pcre download fail and installation stops
Discussion in 'Install & Upgrades or Pre-Install Questions' started by pamamolf, Sep 25, 2017.
    3,147
    303
    9:23 AM
    Nginx-1.13.x
    MariaDB 10.1.x
    Hello :)
    I just try to install the latest Centminmod beta using:
    and got this:
    2017-09-24 21:07:21 (19.5 KB/s) - Read error at byte 634722/2068775 (Connection reset by peer). Error: pcre-8.41.tar.gz download failed.
    Is pcre link dead?
    Thank you
    37,663
    8,241
    5:23 PM
    Got the install log ?
    Example list /root/centminlogs files in date ascending order and grep for install.log
    37,663
    8,241
    5:23 PM
    also what if you manually download the file on the server ?
    wget https://centminmod.com/centminmodparts/pcre/pcre-8.41.tar.gz
    where is server located geographically ? was it close to London, UK ? as from your download timestamp closest in my logs refer to my London cluster for centminmod.com. There were 2 downloads for pcre around that time from 45.76.32.xxx and 45.76.38.xxx based servers.
  4. pamamolf
    3,147
    303
    9:23 AM
    Nginx-1.13.x
    MariaDB 10.1.x
    It was a test vps from Vultr Amsterdam but I just destroy it and I will check tomorrow again from a new vps from Paris :)
    But if the link is ok then the vps may had some network issues...
    I will report back if I got the same issue again ....
