Nginx Domains Permission related doubt and issues
Discussion in 'Install & Upgrades or Pre-Install Questions' started by Saahib, Oct 8, 2017.
    60,207
    12,603
    8:59 PM
    also anything in your mysql error logs ?
    For CentOS 6 only.
    tail -500 /var/lib/mysql/YOURHOSTNAME.err
    or
    tail -500 /var/log/mysqld.log
  2. Saahib
    Saahib Member
    38
    4:29 PM
    1.13
    Nothing as such...
    # tail -n 20 /var/lib/mysql/server.hostname.err
    171008 22:23:15 mysqld_safe Starting mysqld daemon with databases from /var/lib/mysql
    2017-10-08 22:23:15 139799512057888 [Note] /usr/sbin/mysqld (mysqld 10.1.28-MariaDB) starting as process 4095 ...
    2017-10-08 22:23:15 139799512057888 [Note] InnoDB: Using mutexes to ref count buffer pool pages
    2017-10-08 22:23:15 139799512057888 [Note] InnoDB: The InnoDB memory heap is disabled
    2017-10-08 22:23:15 139799512057888 [Note] InnoDB: Mutexes and rw_locks use GCC atomic builtins
    2017-10-08 22:23:15 139799512057888 [Note] InnoDB: GCC builtin __atomic_thread_fence() is used for memory barrier
    2017-10-08 22:23:15 139799512057888 [Note] InnoDB: Compressed tables use zlib 1.2.3
    2017-10-08 22:23:15 139799512057888 [Note] InnoDB: Using Linux native AIO
    2017-10-08 22:23:15 139799512057888 [Note] InnoDB: Using generic crc32 instructions
    2017-10-08 22:23:15 139799512057888 [Note] InnoDB: Initializing buffer pool, size = 1.0G
    2017-10-08 22:23:15 139799512057888 [Note] InnoDB: Completed initialization of buffer pool
    2017-10-08 22:23:15 139799512057888 [Note] InnoDB: Highest supported file format is Barracuda.
    2017-10-08 22:23:15 139799512057888 [Note] InnoDB: 128 rollback segment(s) are active.
    2017-10-08 22:23:15 139799512057888 [Note] InnoDB: Waiting for purge to start
    2017-10-08 22:23:15 139799512057888 [Note] InnoDB:  Percona XtraDB (http://www.percona.com) 5.6.36-82.2 started; log sequence number 198978530
    2017-10-08 22:23:15 139796815017728 [Note] InnoDB: Dumping buffer pool(s) not yet started
    2017-10-08 22:23:15 139799512057888 [Note] Plugin 'FEEDBACK' is disabled.
    2017-10-08 22:23:15 139799512057888 [Note] Server socket created on IP: '::'.
    2017-10-08 22:23:15 139799512057888 [Note] /usr/sbin/mysqld: ready for connections.
    Version: '10.1.28-MariaDB'  socket: '/var/lib/mysql/mysql.sock'  port: 3306  MariaDB Server
     #tail -10 /var/log/mysqld.log
    2017-10-08  8:06:15 140036621249280 [Note] /usr/sbin/mysqld: Normal shutdown
    2017-10-08  8:06:15 140036621249280 [Note] Event Scheduler: Purging the queue. 0 events
    2017-10-08  8:06:15 140037993203456 [Note] InnoDB: FTS optimize thread exiting.
    2017-10-08  8:06:15 140036621249280 [Note] InnoDB: Starting shutdown...
    2017-10-08  8:06:16 140036621249280 [Note] InnoDB: Waiting for page_cleaner to finish flushing of buffer pool
    2017-10-08  8:06:18 140036621249280 [Note] InnoDB: Shutdown completed; log sequence number 198714603
    2017-10-08  8:06:18 140036621249280 [Note] /usr/sbin/mysqld: Shutdown complete
    171008 08:06:18 mysqld_safe mysqld from pid file /var/lib/mysql/server.hostname.pid ended
    60,207
    12,603
    8:59 PM
    double check /etc/hosts file has this entry too
    127.0.0.1 localhost.localdomain localhost
    or check php config connecting to 127.0.0.1 instead of localhost
    php is on same server as mariadb mysql server right ?
    also output for command
    php --ri mysqli
    60,207
    12,603
    8:59 PM
    If you have a spare test server, you can try centos 6 with 123.09beta01 fresh install on that and test phpmyadmin.sh addon install and see if that works if it does, then issue is only specific to your problematic server.
  5. Saahib
    Saahib Member
    38
    4:29 PM
    1.13
    Yes, they are.
    /etc/hosts
     cat /etc/hosts
    127.0.0.1 localhost.localdomain localhost localhost4.localdomain4 localhost4
    # Auto-generated hostname. Please do not remove this comment.
    xxx.xxx.xxx server.hostname.com  server.hostname
    ::1         localhost localhost.localdomain localhost6 localhost6.localdomain6
    with 127.0.0.1, it worked.
    Finally, but my /etc/hosts looks just alright..
    However, I can't change localhost to 127.0.0.1 in code as it is at several places and code is not maintained by me.
    60,207
    12,603
    8:59 PM
    weird can you ping localhost ?
    ping -c4 localhost
    ping -c4 localhost
    PING localhost.localdomain (127.0.0.1) 56(84) bytes of data.
