. noly
    93
    13
    Germany
    3:40 AM
    1.13.x
    10.x
    Fresh installations and upgrading to php 7.0.20 or 7.0.21 went smooth now. :)
    Thank you so much @eva2000 for keeping your ears open to alarm bells. :love:
    38,664
    8,538
    12:40 PM
  10. ArisC
    ArisC Active Member
    116
    29
    4:40 AM
    Nginx Latest
    MariaDB Latest