    64 bytes from localhost.localdomain (127.0.0.1): icmp_seq=1 ttl=64 time=0.014 ms
    64 bytes from localhost.localdomain (127.0.0.1): icmp_seq=2 ttl=64 time=0.010 ms
    64 bytes from localhost.localdomain (127.0.0.1): icmp_seq=3 ttl=64 time=0.009 ms
    64 bytes from localhost.localdomain (127.0.0.1): icmp_seq=4 ttl=64 time=0.008 ms
    --- localhost.localdomain ping statistics ---
    4 packets transmitted, 4 received, 0% packet loss, time 2999ms
    rtt min/avg/max/mdev = 0.008/0.010/0.014/0.003 ms
    60,207
    12,603
    8:59 PM
    Also what are permissions on your /var/lib/mysql directory
    ls -lah /var/lib/ | grep mysql
    drwxr-xr-x  7 mysql   mysql   4.0K Oct  8 23:53 mysql
  8. Saahib
    Saahib Member
    38
    4:29 PM
    1.13
    Yes, can ping localhost same yours.
    It differed a little,
    # ls -lah /var/lib/ | grep mysql
    drwx------ 24 mysql   root    4.0K Oct  9 01:22 mysql
    Then after changing chown mysql:mysql
    drwx------ 24 mysql   mysql   4.0K Oct  9 01:28 mysql
    But no effect.
    Permission of /var/lib/mysql
    ls -lah /var/lib/mysql/ | grep mysql
    drwx------ 24 mysql mysql 4.0K Oct  9 01:22 .
    -rw-rw----  1 mysql mysql  16K Oct  9 01:22 aria_log.00000001
    -rw-rw----  1 mysql mysql   52 Oct  9 01:22 aria_log_control
    -rw-rw----  1 mysql mysql 384M Oct  9 01:22 ib_logfile0
    -rw-rw----  1 mysql mysql 384M Oct  8 08:13 ib_logfile1
    -rw-rw----  1 mysql mysql  74M Oct  9 01:22 ibdata1
    -rw-rw----  1 mysql mysql  52K Oct  9 01:22 server.somehost.com.err
    -rw-rw----  1 mysql mysql    5 Oct  9 01:22 server.somehost.com.pid
    -rw-rw----  1 mysql mysql    0 Oct  8 08:14 multi-master.info
    drwx------  2 mysql root  4.0K Oct  8 22:27 mysql
    srwxrwxrwx  1 mysql mysql    0 Oct  9 01:22 mysql.sock
    -rw-r--r--  1 root  root    15 Oct  8 22:27 mysql_upgrade_info
    drwx------  2 mysql mysql 4.0K Oct  8 22:27 performance_schema
    drwx------  2 mysql mysql 4.0K Oct  9 00:05 pub
    -rw-rw----  1 mysql mysql  24K Oct  9 01:22 tc.log
    Ofourse there are some more listing of my databases there.
    Perhaps, you may see this discussion :
    MySQL cannot connect via "localhost", only 127.0.0.1
    May be based on your expertise, you can suggest me some direction from there..
    Though I have hecked things:
    1. Every user has all three variation with password,
    2. Mysql client is using unix socket
    3. skip-name-resolve is OFF
    4. Using socket=/var/lib/mysql/mysql.sock everywhere.
    Now its weird ..
    60,207
    12,603
    8:59 PM
    then restart nginx + php-fpm + mysql
    nprestart
    mysqlrestart
    60,207
    12,603
    8:59 PM
    oh you need to chmod 0755 /var/lib/mysql directory too
  11. Saahib
    Saahib Member
    38
    4:29 PM
    1.13
    This did the trick, it was hell of a experience and I expected earlier, it is going to be something rather little but have been causing big nuisance.
    Meanwhile looking for solution, I went through whole lot of your documentations in short time, I must say you know your things, specially the way you describe stuff in all docs, its commendable. Otherwise, I have seen good developers but hindered by bad docs.
    Just a note, I found that if I use Filezilla with Auto mode, its corrupting files, I had to shift to "binary" to make transfers. Do you think in pure-ftp turning "ascii modifications" is required ?
    Also, I can assume here that from Mysql 5.5.x to Mariadb 10.1.x, one can safely import database , although I ran mysql-upgrade too.
    60,207
    12,603
    8:59 PM
    Never come across this before what mime type files are you uploading? I don't use filezilla though i use securefx by vandyke
    You're problem was probably the mysqldump with all-datsbases option which forced the wipe all fix. You generally won't have issues with individual database dump and restores
    Thanks been doing server/system related tech support and server optimisation consulting for 16+ yrs which reinforces the ability to explain and document stuff :)
  13. Saahib
    Saahib Member
    38
    4:29 PM
    1.13
    Actually, issue was created by mysql_install_db during reinitialization of , you have also mentioned there to change permission but some how I missed it.
    60,207
    12,603
    8:59 PM
    i actually updated those instructions after your issue. So my mistake :oops:
  15. Saahib
    Saahib Member
    38
    4:29 PM
    1.13
    All along I was wondering how I missed it :p
    Anyways, I today deployed on live environment. And sites stopped loading at all. I understand that I need to do php-fpm optimization but when I went to see logs, nothing was there.
    I suppose php-fpm logs are at :
    /var/log/php-fpm/www-error.log
    Global Nginx logs at :
    /usr/local/nginx/logs/error.log
    Nothing was there.. so how do I start , where to looks stuff ?
    60,207
    12,603
    8:59 PM
    what do you mean stop loading, what does web browser say ?
    To troubleshoot Nginx and PHP-FPM issues you'd want to check the domain site's vhost access.log and error.log logs located within directory at /home/nginx/domains/yourdomain.com/logs. You can see a full overview at centminmod.com/configfiles.html
    FAQ item 19 has more info on all Centmin Mod relevant log files locations and how to use tail command to view a sample of the entries.
    Also post the contents of your site's nginx vhost http /usr/local/nginx/conf/conf.d/yourdomain.com.conf and/or /usr/local/nginx/conf/conf.d/yourdomain.com.ssl.conf in BBCODE CODE tags as outlined at How to use forum BBCODE code tags | Centmin Mod Community
